Closed Thread
Old 08-17-2005, 10:30 AM   #1 (permalink)
hydrohopper's Avatar
Member Number: 11900
Trader Rating: (37)
Default How are you set up to spray
Let's get some info together -
Nitrous Kit?
Shot?
Power Mods & Fuel Supporting Mods?
How is your Nitrous kit setup?
Boost Level before Nitrous engages?
Boost level while Nitrous is engaged?
What gear do you usually begin to spray?
What RPM do you have the Nitrous to begin?
Any complications you have encountered while using Nitrous?
I'll start first. . .
Nitrous Kit: Nitrous Express Single Stage Fogger System
Shot: 50 Shot
Mods: S1, AGP CAI, AGP WGA, AGP Race FMIC, NX Intercooler Sprayer, Mapclamp
Boost Level Before: 18psi
Boost Level While Engaged: 20 psi
Gear: 3rd & 4th
RPM: 3K to redline
Complications: Not yet
Come on guys let's post this info. We can really get a understanding how one person may differ from another.
Mopar Stage 3R with Toys
2004 Flame Red SRT-4
Turbocharged 2.4L DOHC I4 HO
hydrohopper is offline
Old 08-17-2005, 12:47 PM   #2 (permalink)
04bluesmithjuice's Avatar
Member Number: 10189
Trader Rating: (17)
Nitrous Kit - NX stage 1 single fogger efi kit
Shot - 75 shot jetting
Power Mods & Fuel Supporting Mods - Stage 0 computer, stock 04 injectors, Walboro 255, 3 inch TBE w/o muff and cat., BC, S-AFC, cai, solid upp pipe (jmb), agp fmic (street not race)
How is your Nitrous kit setup - WOT (till I have some funds, then going with progressive controler)
Boost Level before Nitrous engages - 17-18
Boost level while Nitrous is engaged - 21ish
What gear do you usually begin to spray - On the street, third gear, first and second are usless with nitrous, tires just roast. At the track on dr's, I shoot in first as soon as I get to 3K rpm, its WOT for me.
What RPM do you have the Nitrous to begin - always after 3K rpm, you never want to shoot before that, your motor will go BOOM
Any complications you have encountered while using Nitrous - None to date, just make sure you have a full bottle or a bottle warmer, spraying nitrous while the bottle is very low or completly out will make you look like an idiot *hides behind wall*
Brian
Mountain Section's Resident Asshole
04 E-Blue SRT-4 <-Under construction, built bottom end, ported and built head, big turbo, standalone, auto trans, its going to be nasty!!
Ask yourself one question:
"When you turn your car on, does it return the favor?"
04bluesmithjuice is offline
Old 08-17-2005, 12:52 PM   #3 (permalink)
Trader Rating: (37)
That was great! A lot of info so other's can compare. Anyone else?? Come as many views we can have more on here.
Old 08-17-2005, 02:58 PM   #4 (permalink)
srt4ram360's Avatar
Member Number: 5448
Trader Rating: (28)
Nitrous Kit? NX efi stage 1 kit
Shot? 75 shot jets ( 41/26)
Power Mods & Fuel Supporting Mods?.... stage 0, map clamp, 3" catless dp with 3" side exit, aem cai,msd wires coil, ngk iridiums,fuel pump,tcc wga,
How is your Nitrous kit setup? Msd 8969 digital window switch, wot switch
Boost Level before Nitrous engages?19 psi fading to 15-16
Boost level while Nitrous is engaged?21-22 psi fading to 17
What gear do you usually begin to spray?late 2nd gear so when i hit 3rd its already activated
What RPM do you have the Nitrous to begin? was at 3600 rpms..now at 4200 rpms
Any complications you have encountered while using Nitrous? none so far..cross my fingers
on a 40 shot i did 300whp and 347 wtq with nitrous activated at 3600 rpms
on the 75 shot did a best of 331whp and 379.4 wtq (on 3" downpipe connected to stock exahust) with nitrous activated at 4200 rpms
(previous dyno gained 16-17 whp and 20+wtq by moving it from 4000 rpms activation to 3600 activtion) but due to some wheel spin i had to adjust it to 4200
hope this helps,
alex
2005 Mustang GT, intake, full exhaust, tuner, pullies, and some extra's
STOCK STOCK STOCK just the way DCX likes it
srt4ram360 is offline
Old 08-17-2005, 07:53 PM   #5 (permalink)
SPL Dan's Avatar
Member Number: 24840
Kit - Custom NOS setup
Shot - 110ish .47 Nitrous / .24 Fuel
Mods - Tip Mod , Stock Open DP , Walbro 255 , Spring Mod ,NGK 4306@.30 , K&N Drop-In
How is it setup - Go Baby Go button style
when - 20MPH or higher
Complications ? 1 nitrous backfire at teh track blew my stock IC pipe to shreads and knocked my TPS out of adjustment
Before spike 17 hold 12
After spike 22-23-hold 13
05 OB
Mods : Stage 0 : CCA FMIC : AGP WGA : AGP Return Line : DasMopar Clamp : K&N Drop In : Walbro 255 : Needswing 3" DP : MaxxFab o2 : CMS Cold pipe w/ HKS SSQ : DIY IC Sprayer : CM Stage 4
Some Nitrous and Slicks
291WHP/374WTQ No Nitrous
426/512 Bottle Fed on 140 shot Stock IC & 02 Housing
???/??? on 180 Shot
12.194@111 No Juice 1.697 60ft
11.497@126 w/140 shot-Highest Trapping Stock Turbo in US !
SPL Dan is offline
Old 08-17-2005, 08:04 PM   #6 (permalink)
Member Number: 28180
on a stock set-up would a 75hp wet shot be ok? i wanna be able to make the 45min trip home from the track
Srt4Toyota is offline
Old 08-17-2005, 09:18 PM   #7 (permalink)
Trader Rating: (37)
For this setup I would recommend SPL Dan's setup. Start out with a 50 shot and work your way up.
Old 08-17-2005, 11:04 PM   #8 (permalink)
Member Number: 2997
I'll be spraying soon
Nitrous Kit- NOS WET
Shot- 50hp jet 35n 20f
Power Mods & Fuel - Stage 2 w/toys, ed's hard pipes, greedy type s, scremon demon coil, when the kit is on i will have nkg lztr6aix-13 plugs .032
How is your Nitrous kit setup- fpss,purge,bottle heater,carbon fiber nitrous gauge, inline fuel and nitrous filters, msd 8969 digital rpm window switch,blow down tube, everthing needed except fuel pump. i was told i'll be ok on a 50 shot. but once i get a fuel pump and 3'' 02 and needswing dp i'll tune to 75-100 shot
Boost Level before Nitrous engages- spike 21-23psi drop to 20psi and hold then drop to 15psi at redline
Boost level while Nitrous is engaged- my guess is alot mabie too much but will find out soon.
What gear do you usually begin to spray-n/a
What RPM do you have the Nitrous to begin-i'm thinking i'll try 3200 on 6200 off
Any complications you have encountered while using Nitrous-n/a
I should be spraying with in 2 weeks
12.877 at 110.61. . . . Stage 2 w/toys & bfg's dr.
off the bottle
srt4 8u is offline
Old 08-18-2005, 08:25 AM   #9 (permalink)
Trader Rating: (37)
I still can't wait until I get the kit in. I hope the 50 shot gives a real good kick.
Old 09-24-2005, 07:55 AM   #10 (permalink)
Trader Rating: (37)
My kit is now in here is my setup...
Shot: 50 Shot
Mods: S1, AGP CAI, Mopar Catback Exhaust, AGP WGA
Boost Level Before: 15psi
Boost Level While Engaged: 20psi
Gear: 3rd & 4th Gear
RPM: I think I will have a window switch set at 3k to 5k
Complications: None
I was thinking of kicking the boost up to about 17 psi. If I did that I imagine that boost would be higher too while spraying. Would this be ok?
Old 09-24-2005, 09:13 AM   #11 (permalink)
Glacius's Avatar
Member Number: 3149
Trader Rating: (63)
not in yet, it's in the works
zex 4 cyl direct port setup, 100 or 125 shot, fired off tps sensor and msd window switch, other mods are
stg 1
return line and fpr
big fmic
3" dp with borla catback
meth injection
walbro 255lph pump
afc
avc-r
Glacius is offline
Old 09-24-2005, 09:16 AM   #12 (permalink)
Member Number: 10065
stg 1
return line and fpr
big fmic
meth injection
walbro 255lph pump
afc
avc-r
clean out ur pm box
Best time w/ catback and wga.
13.60@101.9mph
60ft- 2.10 :
Mods:2 inch drop, Borla cat back no res.out the side, S1, turboxs rfl,turboXs wga, NX 75 wet, NX intercooler wrap!
IMPORTWHAT is offline
Old 09-24-2005, 09:28 AM   #13 (permalink)
Glacius's Avatar
Member Number: 3149
Trader Rating: (63)
clean, didn't notice i filled it up lol
Glacius is offline
Old 10-16-2005, 02:00 PM   #14 (permalink)
Trader Rating: (37)
just a bump for any added info . . .
Old 10-21-2005, 10:08 AM   #15 (permalink)
THIEF
Member Number: 34708
Trader Rating: (-2)
nos single fogger system
100 shot
s0 3'' exhaust stock 02 housing 3'' intake forge wga and profec b spec 2 drag radials and stock fuel pump
it spikes 17 holds 15 i spray when i feel like it usually 2nd 3rd and 4th 3-6000 rpm 46n 30f...i have a switch to activate the button then i have a microswitch which i hold in my hand and spray when i want to
IT DOESNT MATTER IF I BEAT U BY AN INCH OR A MILE I COULD OF PULLED HARDER IF I SPRAYED....
04srtonspray is offline
Closed Thread
Page generated in 0.37817 seconds with 11 queries
