Old 10-11-2009, 07:36 PM   #1 (permalink)
chrishna's Avatar
Member Number: 47605
Default help me decide; controler
ok guys, so far i only found 2 controler with a a/f ratio shut down. not sure which one the get,
1st
the dyno tune a/f ratio Nitrous oxide air/fuel ratio lean shut-down switch for use with nitrous oxide systems. Will shut nitrous down if a lean condition occurs while using nitrous oxide. - Nitrous air/fuel ratio lean shut-down switch
DynoTune one Stage RPM Window Switch / TPS DynoTune Product, 711.2-DynoTune one Stage RPM Window Switch / TPS - DynoTune, Nitrous systems, Purge kits, Nitrous Bottle heaters and more!
2nd
MicroEdge Nitrous Controller Harris Speed Works*::*Nitrous Controllers*::*Nitrous Window Switches & Timing Controllers*::*The MicroEdge Nitrous Controller
any input would be greatly appreciated.
399hp. 423tq stock turbo with 60 shot
chrishna is online now   Reply With Quote
Old 10-13-2009, 03:57 AM   #2 (permalink)
04inred's Avatar
Member Number: 32838
I have the old school vertion of the dynotune one and Im sure the other one is no diffrent, but the key is you have to have a wideband that will talk to them. The wideband has to have an out put that the switch can read. Im not sure if you have one but I know my old LM1 from inovative has one so if and when I get a chance to hook it up ill be good. As far and the controlers the microedge on has mor ethings going for it, but i can tell you for a fact that you will need a tach adapeter for our car to run them. If the Army would let me stay in the states for more then 6 months at a time I could get you moreinfo on the controlers I have.
(\__/)
04inred is offline   Reply With Quote
Old 10-13-2009, 04:22 PM   #3 (permalink)
chrishna's Avatar
thanks for the info.
well, just got done doing all the wireing. also, wired in the msd tach driver for rpm. tps for wot signal. out signal from the wideband for a/f ratio.
so now am just waiting to order the right controler.
Old 10-14-2009, 02:18 AM   #4 (permalink)
04inred's Avatar
Fjo makes a great controler, and so does cooling mist. they have one that you can program to be progresive and O2 bases and boost and all that stuff and its not that expencive.
Old 10-26-2009, 02:55 PM   #5 (permalink)
Member Number: 75468
Actually no tach adapter needed. It can be run off of just about any signal type.
We also have a + upgrade available for the microedge unit as well. You can add it onto any microedge out there (needs to have version 2.0 software flashed), so if money is tight you can always pick it up later down the road. The + upgrade adds the progressive features as well as a bottle contents indicator. What's cool about the progressive feature is that you can have a different graph for each and every gear. And its not some generic linear line...you can custom program it to build non-linearly all done via the microedge unit. No laptops and no cheap read-outs that make you decipher code.
Nick
Nick@HSW is offline   Reply With Quote
Old 10-27-2009, 08:36 AM   #6 (permalink)
Rhunter's Avatar
Member Number: 36794
Nick
Nick,
This sounds like a WIN! would it play nice with N2MB's nitrous control module that controls the solnoids during WOT shifts?
Rhunter is online now   Reply With Quote
Old 10-27-2009, 10:58 AM   #7 (permalink)
Quote: Originally Posted by Rhunter View Post
Nick,
Fill me in...what is it and what does it do?
Nick
Old 10-28-2009, 09:12 PM   #8 (permalink)
chrishna's Avatar
just wanna say the microedge is a great controller, took me like 30mins to install, works great, easy to program.
the best part for me is that i can save 3 diff setting and can switch bitween them while driving down the road. its a great controller
i would recomend this controller to anyone who is thinking about using nitrous
Old 10-28-2009, 09:15 PM   #9 (permalink)
chrishna's Avatar
Nick
didn't know that. i already have a tach adapter hooked up to mine
Old 10-29-2009, 01:32 PM   #10 (permalink)
Rhunter's Avatar
Nick
The N2MB WOT box cuts the car's ignition during no lift shifting. What the nitrous module (add on for the wot box) does is allows a driver to do this while using nitrous.
I'm momentarily stops the solnoids from spraying during no lift. I have one, but that's on my list of things I need to install for spring.
Old 10-30-2009, 12:22 PM   #11 (permalink)
Not a problem. It can read injectors, coils, just about anything! Thanks for the feedback!
Nick
Old 10-30-2009, 12:24 PM   #12 (permalink)
Yup very easy to implement. Send me an email when you're ready and I'll draw up a diagram for you.
Nick
Page generated in 0.14478 seconds with 13 queries
