The "best" way is a fuel rail with a shrader valve built into it. I took the inexpensive route and it works great. I replaced the stock fuel line from the firewall to the stock rail with rubber hose and t'd into that. I used a braided fuel line to get from there to the fuel solenoid.
Get a 03 fuel rail, run the provided braided fuel line from the schrader valve located on the end to the fuel solnoid. You will need the little schrader tool to remove the little valve thingy. Do it right the first time.
the cheapest fuel rail with a shrader valve is off a first gen sohc neon. a dohc doesnt work. they are normally between 10 to 25 dollars shipped off neons.org
^^^That's great info!! I might switch my setup to this.
Do it man. I don't have that rail, but having the schrader at the end makes things so clean and easy. The line to my fuel solnoid attaches directly to the end of it. easy as pie and less chance of getting a fuel leak.
I'm sure it will work, but why take the chance? Why spend the money for a nitrous kit then cheap out on something as important as fuel? Dmoney has given you a cheap, clean and more secure option for your fuel needs.
Plug and play man, and it will only set you back 25 bucks.
If you can't spend another 25.00 can you afford to have a nitrous kit?
I'm not trying to be a prick, I just don't want to see you take short cuts.
im not trying to be cheap, im just trying to get it goin...now. i have plenty of hose already and have no patience for waiting on parts to come. i mean, if its gonna be a risk, then im more than happy with waiting. but rather than getting a rail from a sohc, is there a better one i can get instead?
