Old 06-23-2009, 09:56 AM   #1 (permalink)
1srt4_2nv's Avatar
Member Number: 62580
Default dry kit and stg2????
since i know stg2 runs rich, is it okay to run a higher dry shot (55hp maybe 75) or should i just go with a wet? i have stg2 with toys, now does the toys still work with the kit? HOM and IC sprayer, 17psi@agp WG or should i just save up and buy a big turbo with stg2
looking to hit low 12s or 11s with slicks, maybe DR and cheapest way??
2004 Neon *you know, the unmentionable kind* SRT4\
FOR SALE!!!!!
skittles is one hell of a drug
1srt4_2nv is offline   Reply With Quote
Old 06-23-2009, 12:07 PM   #2 (permalink)
Rhunter's Avatar
Member Number: 36794
- Wet kit is safer than dry. You can compensate for the richness of S2 by using a smaller fuel jet.
- IMHO you are better off injecting nitrous into the motor instead of wasting it on your intercooler. If heat soak is an issue, it's time for a better intercooler.
- You can spray and run HOM but I don't recommend it. If you are gonna spray on HOM you better ensure your tune is perfect!!! Not only do you need to monitor AFR's you need something to monitor Knock.
Guys have been into the 11's without a staged upgrade, nitrous and a lil tuning.
One guy went 11.5 with nitrous, bolt ons and a map clamp
Old 06-23-2009, 06:02 PM   #3 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
i know a guy doing this, i think with about a 50 shot he lost .2 AFR
so its pretty safe (if you run a small shot) and you run rich, but remember if there are any places in your tune where you are lean or close you could do damage, so do your home work and map out your AFR's vs boost and rpm first
Old 06-23-2009, 09:00 PM   #4 (permalink)
1srt4_2nv's Avatar
so that mean's i should just go with a wet kit for safety reason (better safe than sorry)
Old 06-24-2009, 07:46 PM   #5 (permalink)
rrmike1's Avatar
Member Number: 55729
It's not only safer, it's easier to tune...
Mopar S2 no toys, FBM pnp'd turbo/mani., Rage 55mm T/B, AGP WGA, AGP CAI, MPx 3" O2, Maxxfab 3" DP, Mopar Exhaust, AEM UEGO, SprayItRacing BOV, Crane 8.5mm wires, Champion RE10pmc5's, Stant 180 thermo, Prothane race MM inserts, Autometer 30/30, Tein H's, Proparts dual-gauge pillar, Fuel pump re-wire, NOS Sniper kit
rrmike1 is offline   Reply With Quote
Page generated in 0.13946 seconds with 13 queries
