Old 09-30-2009, 11:52 PM   #1 (permalink)
Member Number: 75414
Default does someone have an answer please
so i hooked up nitrous to my 04 srt 4 went out to make a pass and as soon as i hit the switch my 90 degree bend in my intercooler pipe blew to pieces it was made of rubber and oil that has been leaking on it for awhile and weakend it it was only a 65 shot what are my options to fix this problem and keep it from happening again
avogland is offline   Reply With Quote
Old 10-01-2009, 06:51 AM   #2 (permalink)
Member Number: 17029
Trader Rating: (10)
Sounds like a backfire happened. If so, you need to figure out why it happened. What rpm did you spray at, were u at WOT, is the jetting correct ? Also is your ignition system in good shape and what about plug gap ? Tightening your plug gap a little cant hurt when it comes to using nitrous.
msd coil, denzo iridiums, billet mounts, mopar bov and sts, 180 stat, DZ coilovers, stage1pcm, and a k&n drop-in filter. Best et 12.50@117 on worn out drag radials w/ 2.0 60' and couldn't spray until i was already in 2nd gear
All statements made by me on this Forum or any other Forum are purely for entertainment purposes only
bobs rt is offline   Reply With Quote
Old 10-01-2009, 12:12 PM   #3 (permalink)
i was at about 2500 rpm wot and everything on my car is in great condition is it possible with the tube being weak and my turbo already making 18 pounds that the extra boost was to much for the rubber pipe i soon as i hit the nitrous it blew and that was the first time i used it i ws only using a 65 shot on a dry kit it was shooting into my intake pipe about 12 inches from the air filter
Old 10-02-2009, 10:13 AM   #4 (permalink)
porksword's Avatar
Member Number: 66925
Trader Rating: (21)
If I were going to guess. Since you are using a dry kit and shooting it in before the turbo. The turbo isnt at full spool at 2500 rpms, so when you started spraying the nitrous, it acumulated in the intake pipe and then the turbo spooled and gave the sytem alot more than just a 65 shot.
If your going to run that setup I would wait until full spool (3k+ depending on turbo) to start spaying so the nitrous doesnt back up.
If you want to use it to help spool, you should run a wet kit just before the TB.
porksword is offline   Reply With Quote
Old 10-02-2009, 10:33 AM   #5 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
yes before the tb
AGP S256 FS
lyncoo is online now   Reply With Quote
Old 10-02-2009, 10:34 AM   #6 (permalink)
lyncoo's Avatar
Trader Rating: (92)
what turbo do you need help spooling
Old 10-06-2009, 10:32 AM   #7 (permalink)
s ar tee 4's Avatar
Member Number: 54654
a dry shot, before the turbo, at 2500 rpms. all of those at the same time cant be good
s ar tee 4 is online now   Reply With Quote
Old 10-06-2009, 08:53 PM   #8 (permalink)
Rhunter's Avatar
Member Number: 36794
1st off a dry shot is a big NO NO with these cars! You will not get additional fuel.
2nd, if would be a good idea to back your boost down a pound or so. Because of the nitrous, you are gonna get more boost.
3rd. Do you have a wide band? Do you have any idea what you AFR's was while spraying a 65 dry shot?
Dude, your car is not gonna last long.
Old 10-07-2009, 04:26 AM   #9 (permalink)
Trader Rating: (10)
yeah 2500 is a little too early to be spraying. my car sometimes didnt even like spraying at 3000....but 3300 and above never had any issues. and unless you are running super rich off the bottle then i would not run that big of a dry shot. Wet shot definately a safer option plus you should be spraying into the cold side pipe after the intercooler.
Old 10-07-2009, 04:34 AM   #10 (permalink)
Member Number: 39007
2500 is too early. Needs to be more like 3000 or 3200 just to be safe. Shoot your spray in the cold side charge pipe, and dont use dry, use a wet kit.
JMB
Red 04, t04z, meth, spray, crane 18's
639hp/649 tq
RarB!tch is offline   Reply With Quote
Old 10-07-2009, 05:10 AM   #11 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
x2 when you spray low in the rpm range (under 3k) your cylinder pressures will spike way beyond what they should ever see (even at max power with a big turbo) you got away lucky if you look at charts of IMEP and BMEP with N2O they can see 2-3x the load when shot under mid 3k rpm's (3k will be OK with a 65 shot) that means you motor may have been seeing the pressures it would at 500-600 hp at 2500 rpm (YOUR RODS HATE YOU NOW)
NEVER BELOW 3K ...OK
Old 10-07-2009, 06:57 AM   #12 (permalink)
Sota's Avatar
Member Number: 31159
in for the part out thread.
  • N2MB / Jay & Jon
  • S&P Development / Jimmy
  • Maddog Shifters / Chuck
What else needs to be said?
Sota is offline   Reply With Quote
Old 10-07-2009, 07:01 AM   #13 (permalink)
never2muchboost's Avatar
Member Number: 20976
Trader Rating: (59)
first thing you should do is educate yourself on something you know nothing about.65 dry shot? 18 psi? come on...seriously
Email: Jay@N2MB.com
5/24/09 9.30@154
10/4/09 9.12@161.9
www.n2mb.com
Old 10-07-2009, 07:08 AM   #14 (permalink)
Sota's Avatar
Jay...
2 posts, join date this month, I'm thinking 3rd or 4th owner on the car and an age backet of 17-22.
Old 10-07-2009, 03:25 PM   #15 (permalink)
Member Number: 60131
me thinks the motor will go hand grenade....
lower your boost, wait till full spool ( above 3000 rpm ) get an air / fuel monitor, and get a wet kit. save the motor from the first re-build for a few more months
JonBones is online now   Reply With Quote
Page generated in 0.18565 seconds with 13 queries
