Old 05-09-2008, 02:49 PM   #1 (permalink)
Member Number: 41700
Default direct port nozel placement?
where on the intake manifold is the best place to put the nozell would it be close to the plenum or close to the port?
Old 05-09-2008, 04:51 PM   #2 (permalink)
Member Number: 11814
Trader Rating: (87)
You may need to search for some images for guidance.
Also consider if intake manifold spacer is used (= moving the intake out therefore closer to the upper rad hose). I did my intake for methanol port injection a while ago and the placement in #1 runner is close to the upper hose. Also watch out for fuel rail clearance, stock 03-05 rails offer most room, S3 rail and Boomba hang over a bigger part of the intake runner......not sure out other rails. I'm using a Boomba intake spacer and a Rage-Tek thermostat housing spacer so that things are more workable.
I'll get an image up in a little bit as it may help a little.
IMO what ever you do, do not drill without mocking up and then double checking things with everything installed in the car....also check the charts so that you use the correct drill bit for the correct tap being used = more important to do this with aluminum then with steel, a badly sized drill and then tap procedure will equal chewed up/galled threads made by the tap (also make sure to use a fresh tap with a little oil for lube)
Heres two images showing original setup with stock rail
When you mock things up have the rad hose and everything else installed.........with everything installed it gets tight, I wound up getting the spacer for the thermostat from Nemo because the one jet is very close to the rad hose with the Boomba intake spacer installed. I bought a Boomba rail and its tighter again because its double the size of the stock rail but I do not have an image of that yet setup yet.
Heres the same thing with the S3 rail
You can better see things here with regards to the rad hose and you can get an idea that the Boomba rail takes up room kinda of like the S3 rail. With the S3 rail both cyl 1 & 2 need clearance
Old 05-09-2008, 09:20 PM   #3 (permalink)
damm looks nice im thinking about under the manifold "stealthy"
the n2o is gona eat up alot of room with the fogers and distribution blocks
im definatly gona take my time
thanx for the post up and pix
what size meth nozel are you gona run ?
Old 05-10-2008, 12:14 AM   #4 (permalink)
04inred's Avatar
Member Number: 32838
Search in this ection for a guy named neonmarine. He had a sweet direct port set-up tha we never got fully tuned cause he traded the car, buttword the end he made 400hp and 400tq from 3000 to almost red like with a 100 shot.
(\__/)
04inred is offline   Reply With Quote
Old 05-10-2008, 08:22 AM   #5 (permalink)
Trader Rating: (87)
Not sure on the jet size just yet for the methanol injection. I have several different sizes on hand to choose from. I'll know more when the car is completed and the EMS gets tuned.
Old 05-10-2008, 09:16 AM   #6 (permalink)
Rhunter's Avatar
Member Number: 36794
Neons was not the prettiest install I've ever seen but it was darn affective. I wish he would of finished the darn car!! I wanted to see what that sucker would do at the track.
Someone else posted pics of a DP set up with the nozzles installed in the bottom of the IM but I can't remember who. the nitrous section is wierd. You have a few guys who post all the time, the others seem to be passers by. They are either considering nitrous, or were used it for a short period of time.
03 SRT-4
Old 05-10-2008, 12:41 PM   #7 (permalink)
im thinking as close to the port as posible would be the best, to avoid losing charge due to pressure pulses, but it looks like half way down the runner is the best i can do
Old 05-10-2008, 08:27 PM   #8 (permalink)
Trader Rating: (87)
Heres a picture I found for another idea.......some one has it up for sale
http://www.srtforums.com/forums/f27/...-other-441921/
Old 05-10-2008, 10:32 PM   #9 (permalink)
04inred's Avatar
thats a decent set up.
Old 05-10-2008, 10:45 PM   #10 (permalink)
thats sexy, thanx for the pic that gives me a couple ideas
Old 05-15-2008, 10:47 PM   #11 (permalink)
How-To Forum Moderator
blubyu's Avatar
Member Number: 4928
Trader Rating: (28)
blubyu is offline   Reply With Quote
Old 05-16-2008, 05:32 PM   #12 (permalink)
Quote: Originally Posted by blubyu View Post
THATS AWSOME LOOKS LIKE THE SAME KIT I HAVE !!!!!!!!! THANX FOR THE PIC
JUST OUT OF CURIOSITY WHAT LEVEL HAVE YOU RUN IT AT AND DO YOU HAVE ANY PROBLEMS WITH THE ZEX KIT
Old 05-16-2008, 08:42 PM   #13 (permalink)
blubyu's Avatar
Member Number: 4928
Trader Rating: (28)
We are working the bugs out of the street tune so it hasn't been sprayed yet.Truth be told there is no point in spraying untill i can
find more traction.
Old 05-16-2008, 10:16 PM   #14 (permalink)
yea i was spining hard in 3rd with just a 20g, i have no idea whats gona happen now..but is sure gona be fun
Old 05-18-2008, 04:54 PM   #15 (permalink)
daniel427ss's Avatar
Member Number: 51325
noob nitrous ? 1) is there a way to have a kit to be active when only during wot, but spray when go go button is pressed(this means i can press button but it wont spray until i am wot or i can go wot n not spray because i wont press the button)
and only posible under certain rpms?
i know some r possible like wot feature n spray at certain rpms but altogether? button feature n 2)maybe a thing where it stops sprayin when goin wot n u press the clutch? cuz i think is not good to spray during wot shifting correct?
is it possible with this kit nutz bought
daniel427ss is offline   Reply With Quote
Page generated in 0.24901 seconds with 11 queries
Search Engine Optimization by vBSEO
