I believe they are interchangeable, both are stored as liquids around the same pressures 800-1200psi i believe. The only issue you will have is finding someone to fill up a no2 tank with co2. Generally they will only fill a tank with the correct labeling of its contents.
JUST fill it with nitrous bro
Need your turbo rebuilt or modded pm me, LKQ Michaels Auto/KEYSTONE
I have done it, i made an adapter for the fire exting place so it would fit the bottle.
You can do it at a hardware store.
8 dollars a bottle for filling vs 50$.
It was effective when i had it.
Paintball shops and fire and safety shops usually carry co2.
All items for sale will use the following format & MUST include pictures:
Name: (FIRST & LAST)
Contact: (VALID EMAIL OR PHONE #)
Price:
Description:
If you have any questions please see here: http://www.srtforums.com/forums/f27/...elines-352468/
Intercooler sprayers are a waste of a perfectly good nitrous set up. Get a better intercooler if you are having heat soak probs.
It gets 100+ degrees here in the summer, but the humitdity is also 100%.
I don't think it was a waste. But i don't have one anymore because, i spray the good stuff.
I have heard nx claim that a civic gained 50 hp from one of those.
Can they be sure the HP gain was from the spray going onto the intercooler? Or was a majority of it from it getting injested into the intake? That would basically be an unregulated dry shot.
I'm not saying it won't combat heat soak, but if you IC is having that much of a problem then it's time for a better IC.
I noticed a diffrence. Its almost the same as the intercooler sprayers on the stage 3. Is it worth buying one? Not really. Mine was given to me.
But it can be done, and co2 is shittones cheaper than n20. Sell your ring, buy some more noids and do a wet shot.
