Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Other SRT/PVO Vehicles > Other SRT/PVO Vehicles > Viper/SRT-10 Discussion
Old 02-02-2008, 02:03 PM   #1 (permalink)
Member Number: 61298
Default clutch slip and weird marks on flywheel
Hey to everyone,
I'm a new 1st timer here and I need your advice. Got my '08 and love it...but...
I was in stop and go traffic for a while like 40 minutes in Miami, found a chance to punch it to get away from the herd and my clutch slipped BADLY (foot off the pedal). It went to redline so I got off the throttle and after a cool down, it seemed to engage again but not like before.
ANyway, the dealer tore it apart and said the clutch was toast and the flywheel had weird burn marks on it in at like 12 and 6 o clock and had NEVER seen this before! He said there is a new type of clutch in the 08 and it is completely different than the previous Vipers
Has anyone experienced this with their 08? I just got my car and hate to think I messed it up (I *know* how to drive a manual btw :-))
Thanks!
NewSnake
NewSnake is offline   Reply With Quote
Old 02-13-2008, 08:40 AM   #2 (permalink)
Member Number: 61594
Default Viper clutch problem
New Snake,
It looks like one of three things happen, either it was NOT properly installed/adjusted from factory set at the correct clearnce (between the disc
and flywheel) A defective pressure plate assy or some binding when you release the clutch and it's partially engaged simulating you resting your foot on the clutch and causing over heating the whole assy. The dealer should replace everything including the flywheel, that should take care of it.. and remember to always use your foot rest. even the lightest pressure WILL cut clutch life to some degree!! Hope the info. help!!
KennyHemi,
Copperhead coupe owner
P.S a warped flywheel can also be the culprit.
kennyhemi is offline   Reply With Quote
Old 02-19-2008, 04:15 PM   #3 (permalink)
SRTsouth's Avatar
Member Number: 60568
I try to keep my foot off the clutch whenever possible. By the way, congrats on your new purchase! What color did you get?
2005 Dodge Viper SRT10 Roadster
K&N Cold Air Intake
2007 Dodge Charger SRT8
Option group III w/sunroof, Mopar CAI, Zoomers
SRTsouth is offline   Reply With Quote
Page generated in 0.12964 seconds with 13 queries
