Old 10-23-2009, 02:29 PM   #1 (permalink)
Member Number: 42413
Default would running thicker oil cause lower oil pressure?
I use 20w-50 in my recently built motor and I am noticing at times that my oil gauge will sometimes drop to 0 from 5 when the cams get a bit of lope to them. I am wondering if it is the thickness of the oil or just something to do with the crane 18's. If I blip the gas even a little it goes back up to normal. I have a new oil pump from DCR so assuming that not an issue. I have the gauge in the head.
Member 685
RVDSRT4 is offline   Reply With Quote
Old 10-23-2009, 05:57 PM   #2 (permalink)
71ValiantSRT-4's Avatar
Member Number: 25339
Trader Rating: (93)
The gauge in the head will cause the psi to read lower to begin with.
71ValiantSRT-4 is offline   Reply With Quote
Old 10-23-2009, 06:30 PM   #3 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
20w-50 will break your oil pump in no time
wtf
unless your motor is built with loose tolerances and enlarged oil passeges DO NOT us another oil, this places a TON of stress on the oil pump
Old 10-23-2009, 06:31 PM   #4 (permalink)
nutz's Avatar
Trader Rating: (19)
waits for crying partout thread
Old 10-23-2009, 06:35 PM   #5 (permalink)
Hi N Mity's Avatar
Member Number: 33036
Trader Rating: (40)
buy a mechanical gauge and see if the pressure changes....maybe the sending unit or gauge itself is bad
to answer your question, thicker oil will cause higher oil pressure. what does your engine builder recommend for viscosity?
<-----Haz 1 Infraction for too large of a Signature.
Old 10-23-2009, 06:35 PM   #6 (permalink)
Member Number: 5368
I have been running 15w-50 for over 60k miles with nothing special done to my oil pump, I have not seen any issues yet.
viper20220k is offline   Reply With Quote
Old 10-23-2009, 06:39 PM   #7 (permalink)
nutz's Avatar
Trader Rating: (19)
then we should all do it WTF do engineers know
Old 10-23-2009, 06:56 PM   #8 (permalink)
julius717's Avatar
Member Number: 24352
wtf
uhhh sure about that? dcr recomends 20-50 on all their built motors. i been using it for about 3-4 years now myself.... but of course i have every DCR part in my motor
DRASTIC
julius717 is offline   Reply With Quote
Old 10-23-2009, 07:16 PM   #9 (permalink)
nutz's Avatar
Trader Rating: (19)
bearing clearences are different, and yes I am 100% sure puting thicker oil in a stock motor is the stupidist thing ever ...ask DCR
al it will do is lower needed flow and rob HP by overdriving the pump
I'm not here to educate fucking ricers who thing putting race oil in their car is cool, get a freaking grip people
Old 10-23-2009, 07:17 PM   #10 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
it calls for 5w30 good luck
AGP S256 FS
Old 10-23-2009, 07:19 PM   #11 (permalink)
lyncoo's Avatar
Trader Rating: (92)
race engines that use 20w50 are only good for one race. before a teardown or rebuild.
Old 10-23-2009, 07:19 PM   #12 (permalink)
since some people did not read
Old 10-23-2009, 07:19 PM   #13 (permalink)
AdvanSRT-4's Avatar
Member Number: 12791
Trader Rating: (57)
I also heard straight 90W also improves powah!!
Old 10-23-2009, 07:19 PM   #14 (permalink)
so all of DCR motors are only good for one run is what your saying?
Old 10-23-2009, 07:20 PM   #15 (permalink)
lyncoo's Avatar
Trader Rating: (92)
doesnt make i difference
Page generated in 0.19435 seconds with 13 queries
