Old 11-05-2009, 01:55 PM   #1 (permalink)
NastyNate310's Avatar
Member Number: 73269
Default Who has 8:8:1 compression ratio???
I am currently doing my build and want see how this compression ratio differs from others? Bad or good? My setup is meth injection ( straight meth ) and a jouranl 50 trim with supportiong mods.. and of course my 8:8:1 compression engine... Im going to drop the sucker in two weeks and want to know your guys's numbers and setup with this comression ratio.. thanx
p.s. I went with the eagle rods and wiseco pistons
Built bottom end on the way with a fity trim. You guess the rest...
NastyNate310 is offline   Reply With Quote
Old 11-05-2009, 02:42 PM   #2 (permalink)
Member Number: 33203
Trader Rating: (25)
I've been running a similar setup for right at 2 years now. I'd prefer a lower compression ratio due to knock issues, but this setup can work with the right tuning device. Don't expect it to do well at all if you're using a piggyback. You're gonna need timing control for sure.
Precision 6057@30psi on pump
8.50@87 on 10psi w/2.0 60 ft (wg pressure on 30 psi tune, no 2 step)
Contact Turbo666/TDSaaron for your tuning needs.
turbojonsrt4 is offline   Reply With Quote
Old 11-05-2009, 03:04 PM   #3 (permalink)
Member Number: 64820
like a dsp?
btree211 is offline   Reply With Quote
Old 11-05-2009, 04:04 PM   #4 (permalink)
Trader Rating: (25)
Dsp, sct, aem ems,and maybe aem fic as a last resort. You wouldn't wanna use anything like an safc or a dtec. Tuning with them only makes timing worse.
Old 11-06-2009, 01:18 AM   #5 (permalink)
Chief's Avatar
Member Number: 61336
running 8:5.... DSP low timming.... Gonna need meth or race gas to run higher CR with alot of boost. I get away with 18 psi on pump but timming in the teens.
Built bottom end
strapped BC and CP
HTA 60
PTP when you fedex man gettin this block?
Chief is offline   Reply With Quote
Old 11-06-2009, 03:23 AM   #6 (permalink)
Member Number: 36825
Would 8:1 pistons be better for 91octane. There is the trade off for for boost verses compression right?
SRT Jeff is offline   Reply With Quote
Old 11-06-2009, 08:00 AM   #7 (permalink)
Trader Rating: (25)
The lower the compression, the more boost you'll be able to run on said fuel.
Old 11-06-2009, 08:03 AM   #8 (permalink)
Trader Rating: (25)
Do you not have the meth on anymore? I hope that's without it. With 8.8:1 pistons, I daily drive on 30psi on 93 with meth, running off nothing but a mail in flash from agp. I normally get 0 kr doing so.
Old 11-06-2009, 08:13 AM   #9 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
Quote: Originally Posted by turbojonsrt4 View Post
Do you not have the meth on anymore? I hope that's without it. I daily drive on 30psi on 93 with meth, running off nothing but a mail in flash from agp. I normally get 0 kr doing so.
my dsp cable and meth kit comes today. you need to stop posting im eyeballing that turbo of yours lol
AGP S256 FS
lyncoo is online now   Reply With Quote
Old 11-06-2009, 08:36 AM   #10 (permalink)
Trader Rating: (25)
lol, I love it. Unfortunately, I don't believe you can buy them now, unless found used of course but I bet even that will be hard to do considering the short time they were sold.
Old 11-06-2009, 10:14 AM   #11 (permalink)
Chief's Avatar
yeaa w/o meth.... 250psi pump just arrived
Old 11-06-2009, 12:19 PM   #12 (permalink)
Trader Rating: (25)
Good, cuz if that was with meth, I was gonna tell you to just quit right now.
Old 11-06-2009, 12:22 PM   #13 (permalink)
lyncoo's Avatar
Trader Rating: (92)
my kit should come today
Page generated in 0.19318 seconds with 13 queries
