Old 06-27-2008, 12:21 AM   #1 (permalink)
Member Number: 61579
Default want to build engine
all right guys i think its time to build my engine. I would really appreciate any feedback u guys have . I have around a 2000-2500 budget including install. I really want to build everything to make 400 or more hp. What kind of internals u think I should get? I seen a couple things on modernperformance.com but not so sure what to go with. I have basic bolt on like AEM CAI, agp wastegate, greddy bov, 3 exhaust no cats, short shifter, stage 1 I think thats all . right now this is my daily driver but once I start the process probably get something else. so let me know what u guys think would be the best route. Also I live in the Houston area so if anybody knows any good and reliable shops to do this install please let me know. thanx
srt_unit is offline   Reply With Quote
Old 07-08-2008, 06:02 PM   #2 (permalink)
Member Number: 23004
If you want to make 400-450ish hp I wouldnt bother with a build bottom end. There are plenty of people making more than that on the stock block without any problems.
Dumetre is offline   Reply With Quote
Old 07-08-2008, 06:43 PM   #3 (permalink)
darooke's Avatar
Member Number: 26595
Trader Rating: (30)
I would get the modernperformance 8.0 compression kit. it includes everything you need. If you plan on using nitrous I would get dcr crank straps. You have to send your bedplate to DCR.
If you keep a good tune you don't need a engine build. If you are using nitrous, I would build my motor.
Now go get your shine box!
2005 Black ACR
Powered by Tune Time performance and N2MB
darooke is offline   Reply With Quote
Old 07-08-2008, 07:25 PM   #4 (permalink)
vcious's Avatar
Member Number: 50913
pistons, rods, and an upgraded oil pump just for peace of mind. my 2cents
stage2,Hahn s20g kit, QTP 3" dp w/dump, 3" sri, ED "beast" fmic,agp/turbonetics hp's, whalbro255, agp rL kit, RC 750's, CM w/m injection, 180 therm., catch cans, msd wires/coil, ngk plugs, agp wga,Hallman mbc, "raptor" bov, mm inserts, weapon-r torque damper(stiffy), spec stage3clutch/flyweel, b/s chain cut, s-afc II, PLX wideband,T-XS knock light, autometer(boost30psi,water,volts)A.F.scanguage pro, NDE TSC box
406whp, 425wtq
vcious is offline   Reply With Quote
Old 07-09-2008, 07:40 AM   #5 (permalink)
Default thanx
Hey guys thanx for your 2 cents. Yea I was thinking about getting the rebuild kit from modern. Do any of u guys have this kit? I do want to upgrade my turbo later on as well once I get the rebuild kit will it be ready for a turbo?Thanks let me know
Old 07-09-2008, 11:33 AM   #6 (permalink)
matthew00029's Avatar
Member Number: 46349
I got the kit but you can put together something yourself with better quality for about the same price or more. Building a engine the proper way is not cheap but you can do it. You could get:
JE 8:1 stock bore pistons- Modern Performance
Eagle Rods- Modern Performance
New OEM crank (not needed but not a bad idea)- Modern Performance
Water Pump- Modern Performance
All new gaskets- Modern Performance
Clevite Main and Rod bearings- Ptp
DCR oil kit- DCR
that should give you a reliable simple build.
05 Black SRT-4 ACR A lot of hard work and broke days. I hope someday the black beast will return...
matthew00029 is online now   Reply With Quote
Page generated in 0.14096 seconds with 11 queries
