Old 10-28-2009, 08:16 AM   #1 (permalink)
Member Number: 60592
Default Turbo needs rebuilt question
i have a 57 trim that needs rebuilt. the exhaust side looks like it had a peice of a piston or valve go through the turbo, and broke off all the tips on the exhaust compressor wheel. its got a little side to side play, but no in and out. what ever car this was on blew up cuz theres black sticky oil all over the exhaust side. the intake side is fine. who does good turbo rebuilds and how much are they?? what i need is a new exhaust wheel and possably new bearnings. what else would consisit of a turbo rebuild??
stock pcm with bolt ons 13.49@103.89
05 Commemorative Edition
PW1 ACC,ARL,GWA #74/200
SRT_PAPA is offline   Reply With Quote
Old 10-28-2009, 08:28 AM   #2 (permalink)
SRT-4runner's Avatar
Member Number: 68134
Trader Rating: (36)
AGP is probably the best for anything related to SRT's. But Blouch also does a good job and they are closer to us in the NE.
Vtec Slayer
SRT-4runner is offline   Reply With Quote
Old 10-28-2009, 09:24 AM   #3 (permalink)
a853rox's Avatar
Member Number: 1907
Trader Rating: (52)
I can rebuild most any non ball bearing turbos. We can replace turbine or comp wheels from damage as well.
I would need to see the turbo to fully asses the damage, but most times the rebuild, including a balance, is $325 for a turbo like that (could vary a little based on if it is a big shaft or little shaft version), plus the cost of any damaged wheels. Most comp wheels are in the 140-200 range, and turbine wheels are in the 225-325 range.
PM if you need a hand with this!
-Bob
Form and Function Performance, LLC
Trust those who KNOW performance, not just sell it
Your turbo upgrade/rebuild, airflow, and thermal management specialists!
|612-385-0419| |www.FFPerformance.com| |sales@FFPerformance.com|
a853rox is offline   Reply With Quote
Old 10-28-2009, 12:25 PM   #4 (permalink)
thanks guys!!!
Page generated in 0.17538 seconds with 13 queries
