#16 (permalink) |
![]() Join Date: Apr 2009
Member Number: 72050
I'm having this exact issue with the same turbo. I had a 30r before, got tore up and I got another one because I loved it. So this one I got the center section and compressor side are good, just need to rotate the exhaust side.... So I'm trying to understand about using a bolt to back it off. get one that's longer than came with it and screw it in until it prys it away? Not trying to be too rough on it. Maybe light rubber mallot taps around it? Thanks
FML
| Sponsored Links | |||
Advertisement | |||
#17 (permalink) |
![]() Join Date: Aug 2010
Member Number: 80621
put the turbo in a solvent tank for a couple of days remove
then cover the bolts and turbine housing in some wd40 zep ect let sit for a couple more days then try again its probably full of carbon |
#19 (permalink) |
Member Number: 90881
then cover the bolts and turbine housing in some wd40 zep ect let sit for a couple more days then try again its probably full of carbon Learn your products before you speak! To they guy having problems spray some pb blaster or jb80 on it and let it soak for a few min. That should penetrate in it and loosen it up for you.
#20 (permalink) |
![]() Join Date: Dec 2010
Member Number: 82185
that ^^
PB blaster and put it in a vice and give it some love taps with a brass punch all the way around the exh housing and it should break free
280whp 303wtq 16g bws, injen short ram, meth injection.
Stock intercooler, manifolds, o2 housing, wastegate, and motor. Best et: 13.4 Best trap: 107 |
#21 (permalink) |
those were are two different steps the solvent tank will help loosen/ remove the carbon then the zep, pb blaster, wd40 name your penatrant (sp here) will lossen the bolts and the housing |
#23 (permalink) |
![]() Join Date: Aug 2003
Member Number: 3294
Once again learn your product. Wd40 is not a penetrate. It is a WATER DISPLACER hence wd and a rust inhibitor.
maybe he is talking about the Specialist Product Line. They make a rust release penetrant spray.
Mods:
Intune with 3bar sensors 1025cc Duster injectors 3" TBE NGK AFX wideband ED Super Beast IC Mopar STS Gerry's Custom door sills & shift knob Realtune 60mm TB JMB SRI & CC AGP Trans & Motor mounts |
#25 (permalink) |
As long as the oil feed/return lines dont kink up id jus slap it on
please dont do this the oil drain needs to be within 15degrees from vertical best is 90 from ground. huh didnt know that about wd40 i never use it i mostly use pb blaster or (chevy heat riser valve penatrant if i can get it its like $20 per can ) taylor |
#26 (permalink) |
Yea they just came out with a penatrator not to long ago. Don't know how well it works or will I ever find out. Pb has never let me down so I always use it.
#27 (permalink) |
Vendor
![]() Join Date: Jan 2006
Member Number: 37310
If you can find it. Aerokroil is better than any of that stuff period.
Pm me for your performance modified clutch fork,Big turbo and oiling port needs.thumbsup:
I buy clutch fork cores.[/B] http://Wikyd-performance.com |
#28 (permalink) |
Member Number: 3294
I have used the liquid can before and it works good. I didn't know they made it in a aerosol.
Mods:
#29 (permalink) |
Vendor
Yeap. I have 3-4 cans at work at work since it's standard issue. Mouse milk is another.
#30 (permalink) |
![]() Join Date: May 2006
Member Number: 41851
i've had this happen to my 30r before...take all the bolts except for that one and use a hammer and tap on it all around...its from the carbon build up...trust me
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
