unhook battery
Just go underneath, you will see the starter you will need to remove a brace and then two bolts that secure starter to the block/trans/intake manifold
this will give you enough wiggle room to remove the wiring attached to it.
then reverse.
I just put in my new starter you can do it all underneath its really not that bad at all there is enough space to get hands and tools up to the starter
