Old 08-13-2006, 04:25 PM   #76 (permalink)
Member Number: 3175
Trader Rating: (41)
actually wih my thermal coated turbine side t3/t4, here was not so much noticible difference, as there was from the clipping (which was done later on)...thermal coating i believe does help, but just is not a butt-dyno noticible difference in my experience
Quote: Originally Posted by Tex
yes, but that has to do with the clipping not the coating. the coating helps noteciably iff you compare before and after with the same wheels. but it does help pickup 200-300rpm
jersturbo is offline   Reply With Quote
Old 08-13-2006, 04:34 PM   #77 (permalink)
Tex
Tex's Avatar
Member Number: 3622
did you get just the snail coated, or the manifold as well
-Soren Kierkegaard
Tex is offline   Reply With Quote
Old 08-13-2006, 05:07 PM   #78 (permalink)
Member Number: 3175
Trader Rating: (41)
that one was coated cast manifold (T2 turbo dodge PNPd) the 3 turbine housing (0.63 a/r) and the O2 housing also...
...did you do other mods at the time you installed the coated manifold, in which case that can change things
Old 08-13-2006, 09:02 PM   #79 (permalink)
Tex
Tex's Avatar
Member Number: 3622
i understand that changing more htan 1 item at a time will throw off results. im just stating that it helps
Old 09-12-2006, 02:53 PM   #80 (permalink)
duster360's Avatar
Member Number: 45182
ceramic coating is key in keeping the spool up. extra heat in the manifold keeps the gas density low, which helps to spool the turbo up faster
right on the effect of the coating ; wrong on the reason.
Kinematic viscosity goes up much faster with temperature than density goes down. At 70F its 1.64e-4 and at 1500its 1.51e-3 ft^2/s. Over 9 times "thicker"!! It might be less dense but it is more resistant to direction change. By comparison density decreases by a factor of just under 4.
Hotter gas does have more thermal energy availible(duh) to be transfered to the turbine and since its "thicker" it has a bit more inertia. If you keep the heat from being transfered to the ambient, through the housing, more energy is availible to turn the turbine.
Dave
duster360 is online now   Reply With Quote
Old 09-12-2006, 04:50 PM   #81 (permalink)
duster360's Avatar
Dave
I just re-read this. MAN! I sound like a tool!
Old 09-15-2006, 02:39 AM   #82 (permalink)
Member Number: 3175
Trader Rating: (41)
LMAO
Page generated in 0.19828 seconds with 13 queries
