i have spend some time searching out the sizing of the stage3 turbo assembly. i know factory is a TD04. whats the stage3?
thanks guys
thats what i figured, but do we have a wheel size or what have you. thanks a ton noTe
Well, now they have two different versions of S3R kits with the Tial wheel and steel wheel. I don't know the size of them off hand but I'm sure it's around here somewhere
What are you looking for...the dimensions of the wheels?
Yes...it's a TD05-15GK2-10cm2
The compressor (15GK2 portin) has minor diameter smaller than the 16G6 wheel.
Stage 3 Compressor:
Inducer: 1.942
Exducer: 2.560
Height: .900
The turbine wheel (TD05 portion) is same across the family (in dimensions anyways) that I have been able to find / learn.
S3 turbine
exducer = 2.220"
inducer = 1.933"
height = 0.800"
What are you searching for...project idea maybe...swap...let us know!
thanks guys
nah, doing some research. seeing what kind of power i will be able to get out of my stg3 assembly. though, its not a stock setup. ported/polished manifold/turbine housing/compressor housing. plus the hot side is all ceramic coated and the cold side is heat dispersant coated. wheels are currently stock...however, i will be needing a new turbine wheel here shortly. the wheel is slightly knicked. its fine temporarily, but i will need to order one up. the specs you gave about size will help a ton!
There are at least 2 other turbos I know of, which bolt right in....shhh!
2 questions. isnt the srt a reverse scroll? where can i get the wheel?
oh, and i lied...waht kind of machining is necessary for the bigger wheel
Evo is reverse scroll also.
Nigel
04 Srt-4-AGP Borg Warner S360-RS, E85, and MUCH MORE coming soon... 7.493@99.56<-- granny shifting on 30r with 93/meth <--OLD SETUP! FIRST TO MAKE BIG TURBO PCM BOOST CONTROL WORK ON DIABLO! For custom tuning, installs, and transmission rebuilds PM me! www.trudynosports.com
