Old 07-28-2007, 08:39 PM   #76 (permalink)
J-SRT4's Avatar
Member Number: 37428
Trader Rating: (44)
Quote: Originally Posted by aaronneon@RealTune
It has to make more then 440hp. I made 410 with NO ported exhaust or head, stock s3 o2 housing, full 2 1/2" exhaust, 2 1/2" cai and no race gas.
Come on now Walt.
At that point the turbo becomes the restriction.
I figured the exhaust side is a big restriction atleast on my setup. But maybe not. 440hp may be the limit.
The scroll area on the S3 is listed at 10cm2 which is about as big as it gets for that size turbo. A TD06HR wheel would be the upgrade but what kind of affect would remain to be seen. I'm not even sure they make a reverse rotation wheel that size?
It makes no sense to go any bigger of a wheel other than the 44lb. You can go 10s with this turbo. If you want to go faster....its time to step it up [plain and simple]
I say this whole statemant is very true!!! Any larger the the 44 and surge would be unbeliveable I get a good amout now!! 10's are very possible with this set up it gives you the topend that the stock S3 was missing
17-50mm 2.8
50mm 1.8
55-200mm VR
3 SB600's
And some other thangs
55-200mm VR is for sale, mint condition!!
J-SRT4 is offline   Reply With Quote
Old 07-29-2007, 02:01 AM   #77 (permalink)
SRToc Member
-ND4SPD-'s Avatar
Member Number: 458
Trader Rating: (30)
Nice number I wish I had a copy of the whitemtn graph to compare with.
I know nick tuned that car to 416whp/4XX wtq.
That car has headwork and cams, stock S3 turbo, dtec controlled all supporting mods.
I'm waiting for one of you guys to get the head crane 16 cam combo done
I bet your power curve is awesome J.
Ask and you shall receive
Holy mountain of torque!
John Ruckman
- Stage 3 W/ Toys
- AGP WGA, Race FMIC & 3" Intake
- Custom Magnaflow Exhaust & O2
- Eibach Prokit
- B-Woody Traction Bars
- ND Performance Traction Control System
See My Ride Here
Old 07-29-2007, 10:25 AM   #78 (permalink)
srad2drag's Avatar
Member Number: 30677
Trader Rating: (21)
This was alot back in the day huh?? It seems to be the norm now. Whtmtn was a pioneer though.
Bombastic
STG3r W/toys
srad2drag is offline   Reply With Quote
Old 07-29-2007, 12:40 PM   #79 (permalink)
ppx
Member Number: 39388
Trader Rating: (46)
jwcardy, yoursetup inspired me to do the same, im going to go s3 this year on my new acr. s3 with fm upgraded wheel with the dcr surge porting and hopefully fm will have a manifold for the s3 like they do for the e2 if they dont already. other wise ill get aarons. s3 for me now!!
drastic holdin it down for the deuce whatever the fuck, we ain't dead yet
ppx is online now   Reply With Quote
Old 07-29-2007, 12:58 PM   #80 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (27)
comparing whtmtn and the 44lb wheel, 44lb is making more tq towards redline and hp
JnR Performance=envied by many in norcal
Sponsored by DCR
for sale:
mopar cat delete 100 shipped obo
s2 w/toys pcm 300 shipped
iceman 60mm tb $150 obo shipped
s2 injectors 200shipped
reed32 is online now   Reply With Quote
Old 07-29-2007, 01:46 PM   #81 (permalink)
Member Number: 28960
Trader Rating: (21)
sounds awesome man...i hope to have some numbers for everyone really soon...
-wes
starting from scratch AGAIN....
jwcardy is offline   Reply With Quote
Old 07-30-2007, 11:01 PM   #82 (permalink)
Member Number: 39550
Trader Rating: (28)
made a few pulls today in 3rd and 4th, and boy does it pull hard!!!! im only boositng 20 psi for some reason, i have the dtec set to 28, but its not even getting close. shold be going to aaron shop to get a nice tune on it next week, hopefully i can put down at least 440
squishy332000 is offline   Reply With Quote
Old 08-08-2007, 07:37 PM   #83 (permalink)
Trader Rating: (28)
new dyno numbers tomorrow with the 44lb wheel and thec ooling mist stage 3 hom kit, being tuned by aaron at realtune!!!!!
Old 08-09-2007, 06:38 AM   #84 (permalink)
Member Number: 13063
Trader Rating: (18)
[quote=quicktalon11s]
Come on now Walt.
Sorry I should clarify, bigger turbine wheel.
A TD06 turbine wheel mated to a 49lb compressor wheel (50trim) would be very interesting
I will be recieving something from Forced Performance that I think is very close to what you stated above. Their new evogreen turbo's wheels in an S3 housing. Two things I'm not 100% sure on. They list 2 diff flow numbers for their billet compressor wheel. One area on their website they say 47lbs. a min and somewhere else it says 700cfm. I did the math and that calculates to 49lbs. a min. That and they don't say exactly what turbine wheel they use. Just how many blades it has and that it is larger in diameter than the stock one. I'll let everyone know how it does when I receive it.
It's a 47lb wheel. Highest dyno on an evo was 470 i believe.
GAngel is offline   Reply With Quote
Old 08-11-2007, 05:30 PM   #85 (permalink)
dj4monie's Avatar
Member Number: 977
Mods are:
stg3 w/toys
Injen catback and dp (I have the Thermal R&D combo w/cat)
Maxxfab 3inch o2 On My List
crane 14 cams I might get these or Crower I like your torque curve
unorthodox cam sprockets One My List
kinetic 60mm tb I have 55mm FBM unit for time being
ported intake manifold FBM version
JMB ultimate intake AEM CAI
Form & function ported and coated exhaust manifold On My List
DCR oil pump/windage tray and big filter kit Considering
SAFCII Neo version
AGP w/g Refuse to buy there products, look elsewhere
MPSC drag rotors 9lbs Interesting...
CM stg4 clutch and aluminum flywheel Between that at ACT
DCR oil modifier Considering
CTI hotside pipe. Did that help?
Send me a PM I'm still gathering part for install I believe in Sept.
I also got Samco's based on your review...
Now S3R Powered!
dj4monie is offline   Reply With Quote
Old 08-11-2007, 06:01 PM   #86 (permalink)
srad2drag's Avatar
Trader Rating: (21)
Dont forget about some sort of light weight wheels..Every little bit helps..
On a side note.....That combo looks strangely familiar though
Old 08-16-2007, 03:03 PM   #87 (permalink)
Trader Rating: (28)
new dyno sheet, from last week at realtune, i made 421whp on one pull, but this sheet looked a bit better, we were haivng trouble with hom as you can see i kicke dout around 5800rpm, 650cc injectors are being used next week along with some new plugs and a new intercooler, should see some better gains, plus cams wern't tuned, sitting at 0 0.
Old 08-16-2007, 03:07 PM   #88 (permalink)
aaronneon@RealTune's Avatar
Member Number: 623
Trader Rating: (391)
I think the new injectors and IC will make a very big difference in consistency
10.62@133.8 '05 SRT-4 Neon
11.87@125 '08 SRT-4 Caliber
Worlds Quickest/Fastest CSRT-4
Old 08-16-2007, 03:12 PM   #89 (permalink)
J-SRT4's Avatar
Trader Rating: (44)
Quote: Originally Posted by squishy332000
new dyno sheet, from last week at realtune, i made 421whp on one pull, but this sheet looked a bit better, we were haivng trouble with hom as you can see i kicke dout around 5800rpm, 6500cc injectors are being used next week along with some new plugs and a new intercooler, should see some better gains, plus cams wern't tuned, sitting at 0 0.
Nice sheet man, it looks like your not hitting full boost until 4k+??
Old 08-16-2007, 03:14 PM   #90 (permalink)
Member Number: 623
Sheet is ''Ok''. It will look much nicer later next week.
That might look that way on the dyno, but not in the real world. I slow the spool down on the dyno.
