Old 07-11-2009, 09:02 PM   #1156 (permalink)
2.4HEMI's Avatar
Member Number: 67328
boomba sts
05 black ACR
50 trim .63 and meth Turbo666 DSP Tuned
stock turbo 253 whp 292 wtq dynapac dyno
2.4HEMI is offline   Reply With Quote
Old 07-12-2009, 08:15 AM   #1157 (permalink)
TmP
TmP's Avatar
Member Number: 59394
Sounds like an alignment issue though.
If it doesn't go in and blocks, it's usually something with the shifter / cables.
If it grinds it's the syncs.
AGP D44
BFMIC / hard pipes / Greddy RS / custom CAI
195 whp / 190 wtq @ 9 psi
206 whp / 200 wtq @ 11.5 psi
230 whp / 225 wtq @ 12 psi + DSP 93 oct
300 whp / 325 wtq @ 22 psi + DSP turbo666 tune
Best Trap: 110.81 mph
Best ET: 13.6408 s
Best 60': 2.3027 s
TmP is offline   Reply With Quote
Old 07-12-2009, 12:26 PM   #1158 (permalink)
bribri's Avatar
Member Number: 33121
Trader Rating: (10)
i just adjusted my clutch pedal cause i couldnt push the clutch pedal to the floor without it rubbing the forks, first time i adjusted it i went to far and could barely shift gears...try adjusting the pedal out a little bit...cured my problem
bribri is offline   Reply With Quote
Old 07-12-2009, 08:15 PM   #1159 (permalink)
2.4HEMI's Avatar
ive already tried both of those cables and clutch adjustment, but i am going to do play with them again on my next day off, also i was reading a thread last night(very informative) and according to that being locked out is the sign of a bent shift fork which im leaning towards because i drove my car with a bad tob release fork for a while and even when i got the car at 35k it was hard to shift into second. i know its not a synchro, i know what thats like.
Old 07-12-2009, 08:45 PM   #1160 (permalink)
TmP
TmP's Avatar
Had a little tuning session today with my new tune (tune 8).
At first it ran 10.0 A/F as soon as I hit boost.
Played with the settings a little and got it to run 10.6 - 11.2 under boost.
Without logging A/F, that's as good as it's going to get, because staring at the gauge doing 90 mph through the woods ain't funny.
Once I have my cat less SEE on (should be here next week), I'll try some more again.
Not in a hurry right now. Once the new exhaust is here, I'll wire the Uego into the scan gauge and then I have a) accurate readings and b) a A/F log.
What I noticed too, is that under boost my timing seems to stay at 22.5.
I added as much as 4 degrees with the DSP, but that didn't change anything... WTF?
Always get 22.5, unless I get ST knock. Then it reduces it obviously. Didn't knock much with the latest adjustments I made though. Every now and then a 0.5 to 1.0 degrees at 5k.
As far as boost goes, I hit 21 psi at around 3.7 - 4 k, then it drops to 20, then up to 21 again, then falls from 5 to 6k to 17 psi. Will see if the Boost Box changes that. But I want to install it after the new exhaust and after I've played with it more.
Don't want to deal with the box right now, that would just add more ??? to the mix
Old 07-12-2009, 08:46 PM   #1161 (permalink)
conroy9940's Avatar
Member Number: 46401
Trader Rating: (114)
you should be getting full spool way faster than that..
Pittsburgh Penguins 15-8-0 28 points
Old 07-12-2009, 08:47 PM   #1162 (permalink)
bribri's Avatar
Trader Rating: (10)
be very careful when you add that boost box...it takes some getting used to...im on week 3 and i pretty much disabled it and manually configured the whole thing...it can be a big PIA but once you get it its really nice...
Old 07-12-2009, 08:51 PM   #1163 (permalink)
TmP
TmP's Avatar
@Conroy:
I can't seem to find a leak though...
@Bribri:
That's exactly why I want to wait! Got my head full with stuff at the moment anyways and too little time for the car. Having 2 project cars and being in the middle of renovating one house and buying another takes a little more time than I hoped
How much is the A/F of the DSP worth btw???
Shows 12.0 - 12.3 most of the time with my altered tune...
Boost: this pull starts at 2900 rpm. Full boost at 3750 - 21 psi
Drops to 18 at redline (6k)
Old 07-12-2009, 09:19 PM   #1164 (permalink)
Member Number: 65436
Trader Rating: (31)
I think im having the same problem with the full boost at late Rpms. I havent leak tested it yet but once its at full boost it holds good...Not sure whats going on lol. Still got the evap code but some people are saying they dont have any vac lines and dont have a code
cody187x is offline   Reply With Quote
Old 07-12-2009, 09:20 PM   #1165 (permalink)
conroy9940's Avatar
do a pull from 2000 rpms and let us know where full spool is.
Old 07-12-2009, 09:22 PM   #1166 (permalink)
TmP
TmP's Avatar
Think I did that today... let me see.
Old 07-12-2009, 09:23 PM   #1167 (permalink)
Trader Rating: (31)
Alright, i am doing them from 3k thats what turbo666 recommended. But say in a roll race and im at 3500k mine wont be full spool til later rpms
Old 07-12-2009, 09:26 PM   #1168 (permalink)
TmP
TmP's Avatar
Wot at 1860.
Full boost at 3700
Old 07-12-2009, 09:30 PM   #1169 (permalink)
conroy9940's Avatar
damn weird.. should be spooling faster...
Old 07-12-2009, 09:32 PM   #1170 (permalink)
TmP
TmP's Avatar
A) Spool: should be.... what?
B) What about the A/Fs of the DSP. How do they correlate to your WB??
Page generated in 0.21858 seconds with 13 queries
