Old 06-30-2009, 08:05 AM   #1066 (permalink)
TmP
TmP's Avatar
Member Number: 59394
I was just suprised HOW fast I broke it...
It's Mobile 1 and it's been in there for 2000 miles!
And on top of that, i poured in more then 2 quarts since the change.
Man, I hate this situation.
I want to know where my damn oil goes
AGP D44
BFMIC / hard pipes / Greddy RS / custom CAI
195 whp / 190 wtq @ 9 psi
206 whp / 200 wtq @ 11.5 psi
230 whp / 225 wtq @ 12 psi + DSP 93 oct
300 whp / 325 wtq @ 22 psi + DSP turbo666 tune
Best Trap: 110.81 mph
Best ET: 13.6408 s
Best 60': 2.3027 s
TmP is offline   Reply With Quote
Old 06-30-2009, 08:21 AM   #1067 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (92)
Quote: Originally Posted by 04blusrt_4 View Post
its normal, oil and gas are both from the same stuff, when the oil begins to breakdown, it can have a gas smell a little. I would recommend changing it soon.
Smelling fuel in your oil is not normal, and it's not good. You are washing away the oil's ability to protect the rotating assembly. Your turbo will be the first to begin showing wear, then your main and rod bearings will show wear and shortly thereafter will spin.
NHRA Pro Stock Motorcycle - Kenny Van Buren
Come see AGP Turbo at NHRA Full Throttle events.
Ben@AGP is offline   Reply With Quote
Old 06-30-2009, 09:08 AM   #1068 (permalink)
04blusrt_4's Avatar
Member Number: 60369
To me my oil smells like gas a tad all the time, but thats just probably my sensitive little nose...lol.
But yea, Tmp, it is probably from running so damn rich all the time, you are washing down the cylinders and getting gas into your oil. I am not sure why you are waiting for a reflash and not just adjusting the fuel DOWN on your diablo. You can probably get it pretty damn close to perfect without another reflash by taking 10-15% of fuel out.
And burning two quarts of oil is aweful, sounds like you may actually a leak somewhere, probably your return or feed line, unless you are seeing a lot of smoke out the back, which means youre burning oil.
*NE 400 Club*
Old 06-30-2009, 10:11 AM   #1069 (permalink)
TmP
TmP's Avatar
That's why I post allover here!
My problem is the following:
I go through a ton of oil and now the dip stick smells like gas.
What could be the cause?
- My car doesn't smoke.
That kind of rules out a leaking turbo, a blown headgasket and worn rings.
- My drive way is clean.
So I have no external leaks
- My compression was around 150 psi on all four.
According to the info I found, that's ok. Another reason to believe my rings are ok.
- My catch can is not filling quickly.
I just put that on a couple of miles ago, but it doesn't seem to fill like cracy.
I also replaced the pcv valve.
- My AFRs are leaner now. 14.8 cruise, 11.2 - 12.2 under WOT
I WAS running pig rich until recently though...
With the lean tune I haven't even run a whole tank of gas yet.
So, maybe I was running so damn rich, that I was washing my cylinders and burning the oil.
Now that the car is running leaner, it's ok, but I don't have enough miles on it yet to see the improvement...
One thing I'm afraid of:
What if one of my injecors is bad???
What if I'm flodding one cylinder while the others are lean?
I'm gonna do an oil change this weekend and see if it looks better from now on (with the leaner tune).
Old 06-30-2009, 10:36 AM   #1070 (permalink)
Member Number: 65436
Trader Rating: (31)
I still have to talk to turbo666 about whats going on with my part throttle. Im gonna try resetting the fuel trims but i doubt those would be causing the roughness...It gets all jerky and stumbling...Its making me want to sell the car
cody187x is online now   Reply With Quote
Old 06-30-2009, 11:18 AM   #1071 (permalink)
TmP
TmP's Avatar
AFRs?
Mine did that too when I was running REALLY rich.
(Which might have caused all my oil issues...)
Old 06-30-2009, 11:50 AM   #1072 (permalink)
SRT of the Month
1sikACR's Avatar
Member Number: 60564
you and TMP need to take your cars somewhere to get tuned, these mail tunes aren't workin for you IMO
AGP D48, AGP RL, 725's, SBC S3RS non-mod, AEM FIC, AEM SRI, DCR 55mm TB, Spearco BFMIC, 2 Greddy CC's & type-s BOV, STS, Maxx Fab SEE, Walbro 255, WOT box w/2step, much much more...
Tuned by Realtune 421whp 442wtq
http://www.youtube.com/watch?v=Awz9OkDRk0g
11.54@120
1sikACR is offline   Reply With Quote
Old 06-30-2009, 11:55 AM   #1073 (permalink)
TmP
TmP's Avatar
I hate to admit it... but I'm getting to the point were I think you are right.
I'll see what happens after the oil change.
If the oil consumption goes down I'll stick with what I'm doing, if there's still fiunky stuff going on I'll have to find some other solution.
@ACR:
How come you're just making mid 300s with all your mods???
Old 06-30-2009, 12:52 PM   #1074 (permalink)
Trader Rating: (31)
Well the jerking and stumbling is happening when i let off the gas and try to ease back into it...for example rolling through a yield sign or something....its bad man...if this dont get fixed through the email tunes im gonna be pretty mad that i spent 200 dollars on that....IM NOT SAYING THE TUNES ARENT GOOD, but Nigel told me part throttle is hardest part to tune through email.
Old 06-30-2009, 12:54 PM   #1075 (permalink)
TmP
TmP's Avatar
I only had that with the first tune.
When it stumbles, what AFRs do you get?
Old 06-30-2009, 01:00 PM   #1076 (permalink)
bribri's Avatar
Member Number: 33121
Trader Rating: (10)
Quote: Originally Posted by TmP View Post
@ACR:
Cause the car runs right probably haha!
bribri is offline   Reply With Quote
Old 06-30-2009, 01:04 PM   #1077 (permalink)
TmP
TmP's Avatar
Um, I ment it's still low.
I know my car has it's issues and I'm not going to heat up the 400 hp debate again
Just curious.
Old 06-30-2009, 02:38 PM   #1078 (permalink)
harvboi05's Avatar
Member Number: 30703
are you running a fuel return line? what fuel pressure do you have your regulator set to? what are your long and short term fuel trims?
my car bucks if i run any lower than 55psi of fuel pressure, and also my transient fuel response sucks if my trims are not ideal. and then there is a combination of the two as well.
agp S3D 48 kit. 12.37@118.7 and 12.54@122.4.
^^car for sale!
http://www.srtforums.com/forums/f165...ate-ny-521715/
fwd = bad.
new addition: 98 cobra
harvboi05 is offline   Reply With Quote
Old 06-30-2009, 03:08 PM   #1079 (permalink)
Trader Rating: (31)
When it stumbles afr's will go into the 12's 13's as i let off the gas then the display will be (---) on the wideband lol.
Old 06-30-2009, 03:29 PM   #1080 (permalink)
harvboi05's Avatar
thats normal, when you let of the gas it should swing rich for a split second then go back lean. it shouldnt stay there tho, should shoot right back to high 14s when you resume cruising.
what about your fuel trims and return line and fuel pressure?
Page generated in 0.25530 seconds with 13 queries
