Old 06-29-2009, 12:06 PM   #1051 (permalink)
bribri's Avatar
Member Number: 33121
Trader Rating: (10)
Well i just got my Delta 55 in along with a DSP, 750cc injectors and a N2MB boost box...i only have it set a 13psi right now in all the gears but everythings working great...i should have dyno numbers in the next few weeks once i get the car tuned.
This turbo sounds great btw and ive noticed im at 85 miles to this tank and im at around 7/8 tank left on the gauge. Typically id be at around 35-60 at this point! More power and better gas mileage makes things even better!
bribri is offline   Reply With Quote
Old 06-29-2009, 12:08 PM   #1052 (permalink)
Member Number: 67038
fuck my life. i looked at the bc again. had t on backwards!!!!!!lol i went out and it hit 20 pounds and your never gunna believe it but the clutch held!!!!! only for a split second but it did. lol
Delta 55 Turbo kit, agp catch can, agp solid motor mounts,scangauge and wideband, 3 bar map and tip, Injen Sri, Jmb with hks, stage 1, exhaust depot custom undercar dump, grantelli wires,DW 750's, walbro. rescale by turbo 666
AllBoost is offline   Reply With Quote
Old 06-29-2009, 12:25 PM   #1053 (permalink)
TmP
TmP's Avatar
Member Number: 59394
My clutch seems fine for now too.
AGP D44
BFMIC / hard pipes / Greddy RS / custom CAI
195 whp / 190 wtq @ 9 psi
206 whp / 200 wtq @ 11.5 psi
230 whp / 225 wtq @ 12 psi + DSP 93 oct
300 whp / 325 wtq @ 22 psi + DSP turbo666 tune
Best Trap: 110.81 mph
Best ET: 13.6408 s
Best 60': 2.3027 s
TmP is offline   Reply With Quote
Old 06-29-2009, 12:33 PM   #1054 (permalink)
Member Number: 65436
Trader Rating: (31)
So does mine....
for now
cody187x is offline   Reply With Quote
Old 06-29-2009, 12:49 PM   #1055 (permalink)
TmP
TmP's Avatar
On street tires with moderate use I don't think you're going to kill it all that fast.
You're just lighting up the tires anyways
Old 06-29-2009, 12:50 PM   #1056 (permalink)
Trader Rating: (31)
I know, and i only do 3rd/4th gear pulls
Old 06-29-2009, 12:55 PM   #1057 (permalink)
ok well the car has a horrible tune on it right now. 17 pounds and its pulling like a mofo. prolly around 350 or so horsepower if i were to guess. its like 10.4 at redline and 33 degrees of timing with 0 knock retard. i know as soon as i lean it out it will knock so i will be pulling timing shortly. but it still has more in it thats for sure. i will be tuning it tonight as much as i can. get a few logs and post them up for everyone to see. can i log rpm by any chance havent really messed with out data logging alot yet. i wanna log rpm, boost, spark, all the kinda of knock, and idc on the scangauge. im already pulling 15 percent fuel up top so i will def lean her out and take away some timing and see how hard she pulls.
Old 06-29-2009, 12:57 PM   #1058 (permalink)
Trader Rating: (31)
What are you tuning with? My normal driving is weird with my diablo tunes...Like when i let off the gas it stumbles if i try to ease back into the gas....
Old 06-29-2009, 12:58 PM   #1059 (permalink)
diablo just like you guys. lol i just havent did much datalogging cause i havent had all the parts needed. lol
Old 06-29-2009, 01:03 PM   #1060 (permalink)
Trader Rating: (31)
Yeah im on my 6th tune, during WOT the tune is fine, but part throttle its stumbling and jerking and everything else
Old 06-29-2009, 01:12 PM   #1061 (permalink)
send me your log file for just normal driving. maybe running to much timing or somethine. just log spark, avg map to use, baro, and the kinda of knock. i will check it out and see whats up.
Old 06-29-2009, 01:40 PM   #1062 (permalink)
TmP
TmP's Avatar
My car runs like stock.
0 issues when DDing it.
I get 22 deg of timing, 22 psi and some knock.
Old 06-29-2009, 01:44 PM   #1063 (permalink)
2.4HEMI's Avatar
Member Number: 67328
cody187X its probably just a fuel trim issue did you reset the pcm by disconnecting the battery for about ten mins when you uploaded your latest tune. That will reset the fuel trims.
05 black ACR
50 trim .63 and meth Turbo666 DSP Tuned
stock turbo 253 whp 292 wtq dynapac dyno
2.4HEMI is offline   Reply With Quote
Old 06-29-2009, 09:13 PM   #1064 (permalink)
TmP
TmP's Avatar
My dip stick smells like gas.
What do you guys think, just running to rich, or shot rings?
Old 06-30-2009, 07:09 AM   #1065 (permalink)
04blusrt_4's Avatar
Member Number: 60369
its normal, oil and gas are both from the same stuff, when the oil begins to breakdown, it can have a gas smell a little. I would recommend changing it soon.
*NE 400 Club*
Page generated in 0.22296 seconds with 13 queries
