WTF.... I put mine back on PCM boost. Runs like a champ. spikes 23 and holds it to redline. Im not adding any boost on the handheld ether. AFR's are in the low 11's 1.5 counts of knock in this heat.
Did you get your tune from Turbo666? If so, he has it figured out how to run external wga on pcm control, probably has it in your tune.
no they just rescaled my new injectors really My actual tune came from Rage-tek. And works great so far but like I said I have not tried to increase the boost nor decrease it yet. But its right where it needs to be for my everyday driving. Im sooo driving it on vacation like this lol
I have got a thread up in the DSP section with my somewhat log of it. It looks alot smooter I think. Long as it adjusts itself to weather and does the limit boost under 30mph thing that it likes to do I will keep it this way I think
LOL, its an excel version of the log, should be in your choices to export. You dont need to have excel, but should still be able to save it out. Dont need a graph, i want the detailed export.
Again, I'm not throwing the towel anywhere
And furthermore, I'm totally ok with my turbo.
Nevermind. I seem to have rubbed you the wrong way I guess.
I'll keep on working on the car, maybe I'll take it to test and tune friday to get some more logs...
We'll see.
Yea I know.. But mine is doing fine (so far) Like I said I have not adjusted the boost yet. But its a solid 22-23psi right outta the box. which is fine for me. Maybe these delta kits can run on PCM boost just not the bigger dogs like the fifty trims.
got nothin....I need tho a log of wastegate duty cycle, rpm, avg bar, baro pressure, pressure ratio.
If you could give me that, I would love you!!
I had everything on it but the WGDC... I dont have the PID selected but will do next time I go out. I sent it maybe it just didnt go through yet ill try again
