Old 06-25-2009, 06:55 AM   #1006 (permalink)
TmP
TmP's Avatar
Member Number: 59394
Talkin the rochester track I assume?
Actually, starting tonight my wife is gone for 3 weeks...
So yeah, I might. It's test and tune, right? Not bracket racing I hope.
Don't have my boost box yet, so I can't hold boost.
Not sure if it makes sense to drive that far for another couple of 110 mph runs
Then again, it'd be sweet for data logging...
I'll make up my mind 'till tomorrow.
AGP D44
BFMIC / hard pipes / Greddy RS / custom CAI
195 whp / 190 wtq @ 9 psi
206 whp / 200 wtq @ 11.5 psi
230 whp / 225 wtq @ 12 psi + DSP 93 oct
300 whp / 325 wtq @ 22 psi + DSP turbo666 tune
Best Trap: 110.81 mph
Best ET: 13.6408 s
Best 60': 2.3027 s
TmP is offline   Reply With Quote
Old 06-25-2009, 07:04 AM   #1007 (permalink)
04blusrt_4's Avatar
Member Number: 60369
Quote: Originally Posted by AllBoost View Post
ok well i found i had a coolant leak from the bottom of the radiator had to drain it and fix the leak from the gay ass clamp because it cut the hose and i put on a new clamp and i dont think it is leaking. i hope not. also finally went WOT. 120 miles on the turbo so its practically broke in. a/fs went from 14.7 crusing to 11.3 around 4k and to about 10.4 around 6k or so. thing is im only getting around 12 pounds on the 14 pounds spring. i think the charge pipe is a little off the turbo outlet so i will cheak that tomorrow. car didnt even spin second, or even try. 0 knock by the way. gunna put more miles on tomorrow and start tunning and data logging. fixed my O2 sensor, one of the wires up came unsoldered and i pput it back together and code went away. perfect. i think i have a huge boost leak at the turbo so i def wanna se if that is where my huge loss in boost is
Yea, my charge pipe still might be leaking, but you should have around 15psi with the 14psi spring. I had to remove the charge pipe and play with it to get it to seal up nicely.
This turbo wont wake up until 20-22psi, at 15psi mine felt like an absolute dog, LOL. Youre MBC is on its way my friend
*NE 400 Club*
Old 06-25-2009, 07:45 AM   #1008 (permalink)
Member Number: 67038
ya i wanna se this beast with some more boost. i have the diablo zeroed out and its hitting very close to 10.0 at redline so i have more fuel in the setup.
Delta 55 Turbo kit, agp catch can, agp solid motor mounts,scangauge and wideband, 3 bar map and tip, Injen Sri, Jmb with hks, stage 1, exhaust depot custom undercar dump, grantelli wires,DW 750's, walbro. rescale by turbo 666
AllBoost is offline   Reply With Quote
Old 06-25-2009, 07:53 AM   #1009 (permalink)
04blusrt_4's Avatar
With 750s u should be able to get to around 21-22psi. A 50trim runs out right around 23psi without a returnline at 58psi.
Old 06-25-2009, 08:30 AM   #1010 (permalink)
ya i forgot to tell ou guys this. everyone who drives my car says my transmission is like butter and that they cant believe how smooth it s for a srt. well when i ways doing my turb kit and i took off the charge pipe. there is a seal that is put on there by a performance company that does transmissions in miami. im hoping there was some work done.
Old 06-25-2009, 09:07 AM   #1011 (permalink)
CJsStocker's Avatar
Member Number: 58783
Trader Rating: (39)
did you ever check for boost leaks? or even an exhaust leak?
CJsStocker is offline   Reply With Quote
Old 06-25-2009, 09:09 AM   #1012 (permalink)
TmP
TmP's Avatar
Did check for boost leaks.
All I could find was the temp sensor.
Reclamped everything, did this, did that.
Haven't really driven, raced or logged the car since.
Old 06-25-2009, 09:11 AM   #1013 (permalink)
CJsStocker's Avatar
Trader Rating: (39)
start up the car when its cold and feel around the exhaust gaskets to see if there is a leak.
Old 06-25-2009, 09:22 AM   #1014 (permalink)
TmP
TmP's Avatar
Why would that hurt btw?
More flow should be better I thought
Old 06-25-2009, 09:27 AM   #1015 (permalink)
BoostingSnail's Avatar
Member Number: 27440
Trader Rating: (24)
I hate to say it...but Im about to unsubscribe from this thread....it's full of people going blah, blah, blah....and then someone responds with blah, blah, blah
GET VegasFuel AT AGP AGP TURBO!!!
11.75@124.93 - 110 Oct. 26psi on slicks
AGP S3D 47lb-AGP 38mm Gate-750cc Inj.-255 Walbro-SCT Flash-3" MPx dual exit w/ catless downpipe-AGP BMIC w/ Slowboy Crashbar-ACT Xtreme Clutch-Tial BOV-AEM Cold Air-MSD Wires-180* Thermostat-Solid Motor&Trans Mounts-AGP Billet Selector-Ksport Coilovers-Koyo Radiator-AEM Wideband-Aeroforce Interceptor- N2MB 2-step/WOT Box
BoostingSnail is online now   Reply With Quote
Old 06-25-2009, 09:36 AM   #1016 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (92)
-Realtune 725cc
-3bars
-Godspeed BFMIC
-DSP tuned by Aaron Lail
-3" DP -> 2.5" exhaust (Interim solution until Maxxfab is back in business)
-MBC
-9 psi spring (stays there, as my Boost box is going on the car ASAP)
What else do I need?
OK, I can see two things on there that are going to be holding you back. I don't know if you posted dyno graphs in here earlier, but I don't have the time to go back to them. Can you repost, or email them to me?
NHRA Pro Stock Motorcycle - Kenny Van Buren
Come see AGP Turbo at NHRA Full Throttle events.
Ben@AGP is offline   Reply With Quote
Old 06-25-2009, 09:42 AM   #1017 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (92)
Jup.
To be honest, it looks more and more as if my doubt about this turbos power are justified...
Your doubt about what being justified? It's a 440whp turbo all in. Running it at less boost, on pump gas, without supporting mods, and without "perfect" as you call your setup, and you're mad?
If I were you, I wouldn't throw in the towel until you get your car to the "perfect" level. This turbo is an animal, guaranteed. You just need to give it all the support to make it shine.
Old 06-25-2009, 10:30 AM   #1018 (permalink)
Kason23's Avatar
Member Number: 34502
Trader Rating: (20)
WTF.... I put mine back on PCM boost. Runs like a champ. spikes 23 and holds it to redline. Im not adding any boost on the handheld ether. AFR's are in the low 11's 1.5 counts of knock in this heat.
Tuned By TDSAaron!!
My Goal: 100+Mph in the 1/8
Old 06-25-2009, 10:34 AM   #1019 (permalink)
Member Number: 65436
Trader Rating: (31)
Niceeeee. Im still trying to find where this evap code is coming from
cody187x is offline   Reply With Quote
Old 06-25-2009, 10:37 AM   #1020 (permalink)
Kason23's Avatar
Trader Rating: (20)
Its weird I was told this would not work? But seems to be fine so far... If I can actually add boost thru the handheld.. Its gonna be awesome no more MBC shit for me lol
Page generated in 0.23719 seconds with 13 queries
