Old 10-05-2009, 07:24 PM   #1501 (permalink)
SonnySrt-4's Avatar
Member Number: 34315
Trader Rating: (10)
Quote: Originally Posted by tweekssrt4 View Post
The stock clutch is coming up on 56K miles and of that probably 12K miles of it was with the turbo on it. I figured it didn't slip at the track on 25psi and it's either going hold up or die on the dyno.
What did you run and what was the trap speed?
Edited by Inzanesrt4
Agp s3d-44lb turbo kit
38mm TurboSmart Wga
3inch bdj's catless down pipe dumped exhaust
BFMIC
N2MB Boost box (GET ONE!!!)
D/O Meth/Alchy injection m5
DSP tuner
800cc injectors
HKS bov and hard pipe
SonnySrt-4 is offline   Reply With Quote
Old 10-05-2009, 10:45 PM   #1502 (permalink)
tweekssrt4's Avatar
Member Number: 30272
The best I could do spinning the tires was a 13.0@113mph. My 60' times were 2.3 & 2.4's.
-2004 SRT-4 E-Blue
Project Tweeked - AGP Delta 44
408hp/470tq @27psi on 110
tweekssrt4 is offline   Reply With Quote
Old 10-06-2009, 01:38 AM   #1503 (permalink)
bene's Avatar
Member Number: 53801
Trader Rating: (40)
you made 470 tq at 27 psi?
im loving the tq numbers with this turbo, im interested in seeing where the big jump in the torque is. seems to be somewhere right around 24 psi
bene is online now   Reply With Quote
Old 10-06-2009, 03:04 AM   #1504 (permalink)
soulinthewall77's Avatar
Member Number: 62365
Does anyone have any dyno-numbers on the AGP Delta 40? 'Cause that's what I got, and I'd like to hear some of the better results people have gotten. I'm floating around 300tq/300whp, based on dynos taken a year ago. I know, I know--it's not that great. But, lots of fine-tuning needs to get done--for which I don't currently have the funds--soon, however, I'm hoping to hit 330ish/330ish, or more? We'll see...
I think one day, Roscoe was really hungry, he looked in the freezer, and all he could find was leftover chicken, and frozen waffles. The rest is history...
soulinthewall77 is offline   Reply With Quote
Old 10-06-2009, 12:35 PM   #1505 (permalink)
Kason23's Avatar
Member Number: 34502
Trader Rating: (20)
yea 25psi I made 445wtq while 27psi I made 473. also 23psi and pump gas made 416
Tuned By TDSAaron!!
My Goal: 100+Mph in the 1/8
Old 10-06-2009, 03:54 PM   #1506 (permalink)
bene's Avatar
Trader Rating: (40)
so looks like 24+ is the number to shoot for
Old 10-06-2009, 04:07 PM   #1507 (permalink)
04blusrt_4's Avatar
Member Number: 60369
not right...you shoot for the highest boost with the highest return of boost versus torque increase (this indicates you are still in the efficiency range).
23psi to 25psi (2psi increase) - saw an increase of 29wtq or about 14.5ft/lbs per psi increase.
25psi to 27psi (2 psi increase) - saw an increase of 28wtq or about 14.0 ft/lbs per psi increase.
To me, that turbo is still singing along at 27psi and making good efficient power. I would shoot for around 27 or 28.
*NE 400 Club*
04blusrt_4 is online now   Reply With Quote
Old 10-06-2009, 04:21 PM   #1508 (permalink)
bene's Avatar
Trader Rating: (40)
ya, i plan to shoot for 28 psi one day.
i was meaning youll see the best results out of this turbo at 24+
of course the best result will be max psi.
Old 10-06-2009, 05:10 PM   #1509 (permalink)
Kason23's Avatar
Trader Rating: (20)
Yea im sure it might make more over 27psi. But it is limited somewhat being only a 44lb wheel and all. I say somewhere around 27/28/29psi is the max
Old 10-06-2009, 07:39 PM   #1510 (permalink)
Member Number: 67038
ya you guys are really making that turbo sing. i think it actually has more in it thought by the way the torque has increased with such a small psi change. thats actually excellent. i would say that 25-27 really is starting to see this turbo show its teeth. i bet you could rip a 11 second pass with 473 torque. torque wins drag races. not horsepower. the only thing i would worry about is kasons problem of trying to hold boost. i cant wait till i have enough money for a clutch.
Delta 55 Turbo kit, agp catch can, agp solid motor mounts,scangauge and wideband, 3 bar map and tip, Injen Sri, Jmb with hks, stage 1, exhaust depot custom undercar dump, grantelli wires,DW 750's, walbro. rescale by turbo 666
AllBoost is offline   Reply With Quote
Old 10-06-2009, 07:50 PM   #1511 (permalink)
2.4HEMI's Avatar
Member Number: 67328
i have the same boost drop issue as kason, right now im running 28-29 psi with meth and still getting tunes from nigel. He told me to leave the boost where it was at when i asked him if he wanted me to make any changes to it.
05 black ACR
50 trim .63 and meth Turbo666 DSP Tuned
stock turbo 253 whp 292 wtq dynapac dyno
2.4HEMI is offline   Reply With Quote
Old 10-06-2009, 07:51 PM   #1512 (permalink)
dammit i want to turn the boost up on my car so bad. lol i need a clutch and bottom end.......i need to hit the lotto.
Old 10-06-2009, 08:01 PM   #1513 (permalink)
Kason23's Avatar
Trader Rating: (20)
so falling to about 24psi...ish?
Old 10-06-2009, 08:28 PM   #1514 (permalink)
2.4HEMI's Avatar
yea 25-24ish, my timing seems pretty low but im sure nigel knows what hes doing, timing is 23ish at redline and 20-22 throughout the rpms.
Old 10-06-2009, 08:49 PM   #1515 (permalink)
Kason23's Avatar
Trader Rating: (20)
Oh he does. They know how to tune the DSP well. Aaron did mine. Once your timing starts going up you will only be able to get so much psi outta it. Hence why I cant go above 27psi and 29* of timing on 100% heet. Im sure I could get a little more on PURE meth
Page generated in 0.21247 seconds with 13 queries
