Old 07-19-2008, 04:54 PM   #271 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (42)
No more dyno for me this sunday!!!!!!!!!!!!
Went to the track yesterday and wore out my stock clutch pretty badly. Im sure I can do 3 pulls on the dyno but its not even street tuned to where I want it after I did a few more things to it.
At the track, I couldnt shift into gear 2 through 4 AT ALL........I need the money to install my clutch.
I would do it myself but Im scared of all the horror stories about problems with clutches and dont wanna mess up my daily driver. So I might dish out the $500 for installing the clutch.............
FS: HID Fogs Kit - 6000K & 3000K(Yellow) - PM Me
Performance Mods: AGP S3D 48lb - Returnline - Mopar Stage 2 w/o Toys - DW 650cc - TurboXS HPMBC - Maddog STS - MaxxFab 3" DP w/o Cat Magnaflow Muffler - AIS Intercooler - ED LPP - ED UPP w/ HKS BOV - Injen Intake - NGK V-Powers @ .032 - FBM Ported Intake Mani/Spacer - DCR 55mm Throttle Body - DCR Oil Mod - Devils Own MethInjection, M5 - DTEC - AEM UEGO
385HP and 385TQ
Gmanigio is offline   Reply With Quote
Old 07-23-2008, 10:37 AM   #272 (permalink)
addictedtosin's Avatar
Member Number: 30537
Trader Rating: (114)
Quote: Originally Posted by Gmanigio View Post
4306 @ .030 - I like $2 plugs
x2. As long as their gapped properly they work perfect.
Quote: Originally Posted by tweekssrt4 View Post
Any suggests on what pcm would be better on a 44lb wheel complete kit? I'm running a S1 right now but still have my stock one and just wasn't sure what would work the best.
stick with your stage 1. It is a proven PCM that works very well with tuning. Stage 0 works very well but the cel codes you get can be annoying. I have a reflashed B*G stage 0 but If I didnt have that I would have bought a stage one.
12.0@120 on DRs and 93oct.
addictedtosin is offline   Reply With Quote
Old 07-23-2008, 12:44 PM   #273 (permalink)
BoostingSnail's Avatar
Member Number: 27440
Im getting ready to install this kit and I went ahead and swapped out my stage 1 ecu for my stage 0. Im installing an AEM wideband also and I was going to place the wideband O2 sensor in the downstream O2 sensor location in a catless downpipe. Will I get a CEL for that even if i have the downstream O2 plugged in but tied up out of the way on the stage 0 ecu?
Naylor Racing<---Check Us Out! AGP TURBO!!!
AGP Stage 3 Complete Delta 47lb(beta tester)Kit-AGP 38mm Wastegate-750cc Inj.-255 Walbro-SCT Flash-3" MPx dual exit w/ catless downpipe-AGP standard intercooler/ Slowboy Racing Crashbar-Tial BOV-AEM Cold Air-MSD Wires-180* Thermostat-Solid Motor&Trans Mounts-Koyo Radiator-AEM Wideband-Aeroforce Interceptor
Coilovers, 26x8 Hoosiers, & Clutch coming soon!!
BoostingSnail is offline   Reply With Quote
Old 07-23-2008, 03:08 PM   #274 (permalink)
Member Number: 9221
Trader Rating: (18)
Yes........
GO FAST PARTS
Stage 1
FM E1 turbo
FM WGA
Dtec FC
AGP returnline
PTP 55mm TB
PTP check valve
ED hardpipes w/ HKS BOV
Maddog STS 72%
AGP motor mounts
Zeitronix ZT2 wideband
NGK v power plugs .040
8.5 MSD wires
Needswings DP (no cat)
Quickwhips direct fit FMIC
180 thermostat
Bwoody H-brace combo
Bwoody Trans mount
AnotherNeon is offline   Reply With Quote
Old 07-23-2008, 04:46 PM   #275 (permalink)
Quote: Originally Posted by AnotherNeon View Post
Yes........
AH! Crap...S1 back in it is
Old 07-23-2008, 04:53 PM   #276 (permalink)
OH5SRT4's Avatar
Member Number: 21866
Trader Rating: (19)
No I don't think so because you're gonna be running the SCT...someone else chime in for him.
2005 Black SRT-4
Mods: 3" O2 housing/Maxxfab DP, Mopar Catback, CCA FMIC, AGP CAI, BWoody Tranny/Motor Mounts, Hotchkis Springs, HKS BOV, Kinetic WGA, Mopar STS, AEM Wideband, PTP Check Valve, JMB Catch Can, 180 T-Stat, MSD Wires, CF OEM Hood, Black Housing Headlights
XBL Gamertag: The Hammerman37
OH5SRT4 is offline   Reply With Quote
Old 07-23-2008, 05:24 PM   #277 (permalink)
Double J's Avatar
Member Number: 25570
Trader Rating: (19)
I'm running mine on a stage 3 pcm. With pcm controlled boost. It runs awesome now with the 14lb spring in the wg. Quick spool up to 23 psi on dab 3.
AGP S3D /40 lb. wheel- Mopar Stage 3 W/Toys- Maxxfab/borla exhaust w/cat- Mopar STS- Exhaust Depot ic pipes w/ HKS ssq bov- AGP CAI - MSD wires-MM Inserts- PTP Check Valve- PTP 55mm TB- CCA FMIC- Slowboy crashbar- Megan Racing CO's- Hotchkis Swaybars- ACT Clutch/Flywheel
Double J is offline   Reply With Quote
Old 07-23-2008, 05:25 PM   #278 (permalink)
tweekssrt4's Avatar
Member Number: 30272
Good question, since I'm running a S1 pcm also and just got my kit in the mail today but will be awhile until I get it installed.
-2004 SRT-4 E-Blue
AGP S3D 44lb wheel w/SCT Flash, Turbonetics BC, Boomba Fuel Rail, NDE TCS, MPx 3" Catless Turboback, PnP IM, MPx 62mm TB, Darksyde Valve Cover, MPx FMIC, Mopar wires, AGP Hardpipes w/Greddy Type S, Maddog 72% STS, JMB CAI, Bwoody Solid MM & Tranny Mounts, AEM Wideband & Dual Aero Force Scan gauges
Coming Soon - SB Stage 3 Clutch & DCR Oil Mod
tweekssrt4 is offline   Reply With Quote
Old 07-23-2008, 11:37 PM   #279 (permalink)
Kason23's Avatar
Member Number: 34502
Trader Rating: (15)
Agp can turn that code off for you with there flash. Its the next thing on my list i need a race gas tune with it
AGP 44LB kit...382whp/416wtq
on 22psi and pump!
Old 07-26-2008, 12:30 AM   #280 (permalink)
soulinthewall77's Avatar
Member Number: 62365
yea', I spent the last two weeks (on and off, with one intense weekend to start things off) installing my Stage 3 Delta Complete, troubleshooting, working out kinks, fixing mistakes, a mishap here and there, etc.
The kit itself seems pretty stellar; it's just my mechanic-skills (or lack thereof) that left much to be desired.
Anyway, once I'm certain that everything is in proper working order, I'll probably take the car to Modacar (Livermore • CA), to get it dynoed.
Oh, the setup:
Stage 3 Delta Complete w/ 40lb. wheel; SRI; 3"catted dp; 2.5" borla/mopar cat-back; JMP-UPP w/ Greddy Type RS'; and some other stuff that probably won't have much bearing on dyno' results...
...whoever Roscoe was, he was a genius.
AGP S3 Delta Complete • Megan Racing Street Coilovers • Maxxfab 3" catted downpipe • Mopar|Borla cat-back • AEM Short Ram • Possibly some other stuff I might be forgetting • Really awesome billet shift-knob by MPx • Custom Stage 5 70-trim cupholders
soulinthewall77 is offline   Reply With Quote
Old 07-26-2008, 12:37 AM   #281 (permalink)
Member Number: 64760
Trader Rating: (17)
shouldve at minimum, gotten the 44lb...
91PumpKing. is offline   Reply With Quote
Old 07-28-2008, 02:43 PM   #282 (permalink)
Member Number: 43609
hey guys, so i just finished reading all 18 pages on here. lol. I am interested in going with the S3D kit, but not the complete kit. My mods are: 3" JMB SEE (stock O2 housing), JMB Ultimate Intake, Stage 2 Injectors, AGP Wastegate, Stage 1 computer, Mapclamp, stock sensors.
So, What all do i need to complete this kit? I know i will be selling the AGP and Also will probably have to get rid of the injectors and pick up some 650's. I will also need UPP and BOV, and 3" O2 housing
What else do I need to complete this kit?
Thanks for the help
fests-srt is offline   Reply With Quote
Old 07-28-2008, 03:12 PM   #283 (permalink)
Member Number: 9221
Trader Rating: (18)
Thanks for the help
You do not need an 02 since it comes with one. As far as injectors the S2 and a returnline will work
Old 07-28-2008, 09:18 PM   #284 (permalink)
Kason23's Avatar
Trader Rating: (15)
yea hes the one who convinced me to get the 44lb over the 40
Old 07-28-2008, 09:48 PM   #285 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (42)
Could not agree more.
I recommend 48lb cuz its what I got and its what I love. Perfect turbo for the street.
