Quote: Originally Posted by
2005sxt24
well i just did a compression test, and i got horrible numbers. one cylinder was as low as 60 and the other three were right around 100. I put a little oil in each cylinder and that raised the compression to around 140ish, this would indicate i have bad rings correct?
On a running engine, yes but it depends how long your engine was sitting. If the cylinders were just dry/dusty/rusty from sitting for months, the comp test will show that, but it doesn't neccesarily mean you need new rings.
Adding oil should only have a temporary effect at improving the ring seal if the rings are actually worn out. Retest the engine in a day or two. If the numbers still look consistant, you're good.
