Old 10-04-2009, 01:34 AM   #1 (permalink)
Member Number: 70446
Default Spooling Problem
Hi,
ATP 3071r with14PSI Spring /DW750s/3“Exhaust/4“intake
If I am on PCM controlled boost with 14 PSI spring, the turbo spooling later than if the PCM-boostcontroll is off and only 14 Psi spring is on ?!?
BUT WHY??? Is it possible that the wastegate duty cycle start to early?
PT Christoph is offline   Reply With Quote
Old 10-04-2009, 01:44 AM   #2 (permalink)
conroy9940's Avatar
Member Number: 46401
Trader Rating: (114)
why are you on pcm controlled boost with a big turbo? take it off.
Pittsburgh Penguins 16-8-0 32 points
Old 10-04-2009, 01:47 AM   #3 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
you need a boost controller with a ball and spring and there is no reason you should not be boosting 20psi
AGP S256 FS
Old 10-04-2009, 02:05 AM   #4 (permalink)
Would be a 20PSI spring also possible for dailydriving?
I do not understand why it spooling later?
Old 10-04-2009, 02:12 AM   #5 (permalink)
lyncoo's Avatar
Trader Rating: (92)
super rich at spool up and a mbc will help spool a little quicker too
Old 10-04-2009, 02:13 AM   #6 (permalink)
lyncoo's Avatar
Trader Rating: (92)
just putting a heaver spring wouldnt help spool up. a mbc will do wonders. pm sent
Old 10-04-2009, 02:16 AM   #7 (permalink)
lyncoo's Avatar
Trader Rating: (92)
ok sent you a pm with a good boost controller to get and leave the 14psi spring in your wga and add a mbc to turn your boost up
Old 10-04-2009, 02:24 AM   #8 (permalink)
ok thanks a lot.
But why start the turbo spooling earlier with the same wga spring? Only diffence was pcm controll on and off ???
Old 10-04-2009, 02:27 AM   #9 (permalink)
lyncoo's Avatar
Trader Rating: (92)
pcm control kinda works like a boost controller
Old 10-04-2009, 03:11 AM   #10 (permalink)
Yes I think same, but it was so
only 14PSi spring = turbo starts earlier
14PSI spring + pcm controll = turbo starts later ?!?
Old 10-04-2009, 03:15 AM   #11 (permalink)
lyncoo's Avatar
Trader Rating: (92)
oh, get that mbc and it will help.
Old 10-04-2009, 04:24 AM   #12 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
sounds like you need a MBC or EBC (assuming there are no leaks in the exhaust mani) what happens with a spring only is the pressure on the underside of the WG valve with any pressure referance will allow the WG to open slightly slowing the spool (bleeding much needed exhaust energy), a MBC/EBC will eliminate that referance signal untill you want it there and that will eliminate the valve on your WG from leaking ....faster spool
you only want the WG to see signal when you want it to open not before
Old 10-04-2009, 08:21 AM   #13 (permalink)
Member Number: 33203
Trader Rating: (25)
That's incorrect. A leaner afr will spool a turbo faster than a rich afr. Maybe you mean't his current setup is probably rich at spool up.
Precision 6057@30psi on pump
8.50@87 on 10psi w/2.0 60 ft (wg pressure on 30 psi tune, no 2 step)
Contact Turbo666/TDSaaron for your tuning needs.
turbojonsrt4 is offline   Reply With Quote
Old 10-04-2009, 09:52 AM   #14 (permalink)
turbo666's Avatar
Member Number: 25206
Trader Rating: (31)
Super rich with little timing is referred to as anti-lag. Doing that without full PCM control or EMS isn't happening. The average person just does a leaner AFR to help spool.
Nigel
04 Srt-4-AGP Borg Warner S360-RS, E85, and MUCH MORE coming soon...
7.493@99.56<-- granny shifting on 30r with 93/meth <--OLD SETUP!
FIRST TO MAKE BIG TURBO PCM BOOST CONTROL WORK ON DIABLO!
For custom tuning, installs, and transmission rebuilds PM me!
www.trudynosports.com
Old 10-05-2009, 03:40 PM   #15 (permalink)
04blusrt_4's Avatar
Member Number: 60369
Enlighten me more So if I set my timing low and have the meth nail early i can achieve this antilag?
*NE 400 Club*
Page generated in 0.17311 seconds with 13 queries
