Old 09-28-2009, 07:26 PM   #1 (permalink)
turbosrt@hotmail.com's Avatar
Member Number: 73777
Default Spark plugs to use?
Hey guys I recently changed out the factory champion spark plugs in my SRT and I noticed it runs worse with the Bosch Platinums so I measured the gaps again and even put the champions back in to compare and it runs and starts better with the champions. What do you guys run with or any suggestions? Thanks
The SRT4. Loved by those who knew them. Hated by those who could'nt catch up. Thank you PVO.
turbosrt@hotmail.com is offline   Reply With Quote
Old 09-28-2009, 07:32 PM   #2 (permalink)
AnsareStg0's Avatar
Member Number: 71225
I've been using ngk 4306's sice i bought the srt in 05 and never had any problems!
I also gap them @ .35
AnsareStg0 is offline   Reply With Quote
Old 09-28-2009, 09:35 PM   #3 (permalink)
UpShiftSRT4's Avatar
Member Number: 73592
Platinums aren't recomended for boosted applications because the tips stay hot.
So run copper or iridium. I have NGK Iridiums @ .040''
2003_w/LSD
Stg.0 PCM, Stg.1 Injectors, Diablo Sport Predator
QTP E-Cutout Exhaust, Exhaust Depot Hard Pipes
AEM SRI, Kinetic WGA, CCA BFMIC, 180º T-Stat
Mopar STS w/Booger Bushings, MSD Wires
2x UPR Catch Cans, Solid Engine Mount's
Bwoody Trans. Mount, PTP Check Valve
Champion Coppers, Fuel Pump Rewire
Boomba 70mm TB, AEM Wideband
eBay 3'' o2, Mopar BOV
Turboboxboy's MODIFIED TOB FORK:
MOD A 'SERIAL#2' in for testing 12/15/09
UpShiftSRT4 is offline   Reply With Quote
Old 09-28-2009, 09:59 PM   #4 (permalink)
Member Number: 11681
Trader Rating: (96)
NGK stock or iridums
Everybody else is doing it....vote for me http://www.srtforums.com/forums/f389...ml#post8289538
2nd Fastest stock turbo no n2o in the country.
Best 60 1.662
Best 1/8 7.55/93
Best 1/4 11.865/116
Best MPG 28.1 city/33 highway
3147 10.93@128.58 25psi 7.099/103.54
3147 7.26/100 22psi pump full int
Old 09-29-2009, 02:48 AM   #5 (permalink)
Johnny Rocket's Avatar
Member Number: 29826
Default Design engineers recommend...
Check under the hood for the white plate with the Champion and NGK part numbers. There is also a gap number listed for both, .050 The car came with Champion, but I replaced them with NGK. I have read the Champion work just as well.
JR
2005 SRT-4, ACR, Orange Blast, Stage II w/toys, Mopar-Borla Catback, Mopar STS, Moonroof, Mopar Front Shock Tower Brace, Kicker/SRT Livin' Loud Audio System
Johnny Rocket is offline   Reply With Quote
Old 10-01-2009, 09:50 AM   #6 (permalink)
rosejm's Avatar
Member Number: 33812
Yup. Cheapo copper plugs replaced every 20k miles will be your best bet.
rosejm is offline   Reply With Quote
Old 10-01-2009, 12:28 PM   #7 (permalink)
Member Number: 69074
I have NGK 4306's gapped at .038" and it's good,
marthastricycle is offline   Reply With Quote
Old 10-16-2009, 11:20 PM   #8 (permalink)
nickyj249's Avatar
Member Number: 54851
i use ngk 4306 on a 75shot and change them every oil change so every 3000 gapped at 35 i get them so cheap theres no reason not to
Stock Turbo Slow
225hp and 256tq on 9psi
nickyj249 is offline   Reply With Quote
Old 10-16-2009, 11:22 PM   #9 (permalink)
CONROY's Avatar
Member Number: 46401
Trader Rating: (124)
4306 ftw.
Pittsburgh Penguins 41-23-5 87 points
CONROY is offline   Reply With Quote
Old 10-17-2009, 12:09 AM   #10 (permalink)
indian srt-4's Avatar
Member Number: 40634
stock champions here.
Mods: TITLE IN HAND
indian srt-4 is offline   Reply With Quote
Old 10-17-2009, 01:49 AM   #11 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (27)
I'm running 4306's. I think I might open the gap up to .040
WTB: Stock Injectors!
Old 10-17-2009, 07:08 AM   #12 (permalink)
i ran platinum for 5k miles...
Old 10-19-2009, 09:01 AM   #13 (permalink)
red04's Avatar
Member Number: 24993
Trader Rating: (54)
Over the years turbododge's have hated platinum plugs. I recommend on using NGK vpower's. Never an issue with them.
Scott @ Forward Motion Inc.
302-658-2829
www.forwardmotioninc.com
Email: scott@forwardmotioninc.com
Paypal Address: scott@forwardmotioninc.com
Owner of FM's GT37R powered SRT4 513 whp 469 wtq pump gas (93 octane) @ 6,000 rpms
11.31 @ 131.74 mph w/ 1.90 60'
red04 is offline   Reply With Quote
Old 10-19-2009, 09:13 AM   #14 (permalink)
turbo666's Avatar
Member Number: 25206
Trader Rating: (32)
Doesn't mean it was a good idea.
NGK 4306 plugs all day. For the average car I say gap to .035. I've had WAY too many issues with Iridium plugs blowing out on high boost applications, even on stock turbos on 22psi spikes. NEVER have had a issue with 4306's, even at 30psi on my old 30r with pump/meth. I've also always gotten less KR with 4306's too.
Nigel
04 Srt-4-AGP Borg Warner S360-RS, E85, Crane 18's, AMM Race Head, AGP SMIM, 1680cc injectors, ACT Twin Disc, Rage Acc. Shaft, etc... stock bottom!
FIRST TO MAKE BIG TURBO PCM BOOST CONTROL WORK ON DIABLO!
For custom tuning, installs, and transmission rebuilds PM me!
www.trudynosports.com
turbo666 is online now   Reply With Quote
