Smoking issue - Dodge SRT Forum
 2Likes
  • 1 Post By HybridKid
post #1 of 15 (permalink) Old 05-17-2017, 03:56 PM Thread Starter
Quoted: 3 Post(s)
Smoking issue
Ok a little info. 50 trim turbo with fuel mods, tune fbo etcc
One morning I went to start my car and noticed it was smoking alot, white smoke as what I can see. My first thought was head gasket. Drained oil and looked fine.
Put new oil in and drove it. After driving it it seemed the smoke went away or not as much as it did at start up. Once it warmed up it stopped and smoked a little out of the turbo area. Now the turno seems fine. No shaft play and no oil leakage anywhere.
Compression test came back on the lower side but was 120 across all 4. Cylinder 1 was a littlw off but not much
Does this sound like a valve seal problem? Only smokes bad on cold starts and after it warms very little to none
I also run a gutted pcv to a vented catch can. I since then bought a new pcv an ran it like a stock setup would for a day and still same symptoms
Heres a couple videos.
I should mention at startup there is a lot of water coming out of exhaust. More then normal and second video is about 30 mins of driving after
I do have the head off now and a new built head ready to go on. Just dont want to dig in to the bottom end if I dont have too
https://youtu.be/yzxHnlOWoUI
https://youtu.be/Gx6Fuaz6HuI
Fastsrt4door is offline
post #2 of 15 (permalink) Old 05-17-2017, 07:32 PM
"Made" Member
HybridKid's Avatar
Quoted: 815 Post(s)
Rings, maybe oil rings specifically or the turbo seals. Yes, it could be the valve stem seals as well. How does the plugs look?
HybridKid is offline
post #3 of 15 (permalink) Old 05-17-2017, 07:49 PM Thread Starter
Quoted: 3 Post(s)
If it was turbo seal would it do it all the time? Not just on warm up?
The plugs didn't look bad from what I seen. I guess I can drop the oil pan and take the pistons out to see if the rings are bad
post #4 of 15 (permalink) Old 05-18-2017, 06:47 AM
Quoted: 11 Post(s)
Garage
If it is the turbo seal I would imagine it only smokes when cold due to tolerance changes maybe? After it warms up, the expansion helps the seal do its job. Early signs of the seal going out. Someone correct me if I'm wrong lol. Also if you already have the head off isn't there a way to put something like oil on top of the valves? If I remember correctly if the seals around the valves are bad than oil should leak past in a certain amount of time. Something along those lines lol
"When That Boost Hits"
Robdee30 is offline
post #5 of 15 (permalink) Old 05-18-2017, 07:50 AM
"Made" Member
HybridKid's Avatar
Quoted: 815 Post(s)
The less invasive way of checking is to use a bore scope or pull the exhaust and intake manifolds to look at the back of the valves. If the valve seals are leaking it becomes pretty obvious then.
Robdee30 likes this.
post #6 of 15 (permalink) Old 05-18-2017, 07:54 AM
"Made" Member
HybridKid's Avatar
Quoted: 815 Post(s)
If you have to go that far to drop the oil pan, check the cylinder walls too and if they are good, think about refreshing the rings and bearings. Visually inspect for any signs of potential problem areas on the bearing surfaces.
post #7 of 15 (permalink) Old 05-18-2017, 02:15 PM Thread Starter
Quoted: 3 Post(s)
Thanks for the info. On the turbo, any oil leakage from early stages? I didnt see none. Hate to replace a bunch of stuff and be something as simple as a turbo seal.
post #8 of 15 (permalink) Old 05-18-2017, 02:53 PM
"Made" Member
HybridKid's Avatar
Quoted: 815 Post(s)
Technically a turbo seal would require a rebuild of the turbo, not so simple actually.
post #9 of 15 (permalink) Old 05-18-2017, 02:55 PM Thread Starter
Quoted: 3 Post(s)
Have a friend who lives near me who rebuilds them for decent price. Turbobay performance
post #10 of 15 (permalink) Old 05-18-2017, 03:11 PM Thread Starter
Quoted: 3 Post(s)
I don't believe its my turbo though.
post #11 of 15 (permalink) Old 05-18-2017, 03:23 PM
Quoted: 16 Post(s)
how many miles on that motor?
flame red wooot!
bad/andy/GK is offline
post #12 of 15 (permalink) Old 05-18-2017, 08:03 PM
"Made" Member
HybridKid's Avatar
Quoted: 815 Post(s)
Matt in FL?
post #13 of 15 (permalink) Old 05-18-2017, 08:39 PM Thread Starter
Quoted: 3 Post(s)
Yes sir that would be him
post #14 of 15 (permalink) Old 05-19-2017, 04:50 AM Thread Starter
Quoted: 3 Post(s)
130k on motor
post #15 of 15 (permalink) Old 05-19-2017, 06:57 AM
"Made" Member
HybridKid's Avatar
Quoted: 815 Post(s)
Matt in FL?
Ok, he did my Turbonetics. He also told me that he rebuilds the cheap chinese turbos with better parts and such.
Did you have him check this one before you put it in or get any input from him?
User Tag List
Linear Mode Linear Mode
