rod bearing or something else? - Page 2 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 01-23-2013, 04:10 PM   #16 (permalink)
ziggo0's Avatar
Member Number: 63759
if you are going that far why not take the crank in and at least have it checked...the rods as well.....your an inch away from doing it mostly right
Stone White 05 - Stock Head & Bottom End - Holset HX35 7 Blade - e85 & many other supporting mods.
Old 01-23-2013, 04:57 PM   #17 (permalink)
Creamer03's Avatar
Member Number: 62203
Default Re: rod bearing or something else?
This. Because i assure you if the bearing is bad then It has affected the crank in that spot in some way. The crank should be checked, cleaned up, and most likely turned.
Going for a Texas Top 10 1/4 mile spot...
Baby snail and E85...
Creamer03 is offline   Reply With Quote
Old 01-23-2013, 05:59 PM   #18 (permalink)
ziggo0's Avatar
Not to mention the rod in question is DONE...
Old 01-23-2013, 07:44 PM   #19 (permalink)
Kael's Avatar
Member Number: 73094
thanks guys for all the help
04 SRT4, mpx bfmic, Crower Stage 2 cams, valve springs and retainers, aem short ram, homemade catch can, MPX solid motor and tranny mounts, MOPAR Stage 1 PCM, Perrin Fuel Rail, Vibrant cold side pipe with HKS BOV, Mishimoto Radiator, AGP WGA, Apexi Turbo Timer, booger shift bushings, AEM Uego WideBand,
Kael is offline   Reply With Quote
Old 01-23-2013, 08:48 PM   #20 (permalink)
kkbsrt86's Avatar
Member Number: 56748
Im dealing with a spun and shattered rod bearing myself. It started off sounding like yours then got worse to where it knocked the whole time rev or idle. Motor seized when breaking it in on fresh motor. Replaced the rod bearings and then 8k later this happened. In the end im doing new crank etc. Total rebuild. Oh yeah... I didn't c anything when draining the oil but once the pan was dropped it was bad news. Had rods corrected also.
I question the cause on this. Hopefully my dcr oil pump is good.
-2004 N. SRT-4: Redspeedfreak, DCR, Rage-tek, AGP, etc.
-2000 Dodge Neon ES: Downgraded close to stock.
SOLD 5/20/10.
AKA lblackneon.
kkbsrt86 is offline   Reply With Quote
Old 01-24-2013, 08:08 AM   #21 (permalink)
fivetoez's Avatar
Member Number: 9691
just buy a new crank kit & a rod assy. & do it once correctly..........learn from our mistakes.
_____5TOEZ______ 1967 Cadillac Calais 429 2dr., 1967 Chevelle 4sp. Conv. ,1978 Dodge 318 "Factory Custom"van., 2004 Dodge Srt-4,Stage1.5(E-Blue) & a couple motorcycles.
