#1 (permalink) |
![]() Join Date: May 2009
Member Number: 73094
ok so i got a deal on another srt and i am trying to fix it. it has a knocking sound coming from it and it sounds like its in the head at time and others it sounds like its coming from the block. before i tear into it i was just wondering if i could get some opinions on what it could be. At idle its fine and up to about 1800 rpms, past 1800 and up is when it starts knocking. any help would be appreciated.
5D28BBCA-9569-4FAD-9BB0-4B584EFC03B9-5779-000006D639F7366C.mp4 video by irishkael | Photobucket
04 SRT4, mpx bfmic, Crower Stage 2 cams, valve springs and retainers, aem short ram, homemade catch can, MPX solid motor and tranny mounts, MOPAR Stage 1 PCM, Perrin Fuel Rail, Vibrant cold side pipe with HKS BOV, Mishimoto Radiator, AGP WGA, Apexi Turbo Timer, booger shift bushings, AEM Uego WideBand,
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
![]() Join Date: Apr 2004
Member Number: 9691
Sounds like a bad rod bearing.
_____5TOEZ______ 1967 Cadillac Calais 429 2dr., 1967 Chevelle 4sp. Conv. ,1978 Dodge 318 "Factory Custom"van., 2004 Dodge Srt-4,Stage1.5(E-Blue) & a couple motorcycles.
#3 (permalink) |
![]() Join Date: Mar 2008
Member Number: 62203
Heard that before.... Lol id pull the pan or drain the oil and see what you catch with a magnet.
Going for a Texas Top 10 1/4 mile spot...
![]() Baby snail and E85... ![]() |
#4 (permalink) |
What it end up being? Was it a rod bearing
#7 (permalink) |
![]() Join Date: May 2004
Member Number: 11361
Build Thread:http://www.srtforums.com/forums/f451...w-123k-612933/
PCM=S0, DSP rescaled, 3bar map/tip injectors= Siemens 80# (ebay $200) built motor, 8.8:1 weisco, eagle-h, strap & windage S3R DCR manifold ($500) w/evo8 turbo (ebay $150) - 20G/47# ebay ($200) Evo 8 WGA 24x12x4 w/cast ends - CXRacing (ebay $200) DataLogger DataQA, $25 Wideband UEGO (ebay $150) vette rims 275/40/17 needswing v5 SouthBend S3 |
#8 (permalink) |
So I need need to pull the motor or can I change them from underneath SCH-I100 using AutoGuide.C
#9 (permalink) |
![]() Join Date: Jun 2011
Member Number: 84969
You can change them with the motor in the car. But it's only a temp fix. The crank should be taken out and the journals cleaned up/polished. If not it will only happen again. I have gone through this exact same problem.
Sent from
SRI, 3" Exhaust Depo Side Exit + 3" MPx O2, exhaust cutout, DSP, Mopar Plate, AGP Return Line, Walbro 255, Fuel Pump Rewire, Innovate Motorsports MTX-L, N2MB Wot box/2-step and Boost Box, Bwoody check valve, $20 catch can x2, STS, Rage-Tek Shifter Bushings, Pwerks 3rd Gear Extender, 3 Bar Sensors, Dusters Injectors and e85
#10 (permalink) |
![]() Join Date: Mar 2011
Member Number: 83768
You can do it from underneath.
Take the plugs out, hot side pipe off, pan off, and balancer out. Do them 2 at a time: Turn the crank clockwise to where 2 of the pistons are at the bottom. Remove the rod cap and push the piston up a little to get to the upper bearing. They pop right out.
2004 Silver SRT-4
Stage I, AEM CAI, UDP, cut balance chain, muffler ![]() |
#11 (permalink) |
Thats all I need it for is temporary. Im needing it long enough build my other motor SCH-I100 using AutoGuide.C
#12 (permalink) |
![]() Join Date: May 2008
Member Number: 63759
Depending on the damage already done changing won't matter. It might last one mile, it might last 100 miles. The only real way to fix this is by pulling the motor and doing a complete rebuild pretty much. You've got metal shavings all over the place in your oiling system now, other bearings were probably harmed as well, that rod is screwed and out of round, the cranks rod journal is scratched up/out of round now and will require replacement (or turning if we can turn out cranks?), after trying to do what you are going to do on my DSM TWICE many moons ago it always resulted in failure very quickly, much disappointment and tons of money wasted.
Stone White 05 - Built Motor, Built Head, e85 & 75lbs/min - coming soon
#13 (permalink) |
I completely understand OP, I'm just saying prepare for a decent sized bill down the road. Good luck!
Sent from
#14 (permalink) |
I would and will never only change bearings only on a rod or main. That's just asking for another problem in the future.
#15 (permalink) |
Im not just changing just 1 im changing all 4 plus the mains. SCH-I100 using AutoGuide.C
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
