Old 06-18-2008, 01:46 PM   #1 (permalink)
Member Number: 62176
quick AGP wastegate question
my stock WGA is leaking so im upgrading to AGP.
how do i make sure a used WGA isnt also going to leak?
also is it a must to get a BOP along with it?
I want to be running 18lbs and spiking 20.
Thanks.
Alex
atarh001 is offline   Reply With Quote
Old 06-18-2008, 01:52 PM   #2 (permalink)
Member Number: 41718
No u don't need a Block off plate, ur not installing an aftermarket Blow off valve.
thuggishtavo is offline   Reply With Quote
Old 06-18-2008, 01:55 PM   #3 (permalink)
scottw03's Avatar
Member Number: 23435
Trader Rating: (33)
Get an FM wga instead of the AGP. Works better and will give you the same kind of performance you are looking for. As for the BOP, no, you don't need one unless you get an aftermarket BOV.
scottw03 is online now   Reply With Quote
Old 06-18-2008, 02:02 PM   #4 (permalink)
ok, just wondering since i see all the how to's with both. thanks
Page generated in 0.13185 seconds with 11 queries
