Old 10-29-2009, 04:40 AM   #1 (permalink)
Member Number: 42413
Default Oil pressure drop from pan to head
After reading through posts and checking out the archives it seems as though at idle people are getting about 40-45 at the pan, 20-25 at the stock location and 5-10 at the head. That means there is about a 40psi drop from the pan to the head at idle. Which got me thinking where mine reads 0-5 at times at idle could it be that my oil pump is just a couple psi off and that is what is giving the 0 reading at times.
It seems to make sense to me but that might just be because I am tired and have put to much thought into it.
Member 685
RVDSRT4 is offline   Reply With Quote
Old 10-29-2009, 08:54 AM   #2 (permalink)
04blusrt_4's Avatar
Member Number: 60369
I have 19-20psi fully warmed up off the head, 35-40psi cruising, and around 50psi WOT.
Only thing I can think of is you used the wrong port on the head, you are using thinner oil than you should be, or you have an oil modifier in your head.
*NE 400 Club*
Old 10-29-2009, 10:07 AM   #3 (permalink)
Member Number: 36825
Check the how to do it off the back of block. Better reading.
SRT Jeff is offline   Reply With Quote
Old 10-29-2009, 10:24 AM   #4 (permalink)
04blusrt_4's Avatar
Different, not better.
Old 10-29-2009, 06:51 PM   #5 (permalink)
I think your the highest oil pressure I have ever seen for idle coming off the head so far most seem to hold between 5-10.
Where did you tap into the head at?
Old 10-30-2009, 07:28 AM   #6 (permalink)
04blusrt_4's Avatar
There are two plugs on the driver side of block, i used the one closest to the back of the car.
Page generated in 0.12495 seconds with 13 queries
