Old 06-16-2008, 06:47 PM   #1 (permalink)
Member Number: 63816
Default Oil Drain line, bradded, have u done it?
Well I want to know if anyone has changed out there oil line on there TD04 to steel bradded line?
Here is my issue I have tried... and well i can't seam to find a proper fitting. The fitting hits agents the compressor / charge pipe housing.
10badassneon is offline   Reply With Quote
Old 06-16-2008, 07:04 PM   #2 (permalink)
valeriekay_2000's Avatar
Member Number: 27795
Trader Rating: (28)
why would you want BRAIDED lines? If the fitting is hitting AGAINST the compressor, there's probably a reason...keep the stock lines
valeriekay_2000 is offline   Reply With Quote
Old 06-16-2008, 07:38 PM   #3 (permalink)
wannasupra's Avatar
Member Number: 32741
not on a td04, but i've got a t3/t04e that i'm changing to stainless braided.
"Scoff not at my vile remarks horny fiend"
Quote: Originally Posted by Sweets View Post
^^ Im with supra..
Old 06-16-2008, 07:40 PM   #4 (permalink)
Well see I can't find any but one fitting out there and it is for a 10an fitting, and it comes right off of the turbo.
If I was able to find a fitting that was longer and cocked to the side it would be perfect.
as stated I wanted to know if anyone else has done, and how they got around it.
Also i have a 420a motor with the tdo4 turbo on it. I wanted better than stock!
Old 06-16-2008, 07:43 PM   #5 (permalink)
yeha I have done it on the T3/T4 and it is cake... there is alot of room... but the TD04 there is no extra space.
Old 06-17-2008, 10:36 AM   #6 (permalink)
SRTforums Veteran²
onthedwnlow's Avatar
Member Number: 27125
Trader Rating: (43)
1.) why?
2.) why?
3.) no it wont work
sorry guys but the car is for sale....all out first gen is in the works
onthedwnlow is offline   Reply With Quote
Old 06-18-2008, 09:12 PM   #7 (permalink)
dawm's Avatar
Member Number: 2695
Trader Rating: (31)
http://www.srtforums.com/forums/f27/...6g-20g-444366/
theres a few swapped people using this but to make it work you cant use braided line since the braided line fittings are too bulky to fit properly. You can use pushlock/twistloc style fittings and hose (which is what others have done).
07 Caliber R/T FWD 5SPD
98 Neon R/T 2.4L Turbo Coupe 01/03/07 -- drove it home, been on jack stands since
02 Neon R/T 08/08/08 -- traded for the Caliber :cry:
http://www.neontuners.com http://www.detroitneonowners.org
dawm is online now   Reply With Quote
Old 06-19-2008, 04:38 AM   #8 (permalink)
turbo666's Avatar
Member Number: 25206
Trader Rating: (20)
turbojonsrt4 runs -10 braided line for his return. But I don't think he uses fittings. He just slides it over the factory oil return pipe and a aftermarket piece that bolts on the bottom of the turbo and gives you a protruded piece of pipe to slide the hose on. He's had issues in the past with oil returns melting or popping off so he went this route. I've considered it myself.
Nigel
04 Srt-4-So stock it's not stock...
Installs, tuning, and tranny rebuilds done in NC! PM me NOW for GREAT pricing!
http://www.trudynosports.com/customers/nigel.html
Old 06-19-2008, 07:50 PM   #9 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (546)
Do PTFE line and get good stainless steel couplers. I have done this several times now and it looks nice with no leaks and worry free. Hit me up with a PM if you need any help.
Page generated in 0.22031 seconds with 11 queries
