Old 10-10-2006, 08:10 PM   #91 (permalink)
Member Number: 3175
Trader Rating: (41)
i find it interesting that they specifically say that it is a "billet" wheel (the srt4 turbo upgrade)...as we know typically the wheels are a fine-grain casting...meaning that perhaps they are having the wheel cnc machined...perhaps?
...and if so, can they mill me a 52 lb/min "hr" wheel...please ...PLEASE!!!
Quote: Originally Posted by Tex
the site is a mitsu turbo dealer as well...so i think that that option is infact a 20g. im just wondering if they are infact the same, and the rating is just "hyped"
also, i cannot find ANYTHING from garrett that is reverse. the gt2876/3076 runs a standard 47lb/min wheel...so its that size. and that puts it a healthy improvement over the 20g.
the way i see it here,
1. garrett made a small run of reverse wheels for a very limited market...seems odd for a company that makes millions with what they have, though mitsu did it with the 16gR for the evo's and the 15gkR for the TM evo (what we stole)
2. someone spend lots of money casting a new wheel for their own benifit...TCC/DB did it
3. its a different brand wheel...again doesnt seem plausiable because we cant find anything online. 10 years ago that wouldnt be proof enough, however, because every company is out to make a profit, and how do you make a profit if you dont advertise.
4. someone is artificially inflating information...that never happens...i think we might have our winner!!!
jersturbo is offline   Reply With Quote
Old 10-10-2006, 08:29 PM   #92 (permalink)
Tex
Tex's Avatar
Member Number: 3622
cnc milling a wheel would be BANK...wouldnt it...hmmm...i have a good buddy who has 4-axis machining capabilities. i have helped him work on his 1000+hp single turbo c4. im going to talk to him and see if its realistic. jers...wanna go with a bigger wheel?
-Soren Kierkegaard
Tex is offline   Reply With Quote
Old 10-10-2006, 08:39 PM   #93 (permalink)
Tex
Tex's Avatar
Member Number: 3622
holy crap batman...your right jers.
these are off of the mazdaspeed protege...son of a...
this one might be a custom unit
Old 10-10-2006, 08:40 PM   #94 (permalink)
Tex
Tex's Avatar
Member Number: 3622
Full race compressor wheels in these situations are normally CNC machined on a five-axis mill from forged aluminum billets.
Old 10-10-2006, 09:40 PM   #95 (permalink)
SHrtShft-4's Avatar
Member Number: 38618
Inner Diameter. I think I might just be paranoid.
coSRToc
US Army
SHrtShft-4 is offline   Reply With Quote
Old 10-10-2006, 10:03 PM   #96 (permalink)
Tex
Tex's Avatar
Member Number: 3622
OD is 2.5 so that it can fit into the factory piping. your ok. measure the inlet into the turbo (the side that goes to your air filter). compare that measurement to the inducer size i listed. if its close to one, odds are its that one
Old 10-11-2006, 09:49 AM   #97 (permalink)
Member Number: 3175
Trader Rating: (41)
wouldnt that be crazy!? ...do i even want to ask how much? $
my only concern with some of those is a mis-matched comp to turb side....its happened on other hybrids, where the compressor wheel exchanged is just not a good match to the turbine used... (i.e. some P-trim / t03 i've seen!)
i do however really...REALLY...like the idea of a GT series 49 - 52 lb-min compressor wheel, matched to a td05, so it all fits in the s3 housings!
the part i like, is that to generate the same amount of positive boost pressure (lb/min) the shaft speed shouldnt have to be so high then (even if slightly less)...as the real enemy of the td05 turbine wheel appears to be the heat-soak and deterioration damage resulting
Old 12-17-2006, 10:40 PM   #98 (permalink)
xtreemsrt4's Avatar
Member Number: 41347
I just bought a new turbo from a friend. he doesnt know anything about it, i looked up the serial number and found out some info but nothin of any use to me.
its a turbonetics t04b V trim .63 a/r turbo.. does any 1 know if this is a good turbo? How much power can this turbo produce? any info is much appreciated.
xtreemsrt4 is offline   Reply With Quote
Old 12-18-2006, 03:03 PM   #99 (permalink)
Member Number: 13063
Trader Rating: (18)
it's a hybrid (t3/t4 mix) 50 or 60 trim i don't know. Probably lookig at around 500hp
GAngel is offline   Reply With Quote
Old 12-18-2006, 05:40 PM   #100 (permalink)
Scammer
Member Number: 2261
Quote: Originally Posted by Canuck_2k
ptp - post up the size of the sst!
I'm not going to say this is 100% official information, since I just used some simple algebra with a pixel count ratio vs inches... provided that the picture posted from PTPerformance is showing the stocker next to the SST. If this is true then this should be the size of the SST:
Inducer: 1.86"
Exducer: 2.65"
FYX193 is offline   Reply With Quote
Old 12-20-2006, 06:39 PM   #101 (permalink)
Trader Rating: (18)
That's about the size of the evo 8 16g wheel
Old 12-20-2006, 06:40 PM   #102 (permalink)
Tex
Tex's Avatar
Member Number: 3622
pixel count...you had to count pixels to get an idea of the size???? WTF, he posted the pic next to a stocker. just measure the two and it becomes a ratio, and some simple algebra makes the sizing easy as pie
Old 12-25-2006, 03:00 AM   #103 (permalink)
Member Number: 11681
Trader Rating: (96)
Tex did you ever do a 3147 or am i like really blind
2nd Fastest stock turbo no n2o in the country.
Best 60 1.662
Best 1/8 7.55/93
Best 1/4 11.865/116
Best MPG 28.1 city/33 highway
3147 7.49/102 11.51/124 so far 28psi
3147 7.26/100 22psi pump full int
Old 12-25-2006, 10:07 PM   #104 (permalink)
Tex
Tex's Avatar
Member Number: 3622
i am assuming you mean did i do a size comparison with the 3147 turbo? if that is what your asking, yes and know. i had originally asumed that the 3147 was named properly, as i discussed in the write up. after talking with agp, or better put, being chastised by agp for having no idea what i was talking about, i guess they named it improperly, and stated it flows 47lb/min (between s3 and 20g flow rates). however, they refuse to measure it for me, for whatever reason (more than likely, its because they make good money selling the turbo, and dont want us to know how to make our own version...like a couple other turbo's on the market here...especially the modified custom units). i do list the 3147 as a gt3147, but its not acurate, but until i get real information on the sizing, im not going to bother changing anything.
Old 02-28-2007, 10:56 PM   #105 (permalink)
Member Number: 8608
Anyone know were I can fine a flow chart for a 25G? I got this one from
Bill Hahn.
Are there any upgrades for the turbine on this? It has a internal gate and a
pretty small turbine judging from how fast it spools..
Steve
Racerstev is offline   Reply With Quote
Page generated in 0.49473 seconds with 14 queries
