Old 10-04-2006, 02:35 PM   #76 (permalink)
Member Number: 3175
Trader Rating: (41)
Quote: Originally Posted by TurboGLH
Quote: Originally Posted by jersturbo
edited the post ^^ was hydrohopper...in new S3 feeedback thread, remarked about a garrett wheel, wasnt sure if he meant his S3 (because it was being the discussion) or of a different (previous) turbo (gt30r)??
hydro, you wanna clear that up for us?
thx
NEW Stage 3 Owners Feedback Thread
Send a PM to Ed (ptc01), I believe that picture is from his upgraded stage3 and he had it done somewhere locally by a person who's not a forum vendor.
yup...he and Tex are the only other people i know (besides myself) to have different than stock S3 wheels (mods to S3 turbo)...
...pct01 has an upgraded compressor wheel (16G or 20G?) and clipped turbine wheel
jersturbo is offline   Reply With Quote
Old 10-06-2006, 03:11 AM   #77 (permalink)
Member Number: 3175
Trader Rating: (41)
okay...some info pasted (and asked about in other thread "s3 owners feedback 2");
since the "HR" wheels have basically (literally) been mirror image casting of thier 'clockwise' counterparts, these flow numbers should be the same for the "HR" versions...
...still searching!!
Greddy TD04H-15C 15C
compressor
trim. 55
induc. 1.65"/42mm
exduc. 2.187"/55.5mm
housing. TD04
max flow
cfm. n/a
turbine
wheel. TD04H
induc. 1.74"/44.7
exduc. 2.047"/52mm
flange. TD04H
Greddy TD05H-16G
compressor
trim. 60
induc. 1.83"/46.5mm
exduc. 2.236/57mm
housing. TD05
max flow
cfm. 520@2PR
turbine
wheel TD05H
induc. 1.93"/49mm
exduc. 2.20"/56mm
housing. TD05H
Greddy TD05-18G
compressor
trim. 50
induc. 1.99"/50.5mm
exduc. 2.68/68mm
max flow
cfm. n/a
turbine
wheel TD05H
induc. 1.93"/49mm
exduc. 2.20"/56mm
housing. TD05H
Greddy TD06-20G
compressor
trim. 60
induc. 2.07"/52.6mm
exdc. 2.68"/68mm
max flow
cfm. 685
turbine
wheel. TD06S
induc. 2.17"/55.1mm
exduc. 2.56"/65mm
housing. TD06S
...also found this 'flow' map of td05-hr-16g6!
http://www.dubspeedracing.com/photop...r-16g6-cfm.jpg
...interestingly enough, on the GReedy site, they list the turbos (but no other info, maps, etc)...but in thier list i found:
- td04h-15g (8.5cm)
- td05sh-18g (10cm)
- td06sh-25g (8cm)
...the "h" designations set them appart in the list ("h" supposed to mean reverse rotation)
they have listed a td05 with 18g wheel (flow = ?)...and there is a "h" 25g wheel (on a td06h)?
...both of these ^^^ are listed elsewhere as available upgrades for the Evo7/8 model!
Old 10-06-2006, 11:49 AM   #78 (permalink)
TurboGLH's Avatar
Member Number: 9873
- td04h-15g (8.5cm)
- td05sh-18g (10cm)
- td06sh-25g (8cm)
The H doesn't refer to reverse rotation, it indicates a larger turbine wheel. The letter R following the td06/td06h would indicate a reverse rotation turbo.
QW FMIC, 3" BDJ Dump, Fuel Return, WGA and Map Clamp.
284whp/358wtq - uncorrected
Member - New England Shelby Dodge Auto Club
TurboGLH is offline   Reply With Quote
Old 10-06-2006, 01:58 PM   #79 (permalink)
Tex
Tex's Avatar
Member Number: 3622
they must be a complete replacement for the evo. because the 25g and all of those are standard rotation wheels (i wonder how much work is required to alter the engine bay to take a standard turbo vs a reverse turbo?)...and i have yet to even hear of them in reverse. see if you can find any pics.
-Soren Kierkegaard
Tex is offline   Reply With Quote
Old 10-06-2006, 03:10 PM   #80 (permalink)
Member Number: 3175
Trader Rating: (41)
- td04h-15g (8.5cm)
- td05sh-18g (10cm)
- td06sh-25g (8cm)
no, really!! (sarcastic intended)...
...that would be the point of me saying at the page top:
...not "these are "HR" spec wheels"!
Old 10-06-2006, 03:15 PM   #81 (permalink)
Member Number: 3175
Trader Rating: (41)
ya, its intersting to see...i cant find any HR specs for 18g (white rabbit?)...but thought these might help some?
...now if only we could get a 25 HR, eh?
Old 10-10-2006, 08:41 AM   #82 (permalink)
SHrtShft-4's Avatar
Member Number: 38618
Is there a way to make for sure I got the right turbo shpped to me. I measured the inlet its ony like 2in to 2 and a 1/4. Hahn says its supposed to be 2 1/2. Oh I ordered the s20g. The invovice says 20g on. I was looking for partnumber but none matched what I could find. Got any other ideas. Or could someone post pics of theirs so I could compare?
coSRToc
US Army
SHrtShft-4 is offline   Reply With Quote
Old 10-10-2006, 03:10 PM   #83 (permalink)
Tex
Tex's Avatar
Member Number: 3622
did you measure ID or OD on the outlet?
Old 10-10-2006, 07:02 PM   #84 (permalink)
Tex
Tex's Avatar
Member Number: 3622
ok jers...figure this one.
stage3 upgrade
. if you were to take the second picture and measure the OD (which is standard size) and ID (asumed inducer size) it appears to be close to a 20g wheel. if the 20g is roughly a 44lb/hr, than what does boosted planet use?
Old 10-10-2006, 07:07 PM   #85 (permalink)
Tex
Tex's Avatar
Member Number: 3622
after doing some more searching on their site, and looking at power ratings, i am 100% confident that this is a 20g! sooooooooo...what the hell is a 47lb/hr wheel?????????
Old 10-10-2006, 07:49 PM   #86 (permalink)
Member Number: 3175
Trader Rating: (41)
interesting...without knowing the exact dimensions, that one does appear to be a billet wheel, is 6 blade just as the 20g-6
do you know what is the exact model from garrett?...i can not find any listing...
...however, do you mean to say lb/min...and is it 47 or 49 lb/min?
for some comparison:
here is a td05-hr-16g6 map, which shows it about max 30 lb/min flow rate at 2.8 presure ratio...
http://www.stealth316.com/images/td05hr-16g6-raw.gif
...and a td06-20g map, which shows it makes about max 32 lb/min flow rate at about 2.3 pressure ratio...
http://www.stealth316.com/images/td06-20g-raw.gif
Old 10-10-2006, 07:53 PM   #87 (permalink)
Member Number: 3175
Trader Rating: (41)
here is stated that the mitsu 18G wheel is rated at a max of 40 lb/min flow rate...
http://www.blouchturbo.com/turbos/WRX_TD05H-18G-7CM2/
the TD05H-18G features the 40 lb/min performance of the Mitsubishi TD06 18G compressor wheel combined with the quick response of the TD05H turbine wheel.
Old 10-10-2006, 07:56 PM   #88 (permalink)
Member Number: 3175
Trader Rating: (41)
here is the most interesting tid-bit, also off the same site, and a look at the garrett 49 lb/min compressor wheel...
...my guess is that just like mitsubishi, garrett has taken an existing compressor wheel, and simply cast it in mirror-image, to make it reverse rotation!
...is a true Garrett/Mitsubishi hybrid featuring the 49 lb/min race proven performance of a proprietary Garrett compressor wheel combined with the high efficiency and quick response of the Mitsubishi TD06H turbine wheel in a 7cm2 nozzle area turbine housing.
http://www.blouchturbo.com/turbos/WRX_STi_Dominator_I
Old 10-10-2006, 08:03 PM   #89 (permalink)
Member Number: 3175
Trader Rating: (41)
here is one that is 520 hp capable, using a 52 lb/min compressor wheel...
...I want this one!
is an outstanding performer featuring a proprietary state-of-the-art 52 lb/min Garrett GT compressor wheel (with an unheard of 79% maximum efficiency) combined with a race proven proprietary Garrett turbine wheel
http://www.blouchturbo.com/turbos/WRX_STi_Dominator_II/
Old 10-10-2006, 08:06 PM   #90 (permalink)
Tex
Tex's Avatar
Member Number: 3622
the site is a mitsu turbo dealer as well...so i think that that option is infact a 20g. im just wondering if they are infact the same, and the rating is just "hyped"
also, i cannot find ANYTHING from garrett that is reverse. the gt2876/3076 runs a standard 47lb/min wheel...so its that size. and that puts it a healthy improvement over the 20g.
the way i see it here,
1. garrett made a small run of reverse wheels for a very limited market...seems odd for a company that makes millions with what they have, though mitsu did it with the 16gR for the evo's and the 15gkR for the TM evo (what we stole)
2. someone spend lots of money casting a new wheel for their own benifit...TCC/DB did it
3. its a different brand wheel...again doesnt seem plausiable because we cant find anything online. 10 years ago that wouldnt be proof enough, however, because every company is out to make a profit, and how do you make a profit if you dont advertise.
4. someone is artificially inflating information...that never happens...i think we might have our winner!!!
Page generated in 0.22961 seconds with 14 queries
