Old 08-13-2006, 09:42 PM   #46 (permalink)
partyboy8705_sm's Avatar
Member Number: 42113
what other mods should be done to make sure the car runs right with a hahn super 20g turbo?
i was told only a fuel system upgrade is needed leaving everything else stock and achieving 400-425hp
partyboy8705_sm is offline   Reply With Quote
Old 08-13-2006, 11:08 PM   #47 (permalink)
Tex
Tex's Avatar
Member Number: 3622
fuel and some means of moderating the computer so it doesnt see an overboost
-Soren Kierkegaard
Tex is offline   Reply With Quote
Old 08-15-2006, 10:57 PM   #48 (permalink)
TurboGLH's Avatar
Member Number: 9873
Quote: Originally Posted by Tex
already have
How To Pick The Right Turbo
and once you know how to read them, this is where to find them
Turbocharger Compressor Maps
http://www.squirrelpf.com/turbocalc/
Here's a handy tool that the one of the owners over on turbo-mopar.com created.
Inputer your data and it will graph it out for you on a selection of compressor maps.
Your info will need to be accurate as far as VE and intake temp. To get accurate info for a turbo 2.4 I talked with Garry McKissick (Co-autor on the sae paper on turboing the 2.4 for chrysler and was a Design/Development engineer on the Turbo 2.4 group).
He's got the VE info at all different load and RPM levels, but it takes into consideration MAP / RPM / Torque / Load / fuel / spark so he's trying to parse it down to a more simple form that would allow it to be used in the above program.
QW FMIC, 3" BDJ Dump, Fuel Return, WGA and Map Clamp.
284whp/358wtq - uncorrected
Member - New England Shelby Dodge Auto Club
TurboGLH is offline   Reply With Quote
Old 08-24-2006, 10:10 AM   #49 (permalink)
SHrtShft-4's Avatar
Member Number: 38618
If you port the turbo how much will that affect the system? Is it always beneficial, and does it change it enought to a have to upgrade any internals. Im buying the 20g, thinking of porting it, how do I find out if it will help or hurt me?
Please dont flame Im still learning all of this power adder stuff. I like to know how stuff exactly works. You can PM me if this is completely off base.
coSRToc
US Army
SHrtShft-4 is offline   Reply With Quote
Old 08-24-2006, 08:51 PM   #50 (permalink)
Tex
Tex's Avatar
Member Number: 3622
by porting you are altering the a/r. so there is a trade off, you are increasing overall flow, but hurting spool up
Old 08-28-2006, 10:50 AM   #51 (permalink)
c2k
c2k's Avatar
Member Number: 2639
Trader Rating: (65)
ptp - post up the size of the sst!
http://www.SRTCanada.com <----- alternate site for canadians.
DiabloSport Trinity Beta Tester
Quote: Originally Posted by DODGETWEAKER
Boost is like crack and I am your dealer. Come here lil' junkie and take your medicine.
Dodgetweaker is a part of the SRT Engineering team
c2k is offline   Reply With Quote
Old 08-28-2006, 11:35 AM   #52 (permalink)
Member Number: 3175
Trader Rating: (41)
some niblets...
stock turbo next to S3 turbo
stock S3 turbo
S3 manifold with Evo9-20g turbo
jersturbo is offline   Reply With Quote
Old 08-28-2006, 12:05 PM   #53 (permalink)
SRTGallardo's Avatar
Member Number: 39792
Good thread, numbers sell me.
Any Car > WRX's > Ford's
Basic Stage 1
SRTGallardo is offline   Reply With Quote
Old 08-28-2006, 12:10 PM   #54 (permalink)
Tex
Tex's Avatar
Member Number: 3622
very nice jers!!!
Old 08-28-2006, 12:25 PM   #55 (permalink)
Member Number: 3175
Trader Rating: (41)
very nice jers!!!
thanks...we'll have to see yet how it will run?...maybe will be lag-city??..dunno!
stock oil & coolant lines + oil drain line all connect directly, including heat shields (top & bottom)...using Maxfabb 3" o2 housing + full mandrel 3" exhaust
the 20G-6 turbine wheel is clipped, and the S3 manifold PNP...will be matched to the (mild) PNP head (stock valves, crane 16s + adjustables) + PNP intake...have an AGP-WGA after things are running right
running on S3 ECU...for fuel is S3 rail + injectors, 255 walbro, PTP 75psi FPR-mod (and 80psi in hand, just in case)...and SAFC2 for tuning
...can't wait
Old 08-28-2006, 08:58 PM   #56 (permalink)
Tex
Tex's Avatar
Member Number: 3622
Holy Crap!!! You Canadians Are Crazy!!!!!!
Old 08-29-2006, 10:44 AM   #57 (permalink)
Any numbers for the PTP Turbo yet. Or any other Turbos?
Old 08-29-2006, 11:09 AM   #58 (permalink)
Member Number: 3175
Trader Rating: (41)
ha, ha...its the winters, allows for project building!
...I will likely be PMing you for some tuning advise once things are running!?
Jer
Old 08-29-2006, 06:21 PM   #59 (permalink)
Tex
Tex's Avatar
Member Number: 3622
please do, thats why im here
Old 09-12-2006, 09:20 PM   #60 (permalink)
Member Number: 3175
Trader Rating: (41)
okay Tex...gentlemen start your search engines (LOL)...
I dont have the spare ca$h to trial fit compatability of all the parts i'd like too...
...like i did with discovering the evo 8&9 chra's fit to S3 manifold...but still i was pondering?
SO...if the 15gk compressor is out of a td06 somewhere...and the 20g-6 compressor is out of a td06 somewhere...
...both of these "somewhere" td06 turbos must therefore be "HR" also, on thier turbine side (chra)...
...and like the regular vs. reverse rotation td06 wheels, are likely mirror image
i'd love to find out where and what they are exactly...maybe japan only spec?
...and depending upon how much measured difference there is between the td06-hr turbine inducer & exducer and the td05-hr turbine wheel...hmmmm??
...just curious!
Page generated in 0.23740 seconds with 14 queries
