Old 08-04-2006, 03:14 PM   #16 (permalink)
Member Number: 19937
Trader Rating: (37)
This thread rocks!!!
dubgunit is offline   Reply With Quote
Old 08-04-2006, 03:17 PM   #17 (permalink)
Member Number: 3175
Trader Rating: (41)
Quote: Originally Posted by Tex
yeah, thats more work than machining out my housing!!!
...if you want a 20G crammed into the stock S3 housing...i wouldn't!!
jersturbo is offline   Reply With Quote
Old 08-04-2006, 03:25 PM   #18 (permalink)
Tex
Tex's Avatar
Member Number: 3622
its actually not that bad. we have a larger compressor housing than the evo8's do. its a smaller jump for us then for them
-Soren Kierkegaard
Tex is offline   Reply With Quote
Old 08-04-2006, 03:49 PM   #19 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (567)
small turbo = quick spool. there are several options for upgradding the stage3 turbo. you can throw in the mitsu 20g wheel (why i gave it as an option). there is another turbo available, but dont have all the specs as of yet. its called the white rabbit and is a slightly different wheel than the 20g. but since i dont have the specs, its not up yet. i also hope to get some info from PTP as well with his SS turbo. i will be coming back and editing this from time to time
I wanted to add that you can also start to screw with the exducer and inducer wheels and change the spool, surge, flow, ect. like we did with the SS turbo. Tex I will get the wheel size for you that we are using for the SS turbo but I dont want to relase what wheel it is, thanks.
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4
DSP or Trinity
Old 08-04-2006, 03:54 PM   #20 (permalink)
Tex
Tex's Avatar
Member Number: 3622
i have no idea what wheel it is, so i wont say a word. but if you dont mind posting sizes, that will give these guys an idea of how good yoru setup is.
Old 08-04-2006, 03:54 PM   #21 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
tex, the 3147 makes 420 hp @20psi on a great tune. my buddies in florida hit 420 atthat psi. the 3147 will max out around 450hp.
reed32 is offline   Reply With Quote
Old 08-04-2006, 03:56 PM   #22 (permalink)
Tex
Tex's Avatar
Member Number: 3622
mike, the numbers are approximate, on an average tune. i didnt want to hunt down EXACT peak numbers for each setup
Old 08-04-2006, 04:11 PM   #23 (permalink)
2004NeonSRT4's Avatar
Member Number: 4577
Trader Rating: (44)
next u should do write on how to pick a turbo for u. explaining how to read a compressor map. flow vs psi and all.
2004NeonSRT4 is offline   Reply With Quote
Old 08-04-2006, 04:17 PM   #24 (permalink)
Tex
Tex's Avatar
Member Number: 3622
already have
How To Pick The Right Turbo
and once you know how to read them, this is where to find them
Turbocharger Compressor Maps
Old 08-04-2006, 05:44 PM   #25 (permalink)
Member Number: 3175
Trader Rating: (41)
the Evo 8 compressorhousing and the S3 compressorhousing are nearly idenical for volume = A/R value
the Evo 8 compressor housing, even with the stock 16G comp wheel was notorious for experiencing compressor surge issues, and temp issues
installing a 20G wheel into a S3 comp housing will only greatly increase those issues...
..thus, they re-designed and came out with the much more generous (larger) Evo 9 comp housing, due to those issues
Old 08-04-2006, 06:23 PM   #26 (permalink)
Tex
Tex's Avatar
Member Number: 3622
but the stage3 is a bigger inducer meaning more likely to surge, but doenst in its housing. i have yet to have an issue, but we will see
Old 08-04-2006, 07:49 PM   #27 (permalink)
Member Number: 3175
Trader Rating: (41)
have you got the 20G wheel in your S3 turbo now, and running?
Old 08-04-2006, 08:31 PM   #28 (permalink)
Tex
Tex's Avatar
Member Number: 3622
up and running
Old 08-04-2006, 08:34 PM   #29 (permalink)
Member Number: 3175
Trader Rating: (41)
up and running
kool...i've done a bunch of sharing...so you're turn to share with us
so i'm guessing you just machined the 20G wheel to fit the S3 cartridge...take any pics?
let us all know
Jer
Old 08-04-2006, 08:37 PM   #30 (permalink)
Tex
Tex's Avatar
Member Number: 3622
no pics. just had my machine shop port the heck out of the compressor housing. really didnt have much to do with it. gave him the wheel and the turbo. he did the rest
Page generated in 0.18321 seconds with 14 queries
