Old 09-09-2007, 09:06 PM   #1 (permalink)
brianbr's Avatar
Member Number: 50755
Default not holding boost
i have a stock turbo with ptp w/g. my issue is that boost drops off to 12 psi by 5500 to 6000 rpm. when i first installed the w/g it would spike 17 and hold 14 to 15 at redline. i have checked for boost leaks, tested to 25 psi. no major leaks found. i checked for shaft play and there is some. there is no binding or scraping noise when turning by hand. i also noticed that the turbo is much louder when spooling. would that make my boost drop that much? thanks for your input and or advice
Brian
brianbr is offline   Reply With Quote
Old 09-09-2007, 09:20 PM   #2 (permalink)
Hi, I'm a miserable user
Member Number: 46572
This was before or after you installed the bfmic. If not, sounds like pressure drop to me.
FREE 05SilverStreak...........
TheGreyGhost is offline   Reply With Quote
Old 09-09-2007, 09:29 PM   #3 (permalink)
brianbr's Avatar
i did notice a difference after installing the bfmic, but i re adjusted my waste gate and it seemed to hold fine, 14 psi anyway. i dont want to adjust it anymore because i dont have a wideband.
Old 09-09-2007, 09:54 PM   #4 (permalink)
CONROY's Avatar
Member Number: 46401
Trader Rating: (124)
i believe its normal.. mine did the same thing
Pittsburgh Penguins 41-23-5 87 points
CONROY is offline   Reply With Quote
Old 09-09-2007, 10:09 PM   #5 (permalink)
brianbr's Avatar
really? 12 psi at redline sucks. also is there an aceptable limit for turbo shaft play?
Old 09-10-2007, 05:08 PM   #6 (permalink)
brianbr's Avatar
anyone else have any ideas?
Old 09-10-2007, 05:13 PM   #7 (permalink)
dj muze's Avatar
Member Number: 46748
are you controlling you boost or is the computer? if you take the bleed line and connect it to the back of your compressor housing...you will have a more consistent boost reading. and the factory boost guage sucks. it may be inaccurate.
05 Orange
13.1 @ 109mph
ED BFMIC, PTP WGA 19-24psi, JMB Hard pipes, Needs Wings Down pipe, MaxFab O2 housing, Greddy Type RS BOV, Map Clamp, AEM Wideband, 03 fuel rail with return line kit, Ported and polished stock turbo and manifold, Tein springs, solid motor mounts, Mopar stage 1, Mopar STS, catch can, PTP check valve
Hey lady, drop the peon and hop in the Neon...LMAO
dj muze is offline   Reply With Quote
Old 09-10-2007, 06:00 PM   #8 (permalink)
brianbr's Avatar
i have the w/g line running off the compressor housing. i'm not sure how good the autometer pro comp 30 psi guage is but i have one
Old 09-10-2007, 06:08 PM   #9 (permalink)
dj muze's Avatar
well so long as the guage reads 0 when the car is turned off...it should be accurate. if your sure you have no leaks...then increase boost. you can take it up to about 18 safely after that you need a map clamp a fuel controler.
Old 09-10-2007, 06:27 PM   #10 (permalink)
brianbr's Avatar
ok, i'll try it. thanks for the help.
