If you are completely stock yes, but I would rather use the iridium 5 which is the same heat rang as OE. They will fire under the most cylinder pressure with any given gap as compared to the OE plugs having "spark blow out" at even smaller gaps.
If you are outfitted with mods definitely go with the step colder iridium plugs
