Over the winter I am trying to decide my next big mod. I will be building the bottom end, but wondering if I should do the head work first and see what kind of performance I can get. I know I am already pushing things with my current power levels, but seems to be holding up ok.
If I went with head work, do I have to do the whole shabaam or can I just have a local guy I know do port work, and maybe just change the springs / retainers / cams? Most guys will say BC3's or crane 18's and straight up is best, so maybe i wouldn't even get gears?
Right now I am around 450whp and about 27-28psi. I think with head work and cams I can probably pick up 20whp pretty easily.
Only mods that matter...AGP D55 turbo, ported stock intake manny, Mpx 62mm TB.
i did a head and bc3's. my bottom end only has 20k on it
AGP S256 FS DSP> S3K>PORTING>BUILDING>TUNING contact ptp
REALTUNED/BUILT by REALTUNE PERF. and powered by AGP TURBO DELTA HTA 60
10.97@136mph (not under full power yet)
The 6th realtune car to hit the 10 second club
I did the head/cam first and i kick myself every day for it, by the time I can afford the bottom end my head will need a refresher and I have never been able to take full advantage of the power potential of the upper half combo
do the bottom and do it well, cause cams and head will need 8k+ rpm any way
huh? You have to buy adjustable cam gears when you put aftermarket cams in the car. Otherwise you will be wasting that money and time. There is no off the shelf set of cams that are made perfectly for you D55 set up to be dropped in and ready to go. It doesnt work that way.
