Motor is out and bare.. wow its crazy how that whole like 2 inch half of on bottom of motor is the main caps far crank as well..
just curious since i am completly done with balance shafts what can all be removed from inside the engine...
i am ordering a new crank and also need a underdrive pully since i fucked mine all up!
what underdrive pully do i buy stock.. or a aftermarket 1 i was told stick with stock... also
ill buy the stock crank off modern performance for 160 unless somone knows if all i gatta get is a certain crank for it to be a stroker? or how does that work....
also where can i order my rod and main bearings and what name brand i wanna rev too 7500?
thanks hope to see feedback soon
05 srt4
SC61 ..je pistons crower rods,dcr oil pump kit windage tray and crank scraper,dcr head studs,180 therm. ,tkmotorsports timing belt and head gasket,fpr and return,rc750s,crane 16s,crane valve springs,fidanza cam gears,max fabb exhaust, rpm tb,agp race fmic,4 inch intake,screamin demon coil and plug wires,agp ic pipe,hks bov,perrin fuel rail,agp mm's,ss brake lines,18's..
Stock main pulley is the one to stick with but if you want to go aftermarket like I plan to, I would go with the ATI main pulley. Its the only one that offers the same charactristics as the stock one but with High performance in mind.
wow thank u very much... expesially for giving me site and part number/link to that ati pully... also please explain or show me what a strap kit is and what it does thank you
The strap kit is Billet pieces of metal that are machined to fit in the main bearing girdle, with girdle machining as well. Strengthens the support for the crank. Very good idea if your going to be revving higher than stock redline and expecially if your going to rev to 7500rpm. DCR sells a kit that is very good.
Use the modern performance rod and main bearings then get them coated by modern performance. They use calico coating. It is the best and cheaper then dcr.
I used crower rods to be safe but eagles should be ok.
I agree with^. If you have the money get the crank straps. You can spray nitrous later on without crank walk.
I would get DCR head bolts and ARP cam tower bolts (If you get the DCR crank straps you don't need cam tower bolts)and ARP main studs.
Now go get your shine box!
2005 Black ACR
Powered by Tune Time performance and N2MB
PTP sells a tri-metal design and with the added rpm it would be a good idea to go with a high quality main bearing. Your talking about one of the most important bearings to your engine. Plus the main bearings from ptp are already calico coated as well.
well.. i never could find the site for darrel cox racing and now i have it and love it... first off tho which kinda sucks but good also cause i have to work for what i want.. but i am not ganna be able to afford the crank straps this year.. so maybe over winter... anyways as of now im ganna work a deal out with mathew00029 to get them rod and main bearings and then looks like imma need to find me a new underdrive pully... which 409 bucks for the ati is prob. out of my price range right now... so looking for a stocker... i appriciate all the help..
also when puting my motor back together will the machine shop know too put rubber sealant all over main bearing girdle... or is there a gasket kit i should buy for putting motor back together for new water pump seal and all that?
should i also just buy the stock crank from modern performanc as well? thanks every1
and on the bottom of my dcr pick up tube there is not kinda of fiilter or ntohing just like shown on dcr site.. is that how it will be in the engine correct?...
where do i send my pcm out so its no codes like the stage 1 ect. but also revs out too 7500 rpm? do i have to send my stock pcm out and they do t witht hat 1 or can i send my stage 1 pcm out and they can make the rpm rev out higher?
send the ecu to forward motion for there b&g reflash, it'll take it up to 7000, if your going to be revving to 7500 you should get EMS and crank straps
conroy told me the AEM FIC and ems is 2 best ways to tune our cars right now and i can't find the aem fic n e where... if somone could give me a hand i would appriciate it tons... also i got on forward motions site and cannot find how to get my pcm flashed for reving higher.. and which pcm should i send them the stage 1 pcm or stock pcm that i have.. thanks every1 for ur advice...
