Old 10-03-2009, 05:16 PM   #1 (permalink)
StlJimmy's Avatar
Member Number: 62656
Default Monster shaft play AGP 50 trim
Car is burning a ton oil now. I checked the shaft play today and found this. I got 64k on it. Would this make me go through like a quart every 100 miles or so?
YouTube - SRT-4 AGP 50 trim turbo excessive shaft play
StlJimmy is offline   Reply With Quote
Old 10-03-2009, 05:24 PM   #2 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
64k on the car or the turbo
AGP S256 FS
Old 10-03-2009, 05:27 PM   #3 (permalink)
StlJimmy's Avatar
64 is on the car. I bought it w/ 38k on it and the turbo was already there.
Old 10-03-2009, 05:28 PM   #4 (permalink)
lyncoo's Avatar
Trader Rating: (92)
you need a new turbo. massive amount of shaft play and the turbo fins are chewed up from it
Old 10-03-2009, 05:44 PM   #5 (permalink)
Adionik's Avatar
Member Number: 51197
Trader Rating: (25)
Where can I get the Monster shaft play mod
Quote: Originally Posted by KoldKill View Post
E1 is ethanol fuel (corn based) you need mucho larger injectors and a tune (I think?) to run it...
Old 10-03-2009, 06:16 PM   #6 (permalink)
hercfe's Avatar
Member Number: 19255
holy shit that turbo is FUKKED! Go buy a new one now. DO NOT DRIVE YOUR CAR WITH THAT TURBO. if you chew up a comp blade when your turbine shaft snaps and your engine ingests the chunks, you're gonna be out a lot more than just a turbo.
hercfe is offline   Reply With Quote
Old 10-03-2009, 07:46 PM   #7 (permalink)
SRT of the Month
bitts's Avatar
Member Number: 29842
Trader Rating: (101)
God Damn !
I said God Damn !
Buy my turbo Look in sig
bitts is offline   Reply With Quote
Old 10-03-2009, 07:53 PM   #8 (permalink)
Member Number: 3387
Trader Rating: (15)
Holy balls that's insanity!! How did it not fly apart?
Keep your signature clean
edited by Peteblksrt4
jiggalude is offline   Reply With Quote
Old 10-03-2009, 08:09 PM   #9 (permalink)
porksword's Avatar
Member Number: 66925
Trader Rating: (21)
I agree with the "dont drive it at all with that turbo" or you are asking to screw up more.
porksword is offline   Reply With Quote
Old 10-03-2009, 08:59 PM   #10 (permalink)
Member Number: 53240
my god that turbo is toast!!
60ft.2.1 (street tires)
mph:101.54
sri,s2kit,tbe,fm.wga,sts,act clutch,wb,scangauge,30/30 boost gauge,hks bov,ed charge pipe,solid mounts.
Killasrt444 is offline   Reply With Quote
Old 10-03-2009, 09:05 PM   #11 (permalink)
HCCAFan's Avatar
Member Number: 35768
Trader Rating: (23)
Remove your check valve, check the drain tube, set your turbo timer, compression test, leak down test, check your drain tube again. Prolly not the turbo.
J/K Ya'll. It's fucked.
WTB: 96-07 Nissan Pathfinder parts;
Hood
Left front fender
Left headlight
Radiator
Condensor
Bumper Cover
Grille
HCCAFan is offline   Reply With Quote
Old 10-03-2009, 10:19 PM   #12 (permalink)
CJsStocker's Avatar
Member Number: 58783
Trader Rating: (40)
wow.
Did you ever looked at the inlet of the turbo before?
CJsStocker is offline   Reply With Quote
Old 10-03-2009, 10:48 PM   #13 (permalink)
AdvanSRT-4's Avatar
Member Number: 12791
Trader Rating: (57)
Old 10-03-2009, 11:02 PM   #14 (permalink)
2003srt-4's Avatar
Member Number: 67241
Trader Rating: (37)
turbo seems to be ok to me? lol..jk..man that turbo has a crazy amount of shaft play!
50trim..,AEM intake,hks bov,
mpx 62mm TB-agp shift selector
balance shaftchain removed-charge pipe mode
act 6-puck clutch w/prolite weight flywheel
quickwhips IC-hondata heatshield/gasket
bwoody h-brace,traction bars
3''TBE,wot box/2-step,180 stat,fan switch mod
hurst sts/booger bushing/msd coil/wires-safc neo,walbro 255lph,fuel pump rewire
s2 injectors, returnline,boomba fuel rail.dcr oil modifier,agp solid mm and trany mount.
2003srt-4 is offline   Reply With Quote
Old 10-03-2009, 11:05 PM   #15 (permalink)
Zero_psi's Avatar
Member Number: 71591
ahahahha lmfao
stage 1 with some other goodies
Zero_psi is offline   Reply With Quote
Page generated in 0.16865 seconds with 13 queries
