A misfiring spark plug would cause lean or rich? - Dodge SRT Forum
post #1 of 11 (permalink) Old 09-12-2011, 01:10 PM Thread Starter
dohc122acr's Avatar
Quoted: 0 Post(s)
As stated, if a spark plug didn't fire would the o2 sensor be lean or rich? All my fact digging and understanding says it would be outputting a lean signal.
Just a argument I'm having with a friend.
Silver 05 Srt-4 fpgreen s3
11.81 124
07 Charger RT AWD
dohc122acr is offline
post #2 of 11 (permalink) Old 09-12-2011, 01:35 PM
Mopar McNeer's Avatar
Quoted: 1 Post(s)
Not sure how much affect a single non-firing cylinder would have on overall o2 readings, but in theory, if your plug didn't fire, nothing would burn the gas, hence a rich (more fuel than air) condition in the cylinder.
Again in theory, when something like this happens, the ECU would get a rich reading from the o2 sensor and start pulling fuel which would then cause a lean condition. But if its only one cylinder, I really can't say how that would affect your o2 readings.
You can try it out, go out and start you car, then remove one of the plug wires (or start it with one plug wire off). If it does run on 3 cyl., then look at the o2 readings.
Report back with your findings.
AGP 50 Trim .82 A/R, Turbo666 DSP Tuned, Fully Built JP Pistons/BC Rods, DW 750 Injectors, Ported Intake w/ LFS 60mm, AGP Big FMIC, Crane #14 Cams & Cam Gears, Ravenworks CNC Ported w/ Indy Values, ED 3" Exhaust w/ Ported Exhaust Housing/Manifold, Walbro 255 & AGP Returnline w/ Bottleneck fix & Fuel Pump Rewire, HKS SSQV, Tial 38mm WG, ACT 6 Puck, Pwerks Billet Input Shaft.
Click to See my SRT
Click to see my old Avenger- RIP
Mopar McNeer is offline
post #3 of 11 (permalink) Old 09-12-2011, 01:42 PM Thread Starter
dohc122acr's Avatar
Quoted: 0 Post(s)
But the o2 sensor detects oxygen not fuel. A cylinder full of unburnt oxygen just went down to the sensor. Yeah there's fuel but o2 sensor doesn't detect fuel. So it would tell the PCM it's lean, PCM would add fuel to compensate creating a rich running car.
I'm with you though, I don't know if a spark plug occasionally not firing would effect anything enough to cause the PCM to make a change.
Someone knows this. Hoping duster, turbo666, or some other internal combustion smarty pants will chime in.
11.81 124
07 Charger RT AWD
post #4 of 11 (permalink) Old 09-12-2011, 01:49 PM
dodgenconverse's Avatar
Quoted: 0 Post(s)
^^ True about the sensors and it would read lean and it shouldn't effect it right away because the pcm runs off fuel trim but after a while the pcm will try to adapt to it
2005 SRT-4 stage 3 ef2
2004 Ram 1500 426 stroker, stage 2 cam, 100 shot (sold)
2010 HD Iron, Big bore kit, rigid struts, SE exhaust, SE intake (sold)
dodgenconverse is offline
post #5 of 11 (permalink) Old 09-12-2011, 01:52 PM
Quoted: 1 Post(s)
Good point DOHC and it makes sense.
Air-fuel ratio (AFR) is the mass ratio of air to fuel present. Just figured that the fuel is still mixing with the air, even if it isn't a burn mixture, for sensor to read. More fuel = lower A/F ratio.
Now I'm curious.... lol
Click to See my SRT
post #6 of 11 (permalink) Old 09-12-2011, 01:55 PM
duster360's Avatar
Quoted: 138 Post(s)
Misfires are often Lean
WWW.NEEDLESSTORQUE.COM
1025ccInj+ E85/GAS Base tunes =$385
E85+Gas Base tune Combo $150!!
Please EMAIL!!! dave at needlesstorque.com
www.facebook.com/needlesstorque
duster360 is offline
post #7 of 11 (permalink) Old 09-12-2011, 01:56 PM Thread Starter
dohc122acr's Avatar
Quoted: 0 Post(s)
Your on my friends side of the argument, at least I thought this is what his thinking was. But it's all good, just some fun education.
11.81 124
07 Charger RT AWD
post #8 of 11 (permalink) Old 09-12-2011, 02:11 PM
Quoted: 1 Post(s)
So you are saying that a non-firing plug would cause a lean condtion Duster? I wasn't entirely sure how to interpret your comment there.
Definately a good one. Should learn something by the time this is done.
Click to See my SRT
post #9 of 11 (permalink) Old 09-12-2011, 02:15 PM Thread Starter
dohc122acr's Avatar
Quoted: 0 Post(s)
Just a clarification. Would a unburned cylinder be picked up by the o2 sensor as lean or rich. And would an occasional ignition miss cause the PCM to add fuel at idle and light loads?
11.81 124
07 Charger RT AWD
post #10 of 11 (permalink) Old 09-12-2011, 03:15 PM
duster360's Avatar
Quoted: 138 Post(s)
A misfire is a brief and random lean spike.
The car would have to be running pretty shitty for the PCM to want to make a fuel adjustment. You'd get a P0300 first.
post #11 of 11 (permalink) Old 09-12-2011, 03:29 PM Thread Starter
dohc122acr's Avatar
Quoted: 0 Post(s)
Thanks duster. Makes sense to me.
11.81 124
07 Charger RT AWD
User Tag List
Linear Mode Linear Mode
