Low compression piston recommendation - Page 2 - SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum
Old 12-08-2012, 09:44 PM   #16 (permalink)
D-SRT's Avatar
Member Number: 80561
Quote: Originally Posted by SRT4 R View Post
can you even get that much low compression piston?
yes, why couldn't you? lol
I have 6.8:1...
Pumpking.
10.71@140. 1st SRT in TENS in CA.
Thanks to:
TUNED BY MINDMELT101@DRAG-ON Tuning. - http://drag-ontuning.com/blog/
GOKEY RACING for anything fabrication related
instagram for updates and pics: m_santiago37
D-SRT is offline   Reply With Quote
Old 12-08-2012, 09:46 PM   #17 (permalink)
D-SRT's Avatar
Quote: Originally Posted by boots View Post
There is no reason to go that low in compression, have a good tuner tune the car and won't have issues.
110% agree.
Pumpking.
Thanks to:
Old 12-09-2012, 12:24 AM   #18 (permalink)
SRT-Diesel's Avatar
Member Number: 75019
I run 7.0:1
Not a single issue with knock, ever.
SRT-Diesel is offline   Reply With Quote
Old 12-09-2012, 01:38 AM   #19 (permalink)
Member Number: 80621
the only reason to be running that low of comp is 4bar of boost and an 80mm turbo with no intercooler, a bad tuner and 87octane fuel
Sold My Soul for a Neon
pm me for all your HID retrofit needs
TIRED OF YOUR EGO HARD DATA IS MORE IMPORTANT AND USEFUL TO OTHERS SEEKING KNOWLEDGE AND THOES WANTING TO ADVANCE THE PLATFORM
DONT GET STUCK ON PRECISION TURBOS AND BWS THEY ARE NOT THE END ALL........ OTHER GREAT OPTIONS EXIST DO SOME RESEARCH DON'T BE A SHEEP
loroku is offline   Reply With Quote
Old 12-09-2012, 09:07 AM   #20 (permalink)
SRT-Diesel's Avatar
You clearly do not know what you are talking about...
Old 12-09-2012, 12:33 PM   #21 (permalink)
Fresh Meat Moderator
tunerlover3's Avatar
Member Number: 76568
You can have anything made for the right amount of money.
Diablo CMR tuner ~Dan~
310HP 436TQ
XXXHP XXXTQ
Old 12-09-2012, 01:05 PM   #22 (permalink)
D-SRT's Avatar
Grade A internet tuner here.
Pumpking.
Thanks to:
Old 12-09-2012, 01:19 PM   #23 (permalink)
then please explain why you chose to run such low compression?
Old 12-09-2012, 01:24 PM   #24 (permalink)
i was exaggerating a bit but i have not heard of any benefit of going that low not to mention if you street drive car at all, your losing vE and fuel mileage goes in the toilet.
Old 12-09-2012, 01:45 PM   #25 (permalink)
D-SRT's Avatar
i lost no mpg going from 8.5 down to low compression. stop with the internet theorem, before you get stockpiled with chief for people to ignore.
Pumpking.
Thanks to:
Old 12-09-2012, 01:49 PM   #26 (permalink)
People go with low compression that want to run a lot of boost and lots of timing.
You could either build an engine for lots of boost/timing and low compression or build on engine with generally lower boost/timing and higher compression.
All depends on what fuel your using, what your tuner wants, etc.
310HP 436TQ
XXXHP XXXTQ
Old 12-09-2012, 01:52 PM   #27 (permalink)
D-SRT's Avatar
Because 4yrs ago, there was no such thing as a diablo sport. Dropping money for an AEM at a premium price at the time wasnt an option.
i was strictly 91octane, big turbo, and a piggyback...that was the best option for me at the time.
4yrs, going on 5yrs now at over 500hp the entire time on the same engiine...how many folks on this board can say that...ill thank the low compression for that.
with dsp's and ems being so cheap now and capable of having full control of timing, i wouldnt do low compression again, but i dont regret my decision at all.
Pumpking.
Thanks to:
Old 12-09-2012, 02:03 PM   #28 (permalink)
k just from my knowledge the only reason to go that low was for low octane to increase the tuning window.
im surprised you didn't lose mileage did you do cams at the same time?
Old 12-09-2012, 02:21 PM   #29 (permalink)
to the
op reduce your ignition timing and you will be able to run more boost especially with the meth
Old 12-09-2012, 04:49 PM   #30 (permalink)
SRT-Diesel's Avatar
I'll never have to worry about knock, especially on e85. The only "knock" I get is because my cams are so noisy. I plan on turning off the knock sensor completely. I may not make as much power at 30 lbs as these guys that run a 8.5 or higher, but I won't ever have a limit on the amount of boost and timing I can run and still make power.
