#1 (permalink) |
![]() Join Date: Dec 2003
Member Number: 6491
hey guys im currently in the process of gathering up parts for my new big bore low compression build. I already have the rods that i want in mind (eagle due to weight) and was wondering what manufacture and vendor you guys think offers the best piston design??
I plan on running big boost with 94 and meth and more timing then i run now (28deg @25psi) It would be nice if i could grab whole kit from a vendor. I have emailed 3 vendors and so far no reply back and its been over a week ![]() Thanks boys
F&F Stage III 47lb turbo
+1 Race head, Race ported IM BC 2 cams Ext WGA Meth Injection 11.4@125mph (old times, stock head and cams) 26psi |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
![]() Join Date: May 2004
Member Number: 11361
what fuel are you running?
i'm very happy with 8.8:1 and e85
Build Thread:http://www.srtforums.com/forums/f451...w-123k-612933/
PCM=S0, DSP rescaled, 3bar map/tip injectors= Siemens 80# (ebay $200) built motor, 8.8:1 weisco, eagle-h, strap & windage S3R DCR manifold ($500) w/evo8 turbo (ebay $150) - 20G/47# ebay ($200) Evo 8 WGA 24x12x4 w/cast ends - CXRacing (ebay $200) DataLogger DataQA, $25 Wideband UEGO (ebay $150) vette rims 275/40/17 needswing v5 SouthBend S3 |
#3 (permalink) |
![]() Join Date: Sep 2011
Member Number: 86347
im looking to do the same piston. Just worried about winter and running 93 SCH-I510 using AutoGuide.C
04 SRT-4: Under Construction
99 9-3: Daily Driver FS Thread: http://www.srtforums.com/forums/f416...5/#post9777568 |
#4 (permalink) |
Fresh Meat Moderator
![]() Join Date: Dec 2009
Member Number: 76568
You said low compression. How low are you talking?
![]() Diablo CMR tuner ~Dan~ 2004 Black Neon SRT4: E85 stock turbo SOLD ![]() 310HP 436TQ 2004 Eblue Neon SRT4: E85 5558 Built motor ![]() XXXHP XXXTQ |
#5 (permalink) |
lots of opinions on this topic..
personally i go with the math (just a few builds under my belt ) search the build section for 8.8:1 e85 s3+ builds.. lots of happy customers it all comes down to how much air and fuel/octane and temperature of the combustion Chambers .. spend some time searching around What You Need to Know About E85 Ethanol Alternative Fuel - Hot Rod Magazine im looking to do the same piston. Just worried about winter and running 93
SCH-I510 using AutoGuide.C![]()
#9 (permalink) |
![]() Join Date: Aug 2010
Member Number: 80621
do you plan on running 60psi of boost ??? if your running meth and 94 i would suggest at least 9.0:1 comp what turbo r u gong to be running, manifolds, cams,ported head?
not to mention you can only add in so much timing befor you get no gains from it and at 28*is about where im at on stock comp and e85 before the built block im currently in the processes of building a 10.0:1 comp 30+psi of boost monster that will eat e85
Sold My Soul for a Neon
pm me for all your HID retrofit needs TIRED OF YOUR EGO HARD DATA IS MORE IMPORTANT AND USEFUL TO OTHERS SEEKING KNOWLEDGE AND THOES WANTING TO ADVANCE THE PLATFORM DONT GET STUCK ON PRECISION TURBOS AND BWS THEY ARE NOT THE END ALL........ OTHER GREAT OPTIONS EXIST DO SOME RESEARCH DON'T BE A SHEEP Last edited by loroku; 12-07-2012 at 08:06 PM. |
#11 (permalink) |
Member Number: 80561
Work on the tune more..
I've ran 27psi on 91oct and 1 m5 nozzle 50%meth/50%water on a 58mm turbo. And any reason 7".2" vs that of 7.0 or 7.5? lol
Pumpking.
10.31@147. 1st SRT in TENS in CA. QUICKEST & FASTEST IN CA. Thanks to: TUNED BY MINDMELT101@DRAG-ON Tuning. - http://drag-ontuning.com/blog/ GOKEY RACING for anything fabrication related Instagram: m_santiago37 |
#12 (permalink) |
Member Number: 6491
I've ran 27psi on 91oct and 1 m5 nozzle 50%meth/50%water on a 58mm turbo. And any reason 7".2" vs that of 7.0 or 7.5? lol what kind of timing were u running thou? 7.2 so it gives me room for high boost high timing.
#13 (permalink) |
dude its all in the tune man i bet you have too much timing or not enough meth/water
is it knock or preignition?
pm me for all your HID retrofit needs TIRED OF YOUR EGO HARD DATA IS MORE IMPORTANT AND USEFUL TO OTHERS SEEKING KNOWLEDGE AND THOES WANTING TO ADVANCE THE PLATFORM DONT GET STUCK ON PRECISION TURBOS AND BWS THEY ARE NOT THE END ALL........ OTHER GREAT OPTIONS EXIST DO SOME RESEARCH DON'T BE A SHEEP |
#14 (permalink) |
Member Number: 6491
is it knock or preignition? im running an m10 nozzle spraying 80% meth... thats alot of meth.
#15 (permalink) |
![]() Join Date: Aug 2008
Member Number: 67116
There is no reason to go that low in compression, have a good tuner tune the car and won't have issues.
srt powered 1st gen
615hp@13psi through a DCR auto 9.87@153 first full pass |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
