Loctite 515 for bedplate sealant? - Dodge SRT Forum
post #1 of 28 (permalink) Old 08-16-2012, 06:35 PM Thread Starter
big4mike9's Avatar
Quoted: 0 Post(s)
I ordered mopar bedplate sealant from dcr and received this
It also costed me $40 fucking dollars. Can I get some advice on this.
Autoguide iPhone app
Click image for larger version
SRI, 3" Exhaust Depo Side Exit + 3" MPx O2, exhaust cutout, DSP, Mopar Plate, AGP Return Line, Walbro 255, Fuel Pump Rewire, Innovate Motorsports MTX-L, N2MB Wot box/2-step and Boost Box, Bwoody check valve, $20 catch can x2, STS, Rage-Tek Shifter Bushings, Pwerks 3rd Gear Extender, 3 Bar Sensors, Dusters Injectors and e85
big4mike9 is offline
post #2 of 28 (permalink) Old 08-16-2012, 06:37 PM
John203's Avatar
Quoted: 1 Post(s)
I have no peronal experience with it but if DCR is using it on their builds i wouldnt be worried about it , i would call and talk to them if your concerned
Dcr Option A + Cncport Street Storm head + DBB 6262 =
John203 is offline
post #3 of 28 (permalink) Old 08-16-2012, 06:47 PM
Spoolbus's Avatar
Quoted: 0 Post(s)
Spoolbus is offline
post #4 of 28 (permalink) Old 08-16-2012, 07:19 PM Thread Starter
big4mike9's Avatar
Quoted: 0 Post(s)
Wow. Thanks spool bus. I think this is bullshit. I'll be calling them tommorrow. I purchased mopar bedplate sealant not something I could buy at the autopart store. What a bummer.
post #5 of 28 (permalink) Old 08-16-2012, 07:21 PM
AnsareStg0's Avatar
Quoted: 0 Post(s)
Hopefully a mistake! if not get your funds back
Precision CEA 5557 on E85
2005 srt4 Purchased new 12/17/05-Sold 7/26/12
2006 Csrt8 purchased 8/5/12
AnsareStg0 is offline
post #6 of 28 (permalink) Old 08-16-2012, 07:32 PM
atroph's Avatar
Quoted: 201 Post(s)
Garage
You should have received the Mopar green anaerobic sealer. Not the red stuff for the bedplate.
Bedplate - green anaerobic sealer
4773257 $30.00 list $20.16 net
Sealant Torque Cure
Cam cap - Oil Pump - MTX halves - red anaerobic sealer
4318083 $15.00 list $10.08 net
Mopar Gasket Maker
(Loctite 518 or Permatex 51813 is the same)
I am not sure on the specs on the sealant you received, but the part numbers i gave are the ones you shoud have....
On that note some folks have used the red Mopar sealant on the bedplate. I would go with what the FSM calls for.
The green Mopar sealant is expensive if you can find it. IIRC +/-30.00 a tube.
atroph is offline
post #7 of 28 (permalink) Old 08-16-2012, 07:36 PM
csmsach's Avatar
Quoted: 25 Post(s)
Loctite 19614 (don't think it is available anymore or really ever was) is the direct equivilent to the Mopar Green Bed Plate Sealant. The 515 is used either for the cam caps, oil pump to block, or transmission.
The main difference is that the Green has no compressed thickness and the red does. You don't want the red anywhere near your bedplate.
MOPAR GASKET MAKER
Mopar Gasket Maker is an anaerobic type gasket
material. The material cures in the absence of air
when squeezed between two metallic surfaces. It will
not cure if left in the uncovered tube. The anaerobic
material is for use between two machined surfaces.
Do not use on flexible metal flanges.
MOPAR TORQUE CURE GASKET MAKER
Mopar Torque Cure Gasket Maker is a unique
anaerobic type gasket material to be used ONLY
between the bedplate and engine block. The material
cures in the absence of air when torqued between
two metallic surfaces. It will not cure if left in the
uncovered tube. This anaerobic material is specially
made to seal the area between the bedplate and cylinder
block without disturbing the bearing clearance
or alignment of these components.
csmsach is offline
post #8 of 28 (permalink) Old 08-16-2012, 07:50 PM Thread Starter
big4mike9's Avatar
Quoted: 0 Post(s)
Yeah I definitely ordered the green. Hopefully a honest mistake. I'll give them a call tommorrow morning.
post #9 of 28 (permalink) Old 08-16-2012, 07:56 PM
Quoted: 147 Post(s)
napa Permatex Anaerobic Gasket Maker - i think it was $10
405hp, 450tq
http://www.srtforums.com/forums/f451...w-123k-612933/
PCM=S0, DSP rescaled, 3bar map/tip
injectors= Siemens 80# (ebay $200)
built motor, 8.8:1 weisco, eagle-h, strap & windage
S3R DCR manifold ($500) w/evo8 turbo (ebay $150) - 20G/47# ebay ($200)
Evo 8 WGA
24x12x4 w/cast ends - CXRacing (ebay $200)
DataLogger DataQA, $25
Wideband UEGO (ebay $150)
vette rims 275/40/17
needswing v5
SouthBend S3
fixit is offline
post #10 of 28 (permalink) Old 08-16-2012, 11:29 PM
bratz_729's Avatar
Quoted: 17 Post(s)
Last I heard dcr told me the green was on backorder.. I used Hondabond on My build
Built Engine: Eagle/ Arias 8.75:1, Dcr strapped, Ported head w/ Crane 18's and Fidanza Gears.
Turbo/Fuel: PTE 6262-Ported, High Voltage Fab tubular top mount, DCR dual 044s, -8/-6 line, -8 JMB rail, AGP 1200's
Mindmelt 101 tuning
Build Thread:
http://www.srtforums.com/forums/f451...-build-617761/
bratz_729 is offline
post #11 of 28 (permalink) Old 08-16-2012, 11:47 PM
csmsach's Avatar
Quoted: 25 Post(s)
Call your dealers parts dept and ask them to look it up, part# 04773257
csmsach is offline
post #12 of 28 (permalink) Old 08-16-2012, 11:56 PM Thread Starter
big4mike9's Avatar
Quoted: 0 Post(s)
Thanks csmsach. If I call tommorrow and they don't have it, I'll get money back and contact my dealer.
post #13 of 28 (permalink) Old 08-20-2012, 01:18 PM Thread Starter
big4mike9's Avatar
Quoted: 0 Post(s)
ok update. I spoke to dcr and he told me that the order was correct and that this is better than the mopar green bedplate sealant. any suggestions?
post #14 of 28 (permalink) Old 08-20-2012, 02:26 PM
stroudtom7's Avatar
Quoted: 4 Post(s)
stroudtom7 is offline
post #15 of 28 (permalink) Old 08-20-2012, 02:31 PM Thread Starter
big4mike9's Avatar
Quoted: 0 Post(s)
Ok so my question is do I use it or do
I return it and buy the green stuff?
User Tag List
Linear Mode Linear Mode
