Old 07-01-2008, 11:48 PM   #1 (permalink)
turbonino69's Avatar
Member Number: 31428
Default Just installed the 62mm TB..Car is acting weird!!!!!!
okay fellas..I just intalled this thing. It took me about 2 hours. Once I cranked it up...idle rpms was much higher...i was around 1500 rpms idle. The throttle response is touchy..and when i take my foot off the gas...my car just keeps going..like the throttle is stuck or something. When i came to a red light..my car rev up and revved down, revd up and revd down..has anyone else been having these issues? I'm running GT30 right now
turbonino69 is offline   Reply With Quote
Old 07-09-2008, 03:04 PM   #2 (permalink)
Member Number: 37263
check your tps wiring to see if you fucked a wire or something... if you don't find anything you have a nice vaccum leak.
Did you install the gasket for the tb properly? Is is bolted on tightly? Check the hoses going to the tb..... pretty much anywhere around there that has a seal. Quickest way to check is spray some carburator cleaner around the area (or you can use propane) and if the car hesitates or almost dies.... you have found your leak.
2004 Stage 4 SRT4
1996 Chevy Cavalier Z24 Custom Turbo
akana1723 is offline   Reply With Quote
Old 07-09-2008, 03:28 PM   #3 (permalink)
SRTie4k's Avatar
Member Number: 45499
Trader Rating: (31)
You might have a leak, but I'm guessing the car just has to learn the new TB.
Old 07-10-2008, 11:34 PM   #4 (permalink)
matthew00029's Avatar
Member Number: 46349
If you checked and don't have any boost leaks than try resetting your PCM by disconnecting the ground on the battery for 15seconds than reconnect. Go drive around and give your computer time to learn your driving habits and the tb install.
05 Black SRT-4 ACR A lot of hard work and broke days. I hope someday the black beast will return...
matthew00029 is online now   Reply With Quote
Old 08-19-2008, 08:14 AM   #5 (permalink)
str5010's Avatar
Member Number: 34460
Any updates?
str5010 is offline   Reply With Quote
Page generated in 0.14578 seconds with 11 queries
