#136 (permalink) |
![]() Join Date: Oct 2007
Member Number: 58560
op what are your power goals ...........
anything is possible with money and some know how now is it worth it? why will a built 2.4l NOT reach your goals? or i can tell you i have seen a 2.6l make DAMN close to 1000hp at 7800ish rpms ? "engine dyno" point in case if all you want is higher revs ...your better off buying a motor more suited to what you want. ie a Honda....... before deciding to stroke/destroke build or stay with a stock block, you should have set goals for your build.
DCR 2.6l
DCR OUTLAW HEAD AGP ZETA 3.2 .91 T4 AEM EMS DCR BUILT 5-SPEED 37k in parts-everything dcr makes (-) auto trans Just remember guys, you get what you pay for.
DCR has made 1400whp and ran 7s. Has anyone else done that? the shaft speed is past holy shit and halfway into wtf and at that point
| Sponsored Links | |||
Advertisement | |||
#137 (permalink) |
![]() Join Date: Aug 2005
Member Number: 32196
17x8 245/40/17 ST40 BBK Project TRAIN DONE!11/13/09
04 -E-85 Ported Stock Turbo,Stock cams&Head,Stock Motor,Safc Neo 329.69Hp, 395.77Tq STD 297Hp@6K 320.87Hp, 385.18Tq SAE WTB Locked DSP,Built 5speed,SCT Prp |
#138 (permalink) |
SRT of the Month ![]() ![]() Join Date: Mar 2005
Member Number: 25206
My RPM's are currently limited by the stock PCM's RPM resolution (8160) and the trans shifting. I've taken it higher on the dyno but won't do it on the track. I'll probably do some sort of EMS over the winter along with a better head and bigger cams and turn her close to 9k. My setup is very oriented for high RPM's (outlaw intake manifold, 1.25 Twin Scroll S400 67mm, etc) so I wanna make it work the best it can.
My bottom end is a long rod setup with a ion treated stock crank
04 SRT-4-10.18@150.3, and still a lot left in it...
Engine builds, dyno tuning, fabrication, and more available! PM me for pricing and details! Contact me for great prices on your part needs! http://www.facebook.com/BrutalSpeedAndTuning |
#139 (permalink) |
DCR 2.6l
#140 (permalink) |
That's a damn good price for that setup, I like the long rod and shorter stroke better R/A. Few questions if you don't mind, is the crank pedulum cut and or bullnosed cut leading edge... I have learned knife edge is what you don't want. Also is the journal size smaller to carry the load of super high revs? What was the balance of the crank after I've heard under balanced ie 45%. And last was there also a offset grind done? Just want to know, I'm very interested thank you for your time.
#141 (permalink) |
Few questions if you don't mind, is the crank pedulum cut and or bullnosed cut leading edge... I have learned knife edge is what you don't want. Also is the journal size smaller to carry the load of super high revs? What was the balance of the crank after I've heard under balanced ie 45%. And last was there also a offset grind done? Just want to know, I'm very interested thank you for your time. .........i have no idea what your talking about.......
DCR 2.6l
#142 (permalink) |
My bottom end is a long rod setup with a ion treated stock crank Thank you for sharing, it means a lot ...and we all can learn from eachother. I have read a lot about the all motor neon guys, one having problems trying to get 12,000 rpms. He was stuck around 9k then he did this and it fixed his issues. .080 air gap between the sensor and tone wheel, that might do the trick I don't know for sure. Never ran that high but it worked for him it may or may not help you. But I thought I would share. I hope to see Neon's in gen cleaning house!
04 -E-85 Ported Stock Turbo,Stock cams&Head,Stock Motor,Safc Neo 329.69Hp, 395.77Tq STD 297Hp@6K 320.87Hp, 385.18Tq SAE WTB Locked DSP,Built 5speed,SCT Prp Last edited by Racerxvsspeedracer; 11-08-2012 at 01:22 AM. |
#143 (permalink) |
Oh ok, can you get Daddy in here to talk then.. LOL
#144 (permalink) |
well i can sure you my father will be no help to you either .....
DCR 2.6l
#145 (permalink) |
I meant to say Step Daddy Dcr ......LOL
#146 (permalink) |
[QUOTE=Racerxvsspeedracer;9699225]I meant to say Step Daddy Dcr ......LOL[/QUOTe
Darrell Cox and i have no family ties
DCR 2.6l
#147 (permalink) |
KW... I'm sorry you're mad at me, trust me I want to see you do good. I want everyone to reach their goals,without any problems. That's what this forum should be about IMHO, anyway thought I be a bigger man and tell ya!
#148 (permalink) |
![]() Join Date: Oct 2005
Member Number: 34576
I try to shift my car at 8600 and go through the traps at about 8800. I don't see the reason to go to 10,000 RPMs but if I had to I would but as of now I don't have to
If Kevin wants to run his car at 10,000 RPMs that's fine he likes to try different stuff I don't know of anything that he has tried that worked He certainly isn't scared to try new stuff. He certainly is not a guy that goes the Proven route but then again maybe that's why his car has not ran in three years +
"The Red Sled"
Best ET 8.83 - Best MPH 169.30 Engine by Darrell Cox Racing 2.6 Stroker-w-DCR Auto Official Partners of the Red Sled N2MB Racing , Chris Miller Racing , M&H Tire, Nitrous Express Last edited by bayshore power; 11-08-2012 at 05:17 AM. |
#149 (permalink) |
SRTotM Moderator ![]() ![]() Join Date: Apr 2010
Member Number: 78946
You don't need them to make high #'s, they are used to Rev high less weight = less force on crank and bearings,journals.
Some still use steel rods. Im sorry does a 7275 spool at 3k and make power till 8 k.. most likely not... With the numbers crunched in my head i will likely spool around 5500.. so if it holds power till 10k im gonna rev it there.... im not building some street car.. my car is getting built to do one thing.. and thats go well over 200MPH.. Im so glad that everyone knows what im doing so well... But i do need the high RPMs it helps with traction and MPH at 9500rpm on stock gearing that is 199MPH compared to a measly stock 126.1 ![]() and who are some of you to come in and say treated cranks don't work? they have worked for years in redsled sled, the outlaw car and many other cars... it just makes me laugh how the crank is rarely an issue but you say it.. If the OP wants to rev that high let him do it.. but OP beware you lose tons of TQ and all low and mid range power unless you stuff a small ass turbo on it, but then you defeated the entire purpose of destroking the motor..
Huge thanks to Chris, Bill, And Bob @MAPerformane for 95% of all my parts
Huge Thanks to Kevin Warren For.. Many many things MAP EF4 stock block, stock head 452whp on EMS at 26 psi 100&92 octane mix Fully built long block and big numbers coming! |
#150 (permalink) |
If Kevin wants to run his car at 10,000 RPMs that's fine he likes to try different stuff I don't know of anything that he has tried that worked He certainly isn't scared to try new stuff. He certainly is not a guy that goes the Proven route but then again maybe that's why his car has not ran in three years + One He actually has a real job and this is a hobby... 2 who the hell are you to talk all we have seen is issues from your car for the past year and a half and you come in here and run your mouth about kevin... Coll story bro you have the time to go what ever and race and your not getting any faster... i remember you were making calculations on redsled and saying 8.90s but when have you came close to that since you built that car again?? you have multiple engine issues, multiple boost control issues... all you have is issues and you run your mouth.. kinda like the pot calling the kettle black PS thanks for fucking me on that title
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
