Old 07-01-2008, 07:50 PM   #1 (permalink)
garryb05srt4's Avatar
Member Number: 64983
Default info/advice
hi,
so im buying an 04 srt with these mods, can anyone tell me what im will need or should get ,and what hp i might have. boost is set at 20psi right now. any info would be cool.thanks garry
mods are:
agp 50 trim kit,
agp upper&lower hard pipes,
agp cold air intake,
agp solid motor mounts,
lage intercooler (not sur what kind)
b&b 3' exhaust (no cat or muffler)
agp fuel line retun kit
walbro fuel pump
750cc injectors
turbo xs detec
turbo xs boost contoller and blow off valve
mopar stage 2 pcm &map
msd coil&wires
aem air fuel guage
iridieum plugs (2 stages colder)
garryb05srt4 is offline   Reply With Quote
Old 07-01-2008, 10:19 PM   #2 (permalink)
mods if this is in the wrtong place can you put it in the right one?
thanks
Old 07-01-2008, 10:32 PM   #3 (permalink)
04BlueSkittle's Avatar
Member Number: 52567
prolly around high high 300s or low to mid 400s depends if its on a good tune
Painted stockers , msd 8.5 wires, champion spark plugs .36 gap, MPx 3in tbe, aem wideband, prothane MM's, mopar bov, AGP wastgate hold 18/15, MPX 3in o2 housing, PTP Ported Exhaust Manifold, booger bushings,180 degree thermo, SAFC II w/ msd tach, ptp fan switch mod,NO BOOST LEAKS!!!!
04BlueSkittle is offline   Reply With Quote
Old 07-03-2008, 02:58 AM   #4 (permalink)
my_little_srt's Avatar
Member Number: 41179
The onlt thing about buying modded SRT is you never really know what the previous person did or didnt do right to the car......But I wish you the best of luck with the car..........
my_little_srt is online now   Reply With Quote
Page generated in 0.13803 seconds with 11 queries
