Old 11-17-2008, 08:56 AM   #31 (permalink)
camlifter's Avatar
Member Number: 3008
Trader Rating: (25)
using a common plenum would be the same as just having 1 t/b, once you where above idle, thats why you don't see it on boosted motors.
This post is completely ENVIRONMENTALLY GREEN. It was prepared using 100% recycled words and recovered hot air and other gases from the exhaust of the private jet Al Gore used to fly over to Norway and pick up his Nobel Prize. It has been further environmentally corrected and enhanced through the use of Intelligence Offset Coupons.
camlifter is offline   Reply With Quote
Old 11-17-2008, 09:24 AM   #32 (permalink)
Member Number: 30867
dont F1 cars and some other high end race cars run forced induction and ITB's?
Caric is offline   Reply With Quote
Old 11-17-2008, 11:15 AM   #33 (permalink)
Slow_spool's Avatar
Member Number: 50382
Trader Rating: (33)
f1 cars are N/A.
Slow_spool is offline   Reply With Quote
Old 11-17-2008, 03:26 PM   #34 (permalink)
2004NeonSRT4's Avatar
Member Number: 4577
Trader Rating: (44)
more rb26 itb info
Google Image Result for http://images.sportcompactcarweb.com/features/0505_scc_skyline_09_z.jpg
2004NeonSRT4 is offline   Reply With Quote
Old 11-17-2008, 07:52 PM   #35 (permalink)
SpeedEuphoria's Avatar
Member Number: 30870
ITB The Way It Should Be - Pacific Northwest Speed
Project log pics
Old 11-19-2008, 12:35 PM   #36 (permalink)
a853rox's Avatar
Member Number: 1907
Trader Rating: (52)
The only way I would even think about installing ITB's would be before the runners start in toward the head. That way there would be a chance for the airflow to smooth out a bit after being forced around the butterfly and bar.
You would still need to have a decent design for a surgetank/plenum.
I would think getting the car to idle right could be a challenge as well.
I think it's not worth the effort as we have seen numerous 700+whp srt's do well on the stock manifold with nothing more than a bit of portwork.
Can it be done? Probably. Is it practical? No. Again, the stock design is great compared to any number of other oem applications.
$.02
a853rox is offline   Reply With Quote
Old 11-19-2008, 12:53 PM   #37 (permalink)
DDogsrt461BLK 3.0's Avatar
Member Number: 32500
I'm going ITB system on my stock turbo car, it will be the fastest. 7-10K should really shine
DDogsrt461BLK 3.0 is offline   Reply With Quote
Old 11-19-2008, 04:20 PM   #38 (permalink)
aww sheet's Avatar
Member Number: 20431
Trader Rating: (31)
$.02
now thats the answer i was looking for. as i was reading about them and wondering why no one has tried this, i never considered the cost to benefit
ratio.
why are they so hard to tune? i know its bringing a shit load of more air in. would you have to extremely large injectors, or 4 more?
View Modifications
Old 11-20-2008, 07:23 AM   #39 (permalink)
duster360's Avatar
Member Number: 45182
Most OEM designs that I'd seen actually use the butterfly near the port to induce swirl and tumble(4cly Sport bikes, I think a ford v8 has a "swirl" throttle near the port entry). This makes the mixture more homogenious, thus improving combustion efficiency and usually increases mass flow and particularly transient response. To adapt a similiar design properly, you would need a wet flow bench to see any improvments as a regualar bench would show little if any CFM increase.
duster360 is online now   Reply With Quote
Old 11-20-2008, 07:28 AM   #40 (permalink)
duster360's Avatar
They're not hard to tune
An increase in mass flow would be moderate and would only need similiar increase in fuel. I seriously doubt larger injectors would be needed but only changes to the fuel map, unless the current injectors are maxed out.
$$/HP benefit would be very small.
Old 11-20-2008, 11:50 AM   #41 (permalink)
Member Number: 30696
people say the are hard to tune... because they are thinking of the old Mopar 6pack (three 2 bbl carbs) and in reality.. they WHERE a bitch to tune.
amdguy is offline   Reply With Quote
Page generated in 0.19411 seconds with 13 queries
